LG 42PJ350 Starts, Shuts down, won't restart
  • marty-clubber
    • Oct 2014
    • 58
    • u k
    Re: LG 42PJ350 Starts, Shuts down, won't restart
    Hi repair kit power supply LG 42PJ350
    r927 22ohm resistor
    r929 22ohm resistor
    ic301 3br1565jf regulator
    d304 diode
    easy repair thought was the fault on mine but ended up been ysus board there no repair kit.
    • dkneyle
      • Dec 2013
      • 445
      Probably worth changing over D304 just to eliminate that possibility. I wonder what type it is? Be aware that they are almost always fast-switching types. (I made the mistake once of replacing with a general purpose power diode - big mistake.)
      I too was starting to wonder if it was something off board that was causing a shut-down?
      I have the Training Manual for this model but it's about 16MB. I suppose I could post it to DropBox or something? PM if you like and we'll see how we could do that. It has good instructions for how to test the power supply for operation. You could load up the power supply without the other boards attached to it and see if it stays up and running or if it powers down after 40 minutes. Then you know whether you have a power supply fault or something else.
      • Amraks
        • Nov 2011
        • 725
        hey dkneyle I will send you a PM you can email 16mb file ill upload it to my free webspace that comes with my internet.
        • Amraks
          • Nov 2011
          • 725
          Here is the training manual thanks to dkneyle for providing it.
          • Amraks
            • Nov 2011
            • 725
            Today the tv has been running along time.
            I think it was a dry joint on the new regulator causing the issue, it had a blob on the outward most leg on topside of board must of applied to much solder.
            Will soak it all day tomorrow with Back Cover on.
            fingers crossed.
            • Amraks
              • Nov 2011
              • 725
              Yup tv is repaired, Soaked it all day today with back on.
              I figured out the screws were not grounded the other day as there was a loose screw when I was checking stuff.
              • 51k.bos
                The New Girl
                • Apr 2015
                • 4
                • usa
                #27
                HI, I know this is an old thread, but since it isn't closed I thought I would try here before creating a new one.
                I also have an LG 42PJ350 that is exhibiting the same symptoms, albeit slightly different. My particular tv will sometimes run for only 20-30 minutes, other times running for 3+ hours before cutting off, and then doing the clicking thing when trying to restart it. I have let it sit for days, only to get maybe 20 min of run time without it coming on until the next day. But then sometimes I've only let it sit for an hour or so and have gotten 3+ hours of run time. There doesn't seem to be any rhyme or reason to it either. It's not a progressive thing because it goes back and forth from running for a short to long time intermittently.
                From the posts that I've read, I'm seeing that replacing 3br1565jf might fix the problem. I wasn't sure , however if the disparity in run times was perhaps a different issue all together or something else in addition to replacing that part. I thank you in advance for your time and assistance.
                • dkneyle
                  • Dec 2013
                  • 445
                  You know, those regulators are so cheap I don't think you have anything to lose by swapping it out. I wonder if there might be a dry joint around that reg IC? It certainly seems to be a heat sensitive fault. Maybe in the first instance hit it with a hot iron. While you're at it just heat up any other joints associated with large current carrying components. Let us know the outcome.
                  • 51k.bos
                    The New Girl
                    • Apr 2015
                    • 4
                    • usa
                    #29
                    Which would be easier for a non technician do it yourselfer? Replacing with the parts kit or replacing the faulty board?
                    • dkneyle
                      • Dec 2013
                      • 445
                      Well, you'd need reasonable soldering skills and a solder sucker. If you aren't experienced in soldering then you'd likely get yourself into trouble. So if you could pick up a replacement board at a good price then it's a fairly straight forward process to unplug the leads and swap boards over.
                      • newtothis
                        • Mar 2013
                        • 1556
                        • england
                        #31
                        Soldering isn't that hard, As long as you have an iron and some solder its easy enough to swap components out.
