Emerson LC320EM2 back lights on but no picture
  • Gorrillasnot
    • Dec 2013
    • 316
    I bought this TV for $20 at a rummage sale which I don't think is too bad if it's fixable.
    The symptoms are I can plug it in and I get a standby light. Press the power button and the led blinks several times then goes out. Then the back lights turn on (and stays on) but no picture is shown. I also get sound.
    I haven't had a chance to open it up yet, but I'm thinking its something in the inverter part of the board.
    I searched on here to see if anyone else had similar issues with this TV but all I found were posts with no power issues.
    any ideas?
    thanks
    Re: Emerson LC320EM2 back lights on but no picture
    If you do have backlights then inverter circuit is OK, inverter is for backlights to provide light source so you can see pictures on the LCD panel. It sounds to me that either the T-CON board is not getting the power from the main board, or SMD fuse on the T-CON board is blown, or the main board is not sending the signals to the T-CON.
      • 31014
      if it was the invertor, the backlight wouldnt stay on.
      maybe a psu problem - cant say until it's open.
      • Gorrillasnot
        • Dec 2013
        • 316
        I opened it up.
        looks like the power and inverter are on the same board and the main and t-con on the other board.
        No signs of obvious bad caps or burnt components.
        not sure what to do next.
          • 31014
          that's a clean layout.
          it could have done with a heatsink on the main chip though.
          did you check the connectors are in o.k. ?
          • Gorrillasnot
            • Dec 2013
            • 316
            I checked the cables and made sure all were firmly seated.
            Also on the PSU I checked all the jumpers with a voltage labeled next to them. There were 3 or 4 21v jumpers and they measured right on. and I found one 3.3v that was also right on.
              • 31014
              you see that board at the top-center,
              i suspect that has a second connector on it you cant see.
              the panel connectors are not on the edge - they are on the back.
              that board probably acts as an extension cable.
              • Gorrillasnot
                • Dec 2013
                • 316
                i don't see any other connectors just by looking but i also haven't disassembled the metal frame yet either.
                Do u think the issue is with the main/t-con combo board?
                thanks
                  OK, this LCD panel may have integrated T-CON or T-CON is integrated into the main board.
                  Can you see the LCD panel number sticker? I need it so I look up the spec sheet of this panel.
                  I can seven LVDS pairs on the main board.
                  http://www.shopjimmy.com/media/catal...001-dm-top.jpg
                  I cannot find the info for UK32MXK LCD panel.
                  • Gorrillasnot
                    • Dec 2013
                    • 316
                    I can only find one sticker on the back of the panel and if I'm reading it right I think it is P/N UK32BXA
                    • Gorrillasnot
                      • Dec 2013
                      • 316
                      If the t-con is integrated into that top board does that means the TV is likely not fixable?
                        That is correct. So far no info about this LCD panel UK32BXA.
                        • Gorrillasnot
                          • Dec 2013
                          • 316
                          ugh! that sux..was worth a gamble though I guess
                          • Caleb
                            Smokin IC's
                            • Feb 2013
                            • 645
                            That power board is worth at least 40$ on ebay. Its a bit of a hassle but it would get your money back
                            Liberating magic smoke one part at a time
                            • Gorrillasnot
                              • Dec 2013
                              • 316
                              yep that's what i was thinking. part it out and try to break even or maybe even make a couple bucks.
                              thanks everyone
                              • Gorrillasnot
                                • Dec 2013
                                • 316
                                I was tinkering some more with this TV and decided to take the metal frame off and get a look at the board that the LVDS cable attaches to.
                                There is what appears to be a voltage regulator at location IC5 in the pic.
                                It has 1117 written on it.
                                I tested it with the TV powered on and got the following readings 0.01, 0.04, and 0.72.
                                Does that sound like its ok?
                                Are there any fuses or other things I could check on this board?
                                thanks
                                  So it does have T-CON on the panel, the fuse is the SMD green fuse on the left of the connector (CN1) with 20 printed on top (F21? marking on the board). There is also small copper pad with 'VDD IN' for incoming voltage test point.
                                  • Gorrillasnot
                                    • Dec 2013
                                    • 316
                                    With power on it measures 0.29v on both ends of the fuse and at the VDD IN test point.
                                      This means the main A/V board is not turning the power on or the T-con is shorted. Try checking both ends of the fuse to chassis ground for shorts.
                                      • Gorrillasnot
                                        • Dec 2013
                                        • 316
                                        I'm still learning..To test the fuse would I set my DMM to ohm and then with TV unplugged test each end of the fuse?
                                        thanks
                                        • PNI E.
                                          tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                                          by PNI E.
                                          hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                                          02-20-2025, 08:36 AM
                                        • koby058
                                          vostro comes up with back light but no picture
                                          by koby058
                                          Hi people!!
                                          The owner said it showed bad picture once in a while (attached)
                                          I see that there is back light but no picture.
                                          I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                                          Also attached schematic and BDV
                                          LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                                          07-13-2025, 01:03 PM
                                        • dronerat
                                          Samsung UE48JU6400W - back light on, sound on, sometimes picture.
                                          by dronerat
                                          Hi Guys,
                                          This forum has been in great help to me, but I stumbled upon a strange problem with a salvaged Samsung TV that I am banging my head to troubleshoot.
                                          PSU: L48S6 FHS BN44-00807D
                                          T-Con: BN95-01937A
                                          Panel: CY-GJ048HGLVLH
                                          MB: NA (Currently as the TV is assembled and forgot to take picture)
                                          As I said earlier I have some issues with the TV I got from a friend of mine. The TV had no picture, but sound, back light and everything else was working fine.
                                          It was sent to an authorized service for repairs and returned with the...
                                          05-15-2020, 08:03 AM
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          by sam_sam_sam
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
