VIZIO V037L FHDTV20A powers up, backlight on, sound works, buttons work, no picture
  • vinceroger69
    • Mar 2012
    • 6714
    #61
    Re: VIZIO V037L FHDTV20A powers up, backlight on, sound works, buttons work, no pict
    too be honest as you have done all these tests now i would buy a replacement mainboard there a resonable price imo.
      OK, remove the connector J8 for the LVDS cable (where the cable is connected between the main board and the T-CON), then check the DC voltage on pin 30 (left most pin) of J8 to see what you have.
      • triplefour
        • May 2014
        • 1747
        happy to do more tests before spending any money or throwing anything away
        on the j8 connector of the mainboard i disconnected the lvds cable and tested pin 30 which read zero. pin 29, 28 and 27 were also zero... some other pins were 1.2 or 1.25
        but yea pin 30 is definitely zero.
        what does that tell us?
        Don't fear the repair...
        • triplefour
          • May 2014
          • 1747
          also how do you know its called J8? do u have a decent service manual for this board? i cant find schematics for it, and it doesnt say J8 anywhere near the connector...
          • triplefour
            • May 2014
            • 1747
            oh wait it does say j8 on it but i could only see that after removing the cable. still my first question remains, how did u know its J8?
              "how did u know its J8" from looking at the board and know what the connector should be going by the pictures, work on lots of electronics for 40 years.
              Since you are getting a little voltage, it means the switched MOSFET that is turned by the main board to allow the 12V to be fed to the T-CON board may be bad or it is being driven correctly.
              Right now I really need good clear pictures around pin 30 to see where the trace goes to, I can see it is connected to the Ferrite bead, another end of the Ferrite bead goes some where that I cannot see.
              These are some of the pictures of what I work on for fun and knowledge.
              http://s807.photobucket.com/user/bud...?sort=3&page=1
              • triplefour
                • May 2014
                • 1747
                lol nice kitty! u got me i was expecting to see some crazy electronics!
                  On the left pane you will see the list of make and models: for example
                  • triplefour
                    • May 2014
                    • 1747
                    ok heres the pics. lemme know if i didnt quite capture the mood, ill take some more.
                      OK, I think I see that switched MOSFET now, it is the u29 (8-pin device).
                      Please read the P/N as printed on top of that MOSFET.
                      • triplefour
                        • May 2014
                        • 1747
                        oh cool i see youve fixed a lot of vizios. i imagine cause theyre cheap they break a lot? it must feel good to know youve saved so many things from going to the dump. and teaching other people how to do the same! how many TV's have you repaired yourself, and how many have been repaired with your help on this forum?
                          Probably in the 1000's, I have been fixing them when they were using tubes!
                          • triplefour
                            • May 2014
                            • 1747
                            oh man the lettering is so small i couldnt even read it clearly with a magnifying glass. i had to use my cameras soom feature and the magnifying glass and i can just start to be able to read it but im still unclear on a few numbers
                            mx 12G or mx 120?
                            25L32050?2I
                            • triplefour
                              • May 2014
                              • 1747
                              ok i used my friends phone to get a better picture...apparently his camera beats mine by quite some margin.
                              u can clearly read the numbers now
                              • triplefour
                                • May 2014
                                • 1747
                                Mx-12g
                                25l3205dm2i
                                3a512200
                                taiwan
                                ??0736
                                • triplefour
                                  • May 2014
                                  • 1747
                                  cant seem to find the datasheet for this ....
                                  • triplefour
                                    • May 2014
                                    • 1747
                                    am i looking for a datasheet for a mx-12g?
                                    or for 25l3205dm2i?
                                    or do i have to search for both?
                                      OK, just to be sure, check the resistance between the positive leg of that lytic cap CE65 (the positive leg of this cap is connected to pin 30 of J8 through the Ferrite beads) and the top left pin of the IC. From the way it is connected looking at the traces to this IC, it may be the one for supplying the voltage to the T-CON, seems to be some kind of memory chip.
                                      • triplefour
                                        • May 2014
                                        • 1747
                                        with the multimeter in the 1000's range it reads 797 ... i took this reading with the power off. should it have been on?
                                          No, TV should be unplugged. So it does not have direct connection from pin 30 of J8 to that IC. Then we need to locate that MOSFET, it should be close to that J8 pin 30. Right now I am not seeing it.
                                          BTW, any time when you do resistance testing, what ever you work on should have power removed. You will have power applied when you do the voltage testing.
                                          • csmith
                                            Vizio D50u-D1 Powers up no picture
                                            by csmith
                                            I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                                            Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                                            supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                                            issue. Set will power up with remote but not power off....
                                            07-11-2025, 11:52 AM
                                          • JaquesPratt
                                            Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                            by JaquesPratt
                                            I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                            This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                            07-16-2024, 01:04 AM
                                          • npolite
                                            Vizio E320-A1 Powers on But No Display
                                            by npolite
                                            Hi All,
                                            I have a Vizio E320-A1 which lost sound and picture. The power LED comes on and stays on but nothing else works. I am not able to power it off unless I unplug it.
                                            Here are the voltages when the power is on
                                            1 - 5.25
                                            2 - 5.25
                                            3 - 0
                                            4 - 4.8
                                            5 - 25
                                            6 - 25
                                            7 - 0
                                            8 - 0
                                            9 - 0
                                            10 - 12
                                            11 - 12
                                            12 - .9
                                            13 - .5
                                            Can someone let me know if the issue is with the mainboard?
                                            Thanks...
                                            04-19-2024, 11:33 AM
                                          • ossroy
                                            Vizio M60-C3 powers on, perfect logo, turns off
                                            by ossroy
                                            Vizio M60-C3 powers on, perfect logo, turns off. If you don't touch anything it will repeat this process by itself until it is unplugged. Not the "button board" since I disconnected the cables to the main board and the problem persisted. So I'm fairly positive something is going on with the main board, but want to know if there is a fix for this other than replacing the expensive mainboard, which may eventually have the same problem. Also, heat sink was hot as hell when this all started. Unplugged for a few days and same thing happens.
                                            My kids are getting antsy waiting...
                                            08-03-2022, 08:11 PM
