Picture 'Hanging' high contrast
    Hi, I have a 32 inch Sony LCD and recently the picture has seemed a little too bright on light scenes and a little too dark on dark scenes, Also if a still picture or text has been on the screen for a few seconds then you can still see it if you change channel. I am posting a picture with the fault. I have looked around but can't find much info but i assume it will be there TCON/LVDS board or the panel at fault, any info would be very much appreciated, Thank you.
    Ignore the wavy lines, That's just the camera picking them up.
    Re: Picture 'Hanging' high contrast
    Tcon most definitely. One of the voltages required to drive the panel (most likely VGH or VGL) has gone missing.
    A working TV? How boring!
      Show us the pictures of the T-CON board.
        Got almost all of the board on the picture, Hope this helps.
          Seems to but cut off on the sides, is that the whole board?
            Check those test points VGMA 1~XX DC voltages.
              I'm assuming you mean the VGAMA points on the top right of the picture.
              @Shinju there's hardly anything else to see at the sides so thought i would just get a closer look at the board instead.
                Top left i meant...
                  Yes.
                    OK, The readings are:
                    1 - 4.69
                    2 - 4.84
                    6 - 6.98
                    9 - 7.56
                    11 - 8.16
                    12 - 6.21
                    14 - 7.09
                    17 - 4.20
                    22 - 0.34
                    Hope that helps.
                      It is bad, another AS15 fault...!
                        Thank you kindly for all the comments, Although i already know a little bit about electronics and i love to tinker i have only just started to mess with Tv's so it's very much appreciated of you guys.
