Panasonic TX-L42ET5B - how to change language?
  • milha
    • Jun 2012
    • 48
    • Czech republic
    Hello! I have exchanged the mainboard TNPH0993 in my TV Panasonic TX-L42ET5E (E like Europe) for the same board which comes from TV TX-L42ET5B (B like Britain). The TV works properly, but in menu is missing the possibility to set the language and the region of use. I tried to set it in the service menu, but there it isn't possible either. In the end I upgraded firmware on the newest version for Europe models and expected it to help, but it didn't. The two items in the menu are still missing. So my question is: " How can I set this board from Britain TV model to the Europe model?" I think it must be possible, the boards are exactly the same, only the settings (softwares) are different. Just the menu on the picture is missing.
    Note from Admin on the now removed reply - please do not be snarky with people asking for help. Especially if it's simply a minor issue with how someone words their post.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4319
      • Italy - Milan
      I don't know how it works in these sets, but i know there is a settings eprom on the MB, you can try to copy the content of the one on original MB to the new MB, or swap the ic, then perform a service reset, i don't think it works but who knows?
      • milha
        • Jun 2012
        • 48
        • Czech republic
        I have here one mechanically damaged original board type E. I wanted to swap some of the memories, but I was said it is not possible, because all the memories are associated vith the processor. They must have the same numbers written in them. The numbers would have to be changed, but I am not able to do it.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4319
          • Italy - Milan
          I don't know this info on this particular model, you can try it, if you are skilled enough in simple smd works like this there's no risk.. have you got sop8 clip?
          • milha
            • Jun 2012
            • 48
            • Czech republic
            There are SPI, NAND and DDR memories on this board. You are only speaking about SPI memory. Yes, I have the sop8 clip and I could download the dates from that SPI memory on original board and write to another one. But I think, it would be useless. There are only the personal settings in this memory, not software. I will wait for opinion of other technicians for now. Thank you.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4319
              • Italy - Milan
              Post the marking of every sop8 chip on the board, i recall a 24c type eprom, but not easy to recognize
              • milha
                • Jun 2012
                • 48
                • Czech republic
                There is only one EEPROM on the board. It is 24C64F.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4319
                  • Italy - Milan
                  Yes that is the settings eprom, you don't need other memories, try it, clean the chip before with a bit of IPA and let it sit for a couple minutes because of oxydation before read it..
                  • milha
                    • Jun 2012
                    • 48
                    • Czech republic
                    Yes, I am going to try it. I'll let you know.
                    • milha
                      • Jun 2012
                      • 48
                      • Czech republic
                      I did it, how you had advised me. I downloaded the contents of the EEPROM on the Europe board and then uploaded it into the EEPROM on the English board. It worked. You were right. I am happy now. My TV is working properly - it has full menu and all the function. Thank you very much. Have a good time!
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4319
                        • Italy - Milan
                        Ok, happy to hear,. bye...
                        PS: just my curiosity, it worked before or after the service menu reset?
                        • milha
                          • Jun 2012
                          • 48
                          • Czech republic
                          It worked immediately, without service menu reset.
                          • lotas
                            • Jan 2016
                            • 4589
                            • Russia
                            Post Dump eeprom for Europe here, maybe someone will find it useful in the future.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4319
                              • Italy - Milan
                              Sorry for my curiosity... prior the eeprom programming, have you launched the reset in some way and not ended the first setup?
                              • milha
                                • Jun 2012
                                • 48
                                • Czech republic
                                I programmed a new EEPROM. Then I soldered it onto the board. Then I inserted the board to the TV. After the switch on I was asked for the first set up - choosing of the language, region etc. There was needed to do nothing more in service menu.
                                • milha
                                  • Jun 2012
                                  • 48
                                  • Czech republic
                                  I am sorry, I tried to give here the dump for the Europe version, but I was written: " You are not allowed to uplowed the file of extension .bin"
                                  • lotas
                                    • Jan 2016
                                    • 4589
                                    • Russia
                                    Pack in WinRar or Zip
                                    • milha
                                      • Jun 2012
                                      • 48
                                      • Czech republic
                                      I don't want to break the forum rules. I do not want to have trouble with the admin.
                                      • lotas
                                        • Jan 2016
                                        • 4589
                                        • Russia
                                        And what kind of violation can you do by posting a working dump to help others, I probably posted about a thousand dumps on this forum along with corrected dumps...
                                          LCD LED TV Service Menu Codes
                                          TCL LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          10-31-2024, 03:58 AM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          11-20-2024, 08:52 PM
                                        • Retro140
                                          Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
                                          by Retro140
                                          So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
                                          To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
                                          06-18-2023, 06:13 PM
                                        • Ierwin
                                          Philips 58PUS7805 Menu working but no/weird picture from video sources
                                          by Ierwin
                                          I got a 58pus7805 that shows some weird behavior.
                                          The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
                                          However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
                                          I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
                                          I managed to install the latest official firmware by holding the control button while plugging...
                                          03-10-2024, 12:50 PM
                                        • AquaMan Ua
                                          Problem with PANASONIC CF53 laptop after changing BIOS settings
                                          by AquaMan Ua
                                          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                          05-17-2025, 09:40 AM