                        *** Totally opposite view to the post above me, My Mrs can swap components in and out... Even fashioned a solder sucker ourselves when I was first learning. I am sure if she can do it with no experience then you can ***
                        If you want to know how we did a solder sucker... Ever seen those bug catchers.. Its a jar with 2 pipes going into it... One longer than the other inside the jar... Suck one end and aim the other pipe at a bug and it sucks it in. Due to the one pipe being higher than the other in the jar it just traps it. Works the same with solder. Only requires a quick sharp intake of air to suck up solder in a thin pipe... you won't inhale enough to get any fumes near your lungs so don't worry about that
                        • 51k.bos
                          The New Girl
                          • Apr 2015
                          • 4
                          • usa
                          #32
                          I do have experience soldering jewelery, glass and other artsy things but have never done anything like this. I found replacement boards on eBay for not much more than the kit... so I think I'll play it safe and opt for that route. .. Now To make sure I replace the correct board, I should do the freeze test correct?
                          Now I downloaded the training manual and granted it doesn't all look like Greek to me, but some of it is over my pay grade... Should I test all the boards? I really appreciate your help!
                          • dkneyle
                            • Dec 2013
                            • 445
                            The power supply board is the one that the mains lead connects to.
                            • Mikeyboy2007
                              • Mar 2013
                              • 745
                              • Scotland
                              #34
                              i have LG 42PJ350 with same issue someone has asked me to look at. did we find a repair for this ?
                              • dkneyle
                                • Dec 2013
                                • 445
                                Yeah the regulator chip on power supply. Might be as simple as dry joints I suspect on reflection. Hit those solder pads with a hot iron first. Let us know how you go.
                                • Mikeyboy2007
                                  • Mar 2013
                                  • 745
                                  • Scotland
                                  #36
                                  where is the regulator chip on the psu ?
                                  • Mikeyboy2007
                                    • Mar 2013
                                    • 745
                                    • Scotland
                                    #37
                                    also i checked all diodes on board and diode D304 gives 001 reading both ways, is this a bad diode ?
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      #38
                                      remove or lift one side of the diode and re check.
                                      have you checked all these parts as in a previous post do they check ok
                                      r927 22ohm resistor
                                      r929 22ohm resistor
                                      d304 diode
                                      • Mikeyboy2007
                                        • Mar 2013
                                        • 745
                                        • Scotland
                                        #39
                                        will check those and post back, also can you tell me which is the regulator chip on the psu ?
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          #40
                                          ic301 i would guess not sure where on your board it is but as a guess it will be on a heat sink if you cant find it maybe look in the training manual in this thread or post a good clear picture of your board.
                                          • chaos-theory
                                            Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                            by chaos-theory
                                            I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                            Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                            03-14-2025, 05:37 PM
                                          • Shobos
                                            Dell E6420 XFR Rugged starts to boot but after 3 secs shuts down.
                                            by Shobos
                                            Hi, I bought 6420 XFR that tries to boot but shuts down after about 3 seconds, CPU gets warm, fan starts.
                                            So far I have tested all rails wich are good, BIOS flashed with CH341, 3.3,5, main rail present. multiple ram sticks tested. Sometimes it might stay on for longer like 4-5 seconds but not always, theres no picture whatsoever. Also on some rare occasions the caps lock flashes 1 time by itself.
                                            NOTE: I am using bench power supply not dell charger with ID pin and NO battery present, kinda doubtful this would cause this issue.
                                            Any help is welcome. Thanks !
                                            07-29-2025, 03:53 PM
                                          • PowerAmpFreak
                                            LG OLED 65B7V starts with green screen a few seconds then shuts down
                                            by PowerAmpFreak
                                            LG OLED model 65B7V starts up with green screen for a few seconds then shuts down.
                                            Can this be a sign of shorted ceramic caps in the T-con ?
                                            Best,
                                            10-07-2022, 10:27 AM
                                          • Christian0734
                                            Power Issue with ASUS A705UA.
                                            by Christian0734
                                            Hello
                                            The PC starts and shuts down correctly when the battery is removed. However, if I hot-plug the battery, it starts charging as if everything is normal. However, when I turn off the computer and then restart it, there is no display on the screen. The battery indicator blinks slowly, the fan runs, and the power consumption is approximately 520 mA, as if the computer is in standby mode. At this point, even if I disconnect the power supply, the computer doesn't start up normally anymore. Pressing the power button to force a shutdown works, but as soon as I release the button, the...
                                            09-13-2023, 03:04 PM
                                          • shouri
                                            Dell latitude e5490 auto restart
                                            by shouri
                                            Hi guys, can someone help me?
                                            I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
                                            Board model is dm70 la-f401p rev:1.0 2017-09-20.
                                            At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
                                            After a few days test, is seems ok.
                                            Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
                                            12-10-2024, 09:27 PM
