Picture 'Hanging' high contrast
  • Yingus
    • Apr 2014
    • 12
    • England
    Hi, I have a 32 inch Sony LCD and recently the picture has seemed a little too bright on light scenes and a little too dark on dark scenes, Also if a still picture or text has been on the screen for a few seconds then you can still see it if you change channel. I am posting a picture with the fault. I have looked around but can't find much info but i assume it will be there TCON/LVDS board or the panel at fault, any info would be very much appreciated, Thank you.
    Ignore the wavy lines, That's just the camera picking them up.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Picture 'Hanging' high contrast
    Tcon most definitely. One of the voltages required to drive the panel (most likely VGH or VGL) has gone missing.
    A working TV? How boring!
      Show us the pictures of the T-CON board.
      • Yingus
        • Apr 2014
        • 12
        • England
        Got almost all of the board on the picture, Hope this helps.
        • Shinju
          • Mar 2014
          • 1239
          Seems to but cut off on the sides, is that the whole board?
            Check those test points VGMA 1~XX DC voltages.
            • Yingus
              • Apr 2014
              • 12
              • England
              I'm assuming you mean the VGAMA points on the top right of the picture.
              @Shinju there's hardly anything else to see at the sides so thought i would just get a closer look at the board instead.
              • Yingus
                • Apr 2014
                • 12
                • England
                Top left i meant...
                  Yes.
                  • Yingus
                    • Apr 2014
                    • 12
                    • England
                    OK, The readings are:
                    1 - 4.69
                    2 - 4.84
                    6 - 6.98
                    9 - 7.56
                    11 - 8.16
                    12 - 6.21
                    14 - 7.09
                    17 - 4.20
                    22 - 0.34
                    Hope that helps.
                      It is bad, another AS15 fault...!
                      • Yingus
                        • Apr 2014
                        • 12
                        • England
                        Thank you kindly for all the comments, Although i already know a little bit about electronics and i love to tinker i have only just started to mess with Tv's so it's very much appreciated of you guys.
                        • Tr0ll
                          by Tr0ll
                          Original T-con:
                          First replacement T-con:
                          10-07-2023, 07:48 PM
                        • JJAAMM
                          by JJAAMM
                          Problem
                          07-06-2023, 06:01 AM
                        • cloo
                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                          by cloo
                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                          After doing a factory reset this problem was gone and the picture was back to...
                          01-06-2025, 06:02 AM
                        • TR103
                          by TR103
                          - it keeps rebooting
                          01-22-2025, 04:12 PM
                        • MikeRWK
                          Sharp LC-32D40U Negative picture unless the contrast is almost 0
                          by MikeRWK
                          This only affects the picture but not the tv menus. Selecting any of the default picture settings gives a negative picture but turning the contrast down to 5 'fixes' it but then the tv is too dim which is hard to tell in the pictures.
                          This tv has a main board, scaler board, and a tcon.
                          I tore it down so I could probe the tcon which is nicely labelled. I've also included a pic of it.Here are the voltages I got:
                          VGH 32V
                          VGL -6V
                          GAM1 14.6V
                          GAM18 185mV
                          VLS 14.67V
                          3V 3.01V
                          RESET 2.95V
                          TCLK 0V
                          SCC_VDD...
                          01-30-2021, 05:21 PM
