LG 42PJ350 Starts, Shuts down, won't restart
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    #41
    Re: LG 42PJ350 Starts, Shuts down, won't restart
    i found it right after posting that, how do i test this though ? the r927 22ohm resistor
    & r929 22ohm resistor are testing ok at 22.3 and i will need to remove a leg from diode D304 to test that but never tested a voltage regulator before ?
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      #42
      neither have i maybe tom or budm maybe able to advise? can you find a data sheet for it and post a link in advance to be honest if its a cheap part just replace it.
      Now you have found the regulator try resoldering all the joints even if they look good and test the set you have nothing to loose check that diode first though.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        #43
        http://www.ebay.co.uk/itm/ICE3BR1565...item1e967ea16a
        There not a bad price maybe also check rs components as they have free postage offer on now.
        • dkneyle
          • Dec 2013
          • 445
          I think you've worked out that the regulator is the 6 legged device. Can't really be tested. Yes you can pick them up from Taiwan via E-Bay for next to nothing. You replace it and see if things get better!
          • Mikeyboy2007
            • Mar 2013
            • 745
            • Scotland
            #45
            hi guys i put fresh solder round the legs of the voltage regulator and tv has now been on for around 2 hours. think it may just have been a dry solder joint then.
            • dkneyle
              • Dec 2013
              • 445
              Yes, if I had my time over again with the set I fixed I think this would be what I'd go to first. Think about it. This device gets hot; that's why it's on a heatsink. It gets hot enough that the solder melts away from the solder pad. Classic dry joint problem. Hit it with a hot iron and a fresh bit of solder and bingo, fixed!
              • ryanfan03
                • Apr 2014
                • 45
                I have the same tv in my TO-DO pile. The guy I got it from tried the power board repair (crudely I might add) but that didnt work. I traced the problem to the Y SUS board and a few components including a transistor and a resistor. I havent had time lately to replace or check further. Anyone else have a similar experience?
                Doing this on the side to make some extra money for my daughters dance competition.
                • Mikeyboy2007
                  • Mar 2013
                  • 745
                  • Scotland
                  #48
                  Ok so tv stayed on for 8 hours or so then i decided to turn it off... i left it for 3 hours then switched back on and after a few minutes it shut itself off and when trying to startup it went through the clicking crap.... i am going to change the voltage regulator and see if that helps any.
                  • odheng77
                    • Jun 2015
                    • indonesian
                    #49
                    hi .. I am from Indonesia ..
                    I also have a lg tv 42pj350 and suffered the same damage . he does not want to start . only the standby LED lights are flashing .
                    whether the same damage lies in 3BR1565JF ?
                    • Mikeyboy2007
                      • Mar 2013
                      • 745
                      • Scotland
                      #50
                      i changed the voltage regulator 3BR1565JF and it worked for a few days there but now its back to square one ? could something be knocking this out ? any help is welcomed
                      • dkneyle
                        • Dec 2013
                        • 445
                        check that any fast switching diodes used as dampners are ok
                        • Amraks
                          • Nov 2011
                          • 725
                          Back Again
                          Tv Was running fine, now its doing it again just now.
                          I suspect the chip has gone again will order 2 this time.
                          • dkneyle
                            • Dec 2013
                            • 445
                            Tell us if replacing the chip gets you in business again. It does seem like the regulating chip is working too hard or something else causes them to fail. Have a good look at the diodes that are used to snub out high frequency oscillations and the such like.
                            • Amraks
                              • Nov 2011
                              • 725
                              Hey back again I manage to get 3 - 4 hours out of the set before it starts the cycle of clicking on and off.
                              I have replaced the voltage regulatory also run individual wires to test that its not cold solder joints.
                              I am suspecting the 5w22O Resistors are bad this time, I will let you know what I come up with.
