Panasonic TX-L42ET5B - how to change language?
  • milha
    • 48
    • Czech republic
    What kind of violation? I don't know, but I was warned I was not allowed to send files .bin.
    Lotas, if you send me your e-mail address I will send you the dump and you can give it here on the site then. I will be glad.​
    • lotas
      • Jan 2016
      • 4859
      • Russia
      This is not possible in “bin”, but you can pack it in zip or winrar, or send it to me in a private message, I’ll post it here.
      • milha
        • 48
        • Czech republic
        I wanted to send it to you in private message, but for me there is no possibility to add any attachment there, only the URL link. I am sorry, I do not want to communicate with you more. Have a good time.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4538
          • Italy - Milan
          Lotas maybe we are the only crutch of the forum.. sad..
            You are allowed to post the file here no problem. that's what the forum is all about.
            • milha
              • 48
              • Czech republic
              #26
              So, here is the dump for the European version of TX-L42ET5E:
              • milha
                • 48
                • Czech republic
                #27
                From service manual:
                5 Technical Descriptions
                5.1. Specification of KEY for DTCP-IP, WMDRM and Widevine
                5.1.1. General information:
                1. EEPROM (IC8902) for spare parts has the seed of KEY for each DTCP-IP for DLNA, WMDRM for Netflix and Widevine for
                CinemaNow.
                2. The final KEY data will be generated by Peaks IC (IC8000) when SELF CHECK was done and are stored in both Peaks IC
                (IC8000) and EEPROM (IC8902).
                5.1.2. Replacement of ICs:
                When Peaks IC is replaced, EEPROM should be also replaced with new one the same time.
                When EEPROM is replaced, Peaks IC is not necessary to be replaced the same time.
                After the replacement of IC, SELF CHECK should be done to generate the final KEY data.
                How to SELF CHECK: While pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for
                more than 3 seconds.
                TV will be forced to the factory shipment setting after this SELF CHECK.
                  Thanks for coming back and posting Milha, our users really appreciate it
                  • milha
                    • 48
                    • Czech republic
                    #29
                    No need to thank. I am glad, that I could also help.
                    • milha
                      • 48
                      • Czech republic
                      #30
                      That's all. I thank to everyone for help. Good luck!
                        LCD LED TV Service Menu Codes
                        ALL LCD LED TV SERVICE MENU CODES
                        Service Menu Code with Board Name
                        China Universal Board / Jumper Board Service Menu Code
                        Changhong Ruba Service Menu Code
                        Ecostar LED TV Service Menu Code
                        Orient LED TV Service Menu Code
                        Haier LED TV Service Menu Code
                        TCL LED TV Service Menu Code
                        Samsung LED TV Service Menu Code
                        LG LED TV Service Menu Code
                        Videocon LED TV Service Menu Code
                        Supra LED TV Service Menu Code
                        Toshiba LED TV Service Menu Code
                        Symphony LED TV Service Menu Code
                        Veste/ LED TV Service Menu Code...
                        10-31-2024, 03:58 AM
                      • BigPete
                        Panasonic Heatpump Dryer Repair
                        by BigPete
                        I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                        The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                        In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                        Unfortunately the whole machine has to come apart to fix it.
                        I have...
                        11-01-2025, 06:40 PM
                      • Andre Gilbert
                        by Andre Gilbert
                        Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                        Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                        11-20-2024, 08:52 PM
                      • Retro140
                        Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
                        by Retro140
                        So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
                        To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
                        06-18-2023, 06:13 PM
                      • AquaMan Ua
                        by AquaMan Ua
                        05-17-2025, 09:40 AM
