LG 42PJ350 Starts, Shuts down, won't restart
  • cmagavilano
    • Apr 2019
    • 6
    • peru
    #61
    Re: LG 42PJ350 Starts, Shuts down, won't restart
    sobre el 42pj350 deberias cambiar r614 al r617 de 220k al 1% y r108 al r111 de 680k al 1% r112 620k r113 560k t0das al 1% dbes sacar el esmalte debajo de cada resitencia
    • chaos-theory
      Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
      by chaos-theory
      I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
      Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
      03-14-2025, 05:37 PM
    • PowerAmpFreak
      LG OLED 65B7V starts with green screen a few seconds then shuts down
      by PowerAmpFreak
      LG OLED model 65B7V starts up with green screen for a few seconds then shuts down.
      Can this be a sign of shorted ceramic caps in the T-con ?
      Best,
      10-07-2022, 10:27 AM
    • Christian0734
      Power Issue with ASUS A705UA.
      by Christian0734
      Hello
      The PC starts and shuts down correctly when the battery is removed. However, if I hot-plug the battery, it starts charging as if everything is normal. However, when I turn off the computer and then restart it, there is no display on the screen. The battery indicator blinks slowly, the fan runs, and the power consumption is approximately 520 mA, as if the computer is in standby mode. At this point, even if I disconnect the power supply, the computer doesn't start up normally anymore. Pressing the power button to force a shutdown works, but as soon as I release the button, the...
      09-13-2023, 03:04 PM
    • shouri
      Dell latitude e5490 auto restart
      by shouri
      Hi guys, can someone help me?
      I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
      Board model is dm70 la-f401p rev:1.0 2017-09-20.
      At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
      After a few days test, is seems ok.
      Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
      12-10-2024, 09:27 PM
    • pfrcom
      Asus P8Z68-V/Gen3, after saving UEFI settings, shuts down, doesn't restart
      by pfrcom
      I've tried all BIOSes available to download, most recently first release version 0301, using an i3-2100
      For each try, after externally reprogramming its Winbond 25Q64BV (DIP8) with TL866IIplus
      Always same outcome - after Save & Exit, board shuts down and doesn't restart
      If I press onboard Power button, it'll start up then shut down again
      After jumpering CMOS Clear, it'll start to UEFI settings then repeat same behaviour
      It's had a new CR2032 fitted
      Closer examination found a second flash IC, a soldered...
      07-29-2021, 02:46 AM
