Help identifying fuse
  • audiofreak19
    • Apr 2013
    • 556
    • usa
    So just picked up this lnt3242h and it powers on but no backlight and no picture. I have 24v going to the inverter. I checked the fuses on the inverter and the F3 fuse has 24v coming from power supply and .413v on the other side. How do I know what kind of fuse to get. It's the little one with the D on it.
  • R_J
    • 9535
    Re: Help identifying fuse
    From some of the data sheets I've seen its a fast acting .25 amp 63volt
      Too bad there is no standard as far as the letter as printed on the fuse which suppose to represent the current rating.
      You can put your meter in DCA mode and to take the current draw reading but I would check the the resistance on the output side of the fuse to see if it shows really low resistance first.
      • audiofreak19
        • Apr 2013
        • 556
        • usa
        Ok cool thanks. Yea trackin. Down parts by the numbers and especially fuses like these are almost as hard as troubleshooting the tv. Lol
        • audiofreak19
          • Apr 2013
          • 556
          • usa
          So I found a good link to mousers website on help identifying fuses and it shows you how to identify them just like mine. Apparently this is the part number according to mouser. 2410SFV0.75FM/125
          • audiofreak19
            • Apr 2013
            • 556
            • usa
            Shoot. Here is the link the the web page I found. https://cdn.badcaps-static.com/pdfs/...95de4eb86b.pdf
            • audiofreak19
              • Apr 2013
              • 556
              • usa
              Another question. I have another tv with a similar looking component but the spot on the board is labeled like j220 or j19. Are these things the same or would it have to specifically have to come from a fused location
              • audiofreak19
                • Apr 2013
                • 556
                • usa
                Nvm they have a O on them not a D. Hard to see.
                • R_J
                  • 9535
                  Those with the 0 are jumpers or 0 ohm resistors
                  • audiofreak19
                    • Apr 2013
                    • 556
                    • usa
                    So I just got the fuse in. And it looks the same style and has the D on it but it's much larger. Now on te pad it has mini pads for the small size fuse but the bigger pads on both sides for a bigger one I suppose. It looks like I can solder this new one to the bigger pads but is that ok or do I need to order the exact same fuse. Take a look at the pict. The bigger fuse next to the smaller one
                    • audiofreak19
                      • Apr 2013
                      • 556
                      • usa
                      Here is one
                      • audiofreak19
                        • Apr 2013
                        • 556
                        • usa
                        Ok here we go
                        • audiofreak19
                          • Apr 2013
                          • 556
                          • usa
                          Here shows the difference in physical size
                          • SteveNielsen
                            Retired Tech
                            • 2327
                            If you can get it soldered in then it will be fine as long as it is the correct rating. Just because it is a surface mount doesn't mean you must replace it with a surface mount, if you have an equivalent fuse with leads it might be easier to solder that in.
                            • audiofreak19
                              • Apr 2013
                              • 556
                              • usa
                              And that's the thing I don't know what size the origonal one was. So it's real hard to fine the rating of the fuse. The one I have now is size 2410. I thing the origonal one is like a 0603. Cause when I looked it up on mousers website that was the only rating for the fuse with the letter D in that size so I don't know if it changes when they change sizes
                              • audiofreak19
                                • Apr 2013
                                • 556
                                • usa
                                Can anyone find a wiring schematic that might say the info for the F3 fuse on the inverter.
                                • bammbammfran
                                  • Apr 2014
                                  • 476
                                  littlefuse makes a greenish one like these with indented ends
                                  there D vmarking is 1/4amp
                                  0603 is around 1.6mm x .8mm
                                  1206 is just over 3mm x 1.5mm
                                  • SteveNielsen
                                    Retired Tech
                                    • 2327
                                    www.servicemanuals.net says they have a service manual for that unit but it'll cost you $16.99 to download it.
                                    • audiofreak19
                                      • Apr 2013
                                      • 556
                                      • usa
                                      Thanks for the specs on those fuses.
                                      • corrize
                                        A funny fuse story – Lumix LX100 II
                                        by corrize
                                        Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                        I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                        The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                        There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                        And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                        10-19-2023, 09:58 AM
                                      • 1234567v14ada
                                        identifying backlight fuse in v14 ada type 82C6
                                        by 1234567v14ada
                                        I need help identifying and replacing a blown backlight fuse in lenovo v14 ada type 82C6. Any help would be appreciated.....
                                        10-06-2023, 10:56 AM
                                      • unimatrix93
                                        Need help identifying SMD fuse
                                        by unimatrix93
                                        Hey everyone, I could use some help identifying these two SMD fuses:
                                        I'm not sure if they are 2A or 20A. Are they slow or fast acting?
                                        They are coming from a e-scooter BMS panel:
                                        They are located on the output circuit and the battery is a 21.6V 10.2Ah Li-ion battery.
                                        The fuses are blown, OL even on MOhm territory.
                                        The size parameters are 6.7mm x 2.4mm.
                                        Thank you!...
                                        08-14-2024, 01:14 AM
                                      • Iceking007
                                        Help With Identifying A Fuse (? I Think)
                                        by Iceking007
                                        I'm posting this here because I didn't see an "(Help) Identify(ing) Components"/ "Components (Information)" etc. Thread.
                                        I'm repairing a brushless DC motor board, nothing critical just a simple power board. One high side Mosfet and one low side Mosfet were found short (cross phases), and I didn't have continuity through the positive supply. Found two components that were not conducting. Their appearance was similar to capacitors, however they contained some writing, and they were online with the primary power bus. So I determined they were...
                                        07-27-2024, 01:52 PM
                                      • jesterace
                                        Samsung UE46ES8000 Blown fuse but no other signs of short
                                        by jesterace
                                        Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                        09-11-2024, 03:14 PM
