Power Issue with ASUS A705UA.
  • Christian0734
    • Nov 2020
    • 92
    • France
    Hello
    The PC starts and shuts down correctly when the battery is removed. However, if I hot-plug the battery, it starts charging as if everything is normal. However, when I turn off the computer and then restart it, there is no display on the screen. The battery indicator blinks slowly, the fan runs, and the power consumption is approximately 520 mA, as if the computer is in standby mode. At this point, even if I disconnect the power supply, the computer doesn't start up normally anymore. Pressing the power button to force a shutdown works, but as soon as I release the button, the computer instantly tries to restart but remains stuck at the same stage as before. The only way to restart it is to disconnect the battery to completely power it off, then plug in the charger. Without touching the power button, it starts automatically and normally, and I can shut it down and restart it without any issues as long as I don't reconnect the battery.
    Note that without the battery, Windows 11 indicates that the battery is fully charged at 100%, even though it's absent. It's also worth noting that this problem doesn't seem to affect restarts because I performed a complete installation of Windows 11 with all updates, requiring multiple restarts with both the battery and power supply connected, without encountering any issues. However, at some point, when I turned off the computer, it failed to restart completely, as I described earlier. I had to disconnect the battery. Furthermore, when the computer is running, if I reconnect the battery while it's on, the computer restarts without any problems. But if I shut it down at this point, it doesn't work. If, at this stage, I disconnect the connector, nothing changes. However, if I disconnect the battery, even without reconnecting the power supply, and then reconnect the battery, the PC starts without any issues on the battery, and this can be done as many times as desired.
    For your information, a colleague has already replaced the battery with a new one, but it didn't solve the problem I described. When he arrived in the workshop, I tested the computer with a fresh installation of Windows 10 and later with a fresh installation of Windows 11. I also attempted to downgrade the UEFI, but so far, EZflash consistently indicates that the file is not compliant, regardless of the version I obtain from the ASUS website. I'm not sure which direction to pursue for a solution...
  • Christian0734
    • Nov 2020
    • 92
    • France
    Re: Power Issue with ASUS A705UA.
    Another discovery, I just turned it off while it was running solely on battery. I plug in the power supply and start it up; it starts up just fine. Now, I've started and stopped it 5 times without any issues with both the battery and the power supply connected! In fact, I believe it's completely random, and when the problem occurs, once in I don't know how many times, we have to disconnect the battery to make it work again.
    • mon2
      • Dec 2019
      • 14634
      Review the sticky thread by @Piernov on chargers. Often it is the 2nd DC-in mosfet that becomes defective (leaky) and will raise errors like yours.
      Being Asus, you most likely do not have the schematics? If you do, post or link them in the schematic forum only (not here).
      Otherwise, proceed to review the DC in adapter connector and nearby will be the 2 * DCin mosfets (8 pin) and the charger IC. We need full details on the topside markings of these parts. Then can start the review with a multimeter.
      • Christian0734
        • Nov 2020
        • 92
        • France
        Hello
        As a preliminary note, I must say that I performed about ten startups with both the battery and the power supply connected, and this time I didn't encounter any issues! Nevertheless, I removed the motherboard for an inspection. I'm having trouble locating the two MOSFETs in the main power line because right after the connector, the line goes elsewhere through the board via VIA and doesn't directly come out on the other side of the PCB. However, during the visual inspection, I discovered a melted capacitor. It's not short-circuited, and I tested the two MOSFETs right next to it. The drain of the first one is grounded, which seems normal to m, I believe it's a Buck converter. However, I'm getting an open loop (OL) reading between the drain, gate, and source on both MOSFETs...
        • Christian0734
          • Nov 2020
          • 92
          • France
          Here is the voltage reading when the board is operating normally. During these readings, the board displays the BIOS on a screen via the HDMI port, and the board's power consumption is around 0.350 A. If I cut off the board's power and turn it back on, the consumption remains around 0.350 A, without needing to press the power button. Just turning the lab power supply to 'on' is enough. However, the BIOS display doesn't always appear. I have to disconnect and reconnect 2 to 3 times for the BIOS to show up, otherwise it's a black screen. (Core-i3 7100U operating at 58° with the heatpipe but without the fan connected.)
          • mkdj
            ASUS X571 no power : battery issue?
            by mkdj
            Mark and model: ASUS X571
            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
            Tests already made:
            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
            - I have removed...
            07-14-2025, 09:16 AM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • rob777
            Asus TUF won’t run off battery
            by rob777
            I have an Asus TUF machine that doesn't run off battery. Runs off charger ok, shows orange battery charging light and shows battery is at 96%. Battery voltage is less than 0.5v though. It had a short on the 20v rail from a dead cap. Pic attached. Removed cap and replaced a dc in mosfet. Machine now powers and runs fine.
            I have also replaced all 3 battery mosfets with no change. The 1st battery mosfet has 20v going in. Pic attached.
            Does it sound like a battery ic problem, it has bq2470. Not sure if I should replace that as well at this stage as I'd need to order one.
            Thanks....
            05-27-2025, 07:07 PM
          • Iherduleikgemz
            Asus FX505DY - Battery not charging - BQ24780S
            by Iherduleikgemz
            Hello everyone
            I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
            I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
            01-13-2025, 03:54 PM
          • cope
            Battery not charging in ASUS G532LWS Motherboard -> BQ24780S
            by cope
            I have been working on a no power issue with my personal ASUS gaming laptop. It went dead a few months ago.
            Some history:
            Since then, I've found a blown mosfet on the GPU line which I replaced. It started up without a battery, then when I added the battery back it wouldn't start up again.
            As a result, there were some blown components around the BQ chip. (The BQ chip itself - BQ24780S, the low side battery mosfet (shorted), and a resistor -> all replaced)
            Now, with a new battery the system will start up and run off...
            05-13-2024, 09:40 AM
