Panasonic TX-L42ET5B - how to change language?
  • milha
    • Jun 2012
    • 48
    • Czech republic
    What kind of violation? I don't know, but I was warned I was not allowed to send files .bin.
    Lotas, if you send me your e-mail address I will send you the dump and you can give it here on the site then. I will be glad.​
    • lotas
      • Jan 2016
      • 4453
      • Russia
      This is not possible in “bin”, but you can pack it in zip or winrar, or send it to me in a private message, I’ll post it here.
      • milha
        • Jun 2012
        • 48
        • Czech republic
        I wanted to send it to you in private message, but for me there is no possibility to add any attachment there, only the URL link. I am sorry, I do not want to communicate with you more. Have a good time.
        • Davi.p
          Hobbist
          • Sep 2009
          • 4258
          • Italy - Milan
          Lotas maybe we are the only crutch of the forum.. sad..
            • 115463
            You are allowed to post the file here no problem. that's what the forum is all about.
            • milha
              • Jun 2012
              • 48
              • Czech republic
              #26
              So, here is the dump for the European version of TX-L42ET5E:
              • milha
                • Jun 2012
                • 48
                • Czech republic
                #27
                From service manual:
                5 Technical Descriptions
                5.1. Specification of KEY for DTCP-IP, WMDRM and Widevine
                5.1.1. General information:
                1. EEPROM (IC8902) for spare parts has the seed of KEY for each DTCP-IP for DLNA, WMDRM for Netflix and Widevine for
                CinemaNow.
                2. The final KEY data will be generated by Peaks IC (IC8000) when SELF CHECK was done and are stored in both Peaks IC
                (IC8000) and EEPROM (IC8902).
                5.1.2. Replacement of ICs:
                When Peaks IC is replaced, EEPROM should be also replaced with new one the same time.
                When EEPROM is replaced, Peaks IC is not necessary to be replaced the same time.
                After the replacement of IC, SELF CHECK should be done to generate the final KEY data.
                How to SELF CHECK: While pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for
                more than 3 seconds.
                TV will be forced to the factory shipment setting after this SELF CHECK.
                  • 115463
                  #28
                  Thanks for coming back and posting Milha, our users really appreciate it
                  • milha
                    • Jun 2012
                    • 48
                    • Czech republic
                    #29
                    No need to thank. I am glad, that I could also help.
                    • milha
                      • Jun 2012
                      • 48
                      • Czech republic
                      #30
                      That's all. I thank to everyone for help. Good luck!
                        LCD LED TV Service Menu Codes
                        TCL LED TV Service Menu Code
                        LG LED TV Service Menu Code
                        10-31-2024, 03:58 AM
                      • Andre Gilbert
                        by Andre Gilbert
                        11-20-2024, 08:52 PM
                      • Retro140
                        Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
                        by Retro140
                        So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
                        To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
                        06-18-2023, 06:13 PM
                      • finntricky
                        TX-58AX802B, Panasonic no pic but have menu display
                        by finntricky
                        strange going on with this tv,
                        turns on as normal, but with no picture,i have sound from the tv channel that it is on, back lights ok and come on, i can press the menu button and get the menu up, i can also press a channel button or volume and they also display with no problem. just can not get a pic from the tv ?
                        no pics at this time as only just picked it up and yet to take apart,
                        what do you think ?
                        anyone had the same probs ?
                        02-10-2021, 11:27 AM
                      • Ierwin
                        Philips 58PUS7805 Menu working but no/weird picture from video sources
                        by Ierwin
                        I got a 58pus7805 that shows some weird behavior.
                        The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
                        However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
                        I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
                        I managed to install the latest official firmware by holding the control button while plugging...
                        03-10-2024, 12:50 PM
