Emerson LC320EM2 back lights on but no picture
  • Gorrillasnot
    • Dec 2013
    • 316
    Re: Emerson LC320EM2 back lights on but no picture
    I received my LVDS cable in the mail today. I installed it and the TV now works.
    I paid $20 for the TV plus $14 for a replacement main board (since I shorted the original) and $8 for the LVDS cable.
    Total invested $42 which is allot for a lower end 32' TV but worth it to me for the experience and fun of tinkering.
    thank you very much everyone for all your help
    • Caleb
      Smokin IC's
      • Feb 2013
      • 645
      congrats, I would consider it a win! Make sure you have it on a good surge protector the power supply on these is notorious for dieing during surges.
      Liberating magic smoke one part at a time
      • high5va
        • Mar 2015
        • 4
        I found this thread so just joined the forum as I'm having same symptoms with the backlight and sound working but no picture - just some faint vertical lines. I checked the LVDT cable continuity and all wires tested good. I've not tested any voltages, etc. yet but thinking its the T-Con board from this discussion. Is there a quick test to verify? My unit looks exactly like the pics in this thread
        • Caleb
          Smokin IC's
          • Feb 2013
          • 645
          Probably your best bet is to check the tcon fuse for continuity and voltage. Do you have sound when you hook up a source? If so I would agree that it is likely the tcon.
          • high5va
            • Mar 2015
            • 4
            thanks for your feedback, Caleb. Yes I have sound when connected to source, just no pic and some faint vertical lines. I can only find one fuse and it is on the main power supply board - it has continuity so seems fine.
            This tcon board is connected to screen by several thin ribbon conductors adhered to the board without plug connectors, so I assume not really replaceable? If so, I assume this one is a lost cause?
            Thanks again for any feedback
              There is SMD fuse on the T-CON board that you need to find out if it has DCV at both ends of the fuse with ref. to the chassis.
              • Caleb
                Smokin IC's
                • Feb 2013
                • 645
                found a pic of the tcon and have put a red box around the fuse, although on this board it appears they have it labeled as and inductor.
                • high5va
                  • Mar 2015
                  • 4
                  Thanks tons to both budm & Caleb for your guidance. However, my t-con board appears identical to the one in Gorrillasnot's photos so does not appear easily worked on (see my photo attached)
                  I am currently leaning towards salvaging the other boards and speakers to sell off - thoughts?
                  • Caleb
                    Smokin IC's
                    • Feb 2013
                    • 645
                    even though the pic you posted isnt very clear it does appear that there is a fuse just to the left of the main connector under that gold rectangle. the power board on these should sell pretty quick as they are the most common failure
                    • PNI E.
                      tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                      by PNI E.
                      hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                      02-20-2025, 08:36 AM
                    • koby058
                      vostro comes up with back light but no picture
                      by koby058
                      Hi people!!
                      The owner said it showed bad picture once in a while (attached)
                      I see that there is back light but no picture.
                      I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                      Also attached schematic and BDV
                      LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                      07-13-2025, 01:03 PM
                    • dronerat
                      Samsung UE48JU6400W - back light on, sound on, sometimes picture.
                      by dronerat
                      Hi Guys,
                      This forum has been in great help to me, but I stumbled upon a strange problem with a salvaged Samsung TV that I am banging my head to troubleshoot.
                      PSU: L48S6 FHS BN44-00807D
                      T-Con: BN95-01937A
                      Panel: CY-GJ048HGLVLH
                      MB: NA (Currently as the TV is assembled and forgot to take picture)
                      As I said earlier I have some issues with the TV I got from a friend of mine. The TV had no picture, but sound, back light and everything else was working fine.
                      It was sent to an authorized service for repairs and returned with the...
                      05-15-2020, 08:03 AM
                      Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                      by sam_sam_sam
                      This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                      I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                      I am comparing them to a brand new one that I installed
                      The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                      I going to let it run for several days before I remount back on the wall next to the...
                      09-05-2024, 06:48 PM
                    • TR103
                      by TR103
                      - it keeps rebooting
                      01-22-2025, 04:12 PM
