Sony Bravia KDL-46EX640 no power
  • bullwinkle
    • May 2009
    • 107
    Re: Sony Bravia KDL-46EX640 no power
    Update:
    bought a t-con board from shop jimmy but the result is the same.
    • bullwinkle
      • May 2009
      • 107
      as a summary for this specific problem of No power No standby problem:
      1.) Bought power supply board from Shop Jimmy, problem is still the same.
      2.) Bought Mainboard from another vendor though not brand new, the result is Power is
      now OK as well as the standby voltage is now present. The "only" problem is the
      that there are some "green lines" appearing on the screen. Please refer photos
      posted. This Mainboard is actually from the 55" model of this TV series. Second, I
      cannot change some parameters even following the manual on how to change some
      parameters.
      3.) Bought and LVDS cable from another vendor (another pullout from the same tv model)
      Result is still the same.
      4.) Bought T-Con board from another vendor (still another pullout), same result.
      5.) Not yet convinced, bought another T-Con Board from Shop Jimmy, same result.
      • bullwinkle
        • May 2009
        • 107
        Originally posted by tom66
        That can cause problems, Sony TVs are notoriously picky about the panel size requirement. You need to use 46" board.
        @ tom66: I am now considering your suggestion.
        • tibimakai
          • Jan 2012
          • 3680
          Did you manage to clear that Main Power error?
          Some electronics, return to normal operation after clearing a previous error code.
          • bullwinkle
            • May 2009
            • 107
            as stated, i want to try to change some parameters at the service menu section but problem is it wont save the settings. it will revert back to its original settings everytime. any other suggestions?
            • bullwinkle
              • May 2009
              • 107
              any suggestions?
              • tibimakai
                • Jan 2012
                • 3680
                Ask shopjimmy how to update the firmware on this board.
                You should probably open up the firmware somehow and edit the version of the firmware.
                • holmzy
                  • Nov 2009
                  • 99
                  #88
                  your not saving changes. read the repair manual
                  • Freko
                    • Jan 2016
                    #89
                    This is the Only Sony KDL post I can find.Sorry if I posted in the wrong place.
                    My Sony KDL-37EX403 LCD tv,won"t switch on anymore.When pluged in the power socket the Green light comes on for 2 seconds and then goes off and the Standby light comes on then Blinks for 7 times,if I press the power on on remote or side of tv the standby light blinks 3 times then pauses and repeats 3 blinks.
                    I dont know anything about tv"s but would be willing to repair the board if there is a KIT for my model.
                    Any Help would be great.
                      • 12322
                      • U.S.
                      #90
                      7 red flashes- main board over heating, can be short on power board or main logic board, maybe blow out any dust if you haven't already.
                        • 12322
                        • U.S.
                        #91
                        3 red flashes is bad main logic or power board, check for standby volts if ok replace main logic board.
                          • 12322
                          • U.S.
                          #92
                          As always be very careful when working on primary side of power supply, it can be deadly.
                            • 12322
                            • U.S.
                            #93
                            http://www.ustvparts.com/apps/websto...utf8=%E2%9C%93 one there for 95 bucks, maybe one of the members here has one for sale, didn't see too many.
                            • PopsCaps
                              Sony Bravia KDL-40V2500 that will not power on
                              by PopsCaps
                              I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                              I do not hear any sound and I cannot see any backlight.
                              I have tried disconnecting every cable on each board one at a time to see if anything changes.
                              The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                              My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                              03-25-2025, 11:23 AM
                            • PantherDave
                              by PantherDave
                              Hi all!
                              05-29-2024, 02:01 PM
                            • GLISIT
                              by GLISIT
                              01-16-2025, 02:29 PM
                            • alegatorul
                              sony bravia kdl-43w756c, no power, no sound
                              by alegatorul
                              the charger brick has 19,2-19,3 vcc
                              changed the inverter board same result.
                              where should i start?
                              cheers
                              11-15-2025, 10:00 AM