                              • lesnajair
                                • May 2015
                                • 57
                                #55
                                These blooming PJ series!! I've got a PJ650 and it has the same issue. Replaced the voltage IC managed to get the red led to go blue, LG logo and a channel id logo then went straight back to square one clicking etc. with red slow flashing red led. Grrr! Managed to get a new psu board but worried it might get fried!!
                                • dkneyle
                                  • Dec 2013
                                  • 445
                                  There certainly appears to be a design fault that is causing the power IC to overload and fail. I don't have the board any longer to look at so I don't know what more advice to give. Those power resistors are known to be problematic in other SMPS. What value do they measure? Do they look physically stressed?
                                  • Amraks
                                    • Nov 2011
                                    • 725
                                    22.04 to 22.05 even the new resistors tested the same.
                                    Seems like the set got worse after sitting longer this time as it a instant failure.
                                    • Amraks
                                      • Nov 2011
                                      • 725
                                      You will be happy to know dkneyle after a few years I got around to working on this tv again and it working.
                                      6 resistors R08 - R13
                                      It is safe to bridge pc101 on the cold side to test the voltage drop on them resistors.
                                      you should see it straight away when you test voltage on individual resistors. I noticed it mainly on R110 it was lower than the others.
                                      • dkneyle
                                        • Dec 2013
                                        • 445
                                        G'Day Amtraks. Great to see a story finally resolved! (I too drift in and out of this hobby depending upon motivation.)
                                        • Amraks
                                          • Nov 2011
                                          • 725
                                          Its good its not taking up space now..
                                          now I got the 27 inch tv for the bedroom I was using while this one was down to get rid of lol
                                          I don't get many tv repairs coming in just a few screen replacement jobs and just bought a microscope for micro soldering hoping to do some ps4 port repairs instead of turning them down..
                                          if you still have this tv I can post you some of them resistors I got 15000 of them as I had to buy 3 reels lol.
                                          • chaos-theory
                                            Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                            by chaos-theory
                                            I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                            Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                            03-14-2025, 05:37 PM
                                          • Shobos
                                            Dell E6420 XFR Rugged starts to boot but after 3 secs shuts down.
                                            by Shobos
                                            Hi, I bought 6420 XFR that tries to boot but shuts down after about 3 seconds, CPU gets warm, fan starts.
                                            So far I have tested all rails wich are good, BIOS flashed with CH341, 3.3,5, main rail present. multiple ram sticks tested. Sometimes it might stay on for longer like 4-5 seconds but not always, theres no picture whatsoever. Also on some rare occasions the caps lock flashes 1 time by itself.
                                            NOTE: I am using bench power supply not dell charger with ID pin and NO battery present, kinda doubtful this would cause this issue.
                                            Any help is welcome. Thanks !
                                            07-29-2025, 03:53 PM
                                          • PowerAmpFreak
                                            LG OLED 65B7V starts with green screen a few seconds then shuts down
                                            by PowerAmpFreak
                                            LG OLED model 65B7V starts up with green screen for a few seconds then shuts down.
                                            Can this be a sign of shorted ceramic caps in the T-con ?
                                            Best,
                                            10-07-2022, 10:27 AM
                                          • Christian0734
                                            Power Issue with ASUS A705UA.
                                            by Christian0734
                                            Hello
                                            The PC starts and shuts down correctly when the battery is removed. However, if I hot-plug the battery, it starts charging as if everything is normal. However, when I turn off the computer and then restart it, there is no display on the screen. The battery indicator blinks slowly, the fan runs, and the power consumption is approximately 520 mA, as if the computer is in standby mode. At this point, even if I disconnect the power supply, the computer doesn't start up normally anymore. Pressing the power button to force a shutdown works, but as soon as I release the button, the...
                                            09-13-2023, 03:04 PM
                                          • shouri
                                            Dell latitude e5490 auto restart
                                            by shouri
                                            Hi guys, can someone help me?
                                            I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
                                            Board model is dm70 la-f401p rev:1.0 2017-09-20.
                                            At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
                                            After a few days test, is seems ok.
                                            Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
                                            12-10-2024, 09:27 PM
