How do i test these 3 leg ics on inverter?
  • mattstolte
    • Dec 2013
    • 612
    • usa
    I am wanting to know how to test these 3 leg ics on my inverters, i see they sell inverter repair kit but i need to know how to test them? I have a good meter i just dont know how to test them?
  • mattstolte
    • Dec 2013
    • 612
    • usa
    Re: How do i test these 3 leg ics on inverter?
    Originally posted by mattstolte
    i am wanting to know how to test these 3 leg ics on my inverters, i see they sell inverter repair kit but i need to know how to test them? I have a good meter i just dont know how to test them?
    sorry didnt mean to add that last picture
    • mattstolte
      • Dec 2013
      • 612
      • usa
      Anybody?
      • Glitcher
        • Mar 2013
        • 673
        • USa
        I assume you mean these circled? Just check if there is continuity between each pin for each. If you find continuity or low resistance, it is shorted and needs to be replaced.
        If they are in parallel and only one is shorted, it will show that they are all shorted, in that case you will have to lift up the pins and test them again.
          Those are MOSFETs, not ICs.
          • mattstolte
            • Dec 2013
            • 612
            • usa
            Can you tell me how to check them?
              Glitcher told you how...
              • mattstolte
                • Dec 2013
                • 612
                • usa
                Ok there's 1 flat pin on front and 3 on back but middle is only the half leg which isn't connected... so I put this in diode mode and do what's? Please be specific details, I am new and learning, thanks
                  The half leg & tab pin are electrically connected, this is fine. Only test the other pins.
                  • mattstolte
                    • Dec 2013
                    • 612
                    • usa
                    So I put this in diode mode? And I put what probes on which pins? And what am I lookn for that's bad?
                      Diode mode. All combinations of pins. Both ways. You're looking for zero or near zero. (<200)
                      • chth96
                        How Can I test PWM DM0365R?
                        by chth96
                        Hello
                        I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                        So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                        I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                        I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                        06-18-2025, 04:14 PM
                      • khelane
                        test active pfc power with lamp test
                        by khelane
                        Hello
                        I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                        Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                        Is there a way...
                        06-03-2025, 01:00 AM
                      • chronic519
                        Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                        by chronic519
                        Hello.
                        GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                        Found issue with a RAM block
                        Replaced, green lines gone.
                        Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                        Used a good card to test and same results low errors 32+.
                        I am just search for some form of command to do a full test on the GPU.
                        I just ran the mats command with my good GPU and passed after roughly 40 min.
                        The repaired one, ran...
                        05-20-2025, 07:56 PM
                      • alltvrepairs
                        Lg TCon test pins for screen test
                        by alltvrepairs
                        i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                        Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                        Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                        Appreciate your help....
                        06-13-2025, 06:33 AM
                      • vampy999
                        how to test lcd inverter transformer
                        by vampy999
                        i found this very helpful.
                        https://jestineyong.com/test-lcd-inverter-transformer/
                        02-28-2021, 07:52 PM
