Help With Identifying A Fuse (? I Think)
  • Iceking007
    • Oct 2022
    • 10
    I'm posting this here because I didn't see an "(Help) Identify(ing) Components"/ "Components (Information)" etc. Thread.
    I'm repairing a brushless DC motor board, nothing critical just a simple power board. One high side Mosfet and one low side Mosfet were found short (cross phases), and I didn't have continuity through the positive supply. Found two components that were not conducting. Their appearance was similar to capacitors, however they contained some writing, and they were online with the primary power bus. So I determined they were fuses, initially thinking they contained the letter S, I convinced myself it must be a 5, and that they were 5A fuses.
    I ordered replacement parts, and when they arrived I discovered I made an error ordering imperial sizes instead of metric, and these are FAR too small (costly too... so that's gravely disappointing!). I went back to research more about SMD fuses and now reconsidering that these are in fact letter "S"s. However there is no standard, and brands use various symbols for their ratings. I thought a quick check on the Mosfets datasheet would help me sort safe currents, however the Mosfet are NTMFS4C302N, and rated for 230A, there is absolutely no way this circuit is rated anywhere near that threshold.
    So if I could get any assistance on tracking down these parts I would be grateful.
    dimensions measured roughly with a caliper:
    0.12..." (3mm)
    0.06..." (1.5mm)
    Please see attached image.
    Thank you for your time.
  • R_J
    • Jun 2012
    • 9625
    It is likely a 4 amp fuse
    • Iceking007
      • Oct 2022
      • 10
      I found that result as well... any idea on brand?
      • Iceking007
        • Oct 2022
        • 10
        I'm going to order some LittelFuse fuses, they have a 4A with an S code on the case, and they measure the same dimensions.
          Surface Mount Fuses Fundamentals Datasheet
          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
          10-07-2024, 06:07 AM
          TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
          FF Series (Very Fast Acting), 0603 Size
          Features
          ● Very fast acting at 200% overload current levels
          ● Low DCR
          ● High inrush current withstanding capability
          ● Fiberglass enforced epoxy fuse body
          ● Copper termination with nickel and tin plating
          ● Halogen free, RoHS compliance and lead-free
          Applications
          ● Notebook computers and tablets
          ● Digital cameras
          ● Memory cards
          ● Toys
          ● Bluetooth earphones
          ● Portable electronic devices​...
          10-07-2024, 05:50 AM
        • 1234567v14ada
          identifying backlight fuse in v14 ada type 82C6
          by 1234567v14ada
          I need help identifying and replacing a blown backlight fuse in lenovo v14 ada type 82C6. Any help would be appreciated.....
          10-06-2023, 10:56 AM
        • jesterace
          Samsung UE46ES8000 Blown fuse but no other signs of short
          by jesterace
          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
          09-11-2024, 03:14 PM
        • jshhh
          Help replacing fuse on my Mimaki CJV300-160 vinyl printer
          by jshhh
          Hi guys,
          I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
          How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
          Anybody know how to remove this type of fuse?
          (The fuse is toward the bottom of the image labeled F2)...
          06-17-2025, 01:35 AM
