emerson BA01P0F0103 3 transformer squeals
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Hello all,
    TV is a phillips 42pfl3505
    Power supply is a BA01P0F0103 3
    Problem: As soon as you plug in TV,a loud squeal/buzzing from transformer T601(see pic#2,I'm pointing my finger at it),the squeal starts kinda high in frequency and slowly frequency goes lower,as if it is grunting down to a halt.
    I proceeded and de-soldered T601 and measured the pins according to diagram in pic#4.
    Measuring the points on the board where T601 sits,non of the pins measures a short.
    Measuring the T601 I get the following values:
    pin 1-3=0.3ohm
    pin 5-6=0.3ohm
    pin 6-7=0.3ohm
    pin 5-7=0.4ohm
    At first glance,does that sound shorted to you?
    If so,where could a person buy one of these? (pic#3 has the numbers on it)
    p.s: I searched forum and could only find threads where fuse blew,with shorted diodes,mine fuse stays intact...
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: emerson BA01P0F0103 3 transformer squeals
    Originally posted by martino
    Hello all,
    pin 1-3=0.3ohm
    pin 5-6=0.3ohm
    pin 6-7=0.3ohm
    pin 5-7=0.4ohm
    Nope those resistances are normal, they are actually probably much lower than that, but most meters don't measure resistance much lower than that.
    It is quite rare for a smps transformer to fail. It is more likely for the backlight transformers to fail, since they operate at a higher voltage.
    That ticking/squealing sound is typical of an unstable SMPS (not regulating properly), which can be caused by a number of things. Bad capacitors, bad resistors, bad IC's and transistors, or bad opto-couplers just to name a few.
    Are there any parts on the bottom of the board around that area with the noisy transformer? If so, could you get us a pic or two of that?
    Muh-soggy-knee
    • R_J
      • 9551
      I would check for a shorted diode etc. in the secondary, sounds like something is loading down the power supply.
      • martino
        Not so "senior"
        • Aug 2013
        • 997
        • canada
        Took a couple of pics from the bottom side of board around the squealing coil..
        I also found this pdf that shows top and bottom in see through..I attached it,hope it shows up(don't know how to attach a pdf)
        I could use a bit of guide on where to start trouble shooting,been poking around a bit with my dmm but didn't find a obvious short.
        One guy told me once,that a squealing coil often means a badly driven coil,making me snooping around in the driver portion of the coil,any truth to that???
        I ordered a ESR meter,should be in any day now
        Hope these pics/pdf help.
        Am I correct in saying that pic3 shows the ACdetect circuit?
        • martino
          Not so "senior"
          • Aug 2013
          • 997
          • canada
          Gentleman we have a fix !!!!!
          On suggestion by R_J I poked around in the cold side and sure enough,I found a shorted diode!
          The diode is a FR104,I only had a FR103,looking at the spec's I believe them to be "close enough",am I correct or should i order a FR104???
          For anyone reading this post,having the same problem,it was diode 651,located very near transformer T601.It's in the 35volt rail.
          Thank you gentleman in your as always awesome assist
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Good job, however,
            Noooo!, use an FR104 or greater (FR105, FR106, FR107...)
            The FR103 is rated at a maximum reverse voltage of 200V, whereas the FR104 is rated at 400V. This could cause an early failure of the FR103 diode you put in there.
            Muh-soggy-knee
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              Nice job! I would also recommend replacing all the caps, as they are only rated for 85C
              • kca
                • Feb 2016
                • 529
                Hello martino ~
                Did replacing diode 651 fix your problem?
                Or, did it take that and something else in combination with that?
                I have the same transformer hissing problem on my Philips 46PFL370D/F7.
                ~ kca
                • martino
                  Not so "senior"
                  • Aug 2013
                  • 997
                  • canada
                  Nope, just that diode. Gave tv to brother in law and it still works fine today
                  • kca
                    • Feb 2016
                    • 529
                    That's good to know! Thank you for the reply.
                    Do you think any of these readings are out of line such that the diode(s) need be replaced?
                    I don't have a great deal of experience yet w/ diode readings/replacement, so any advice you can give would be most appreciated.
                    PHILIPS 46PFL3705D/F7
                    D651 = 565
                    D652 = 566
                    D656 = 253
                    D662 = 155
                    D665 = 525
                    D670 = 175
                    D672 = 193
                    D673 = 193
                    D674 = 193
                    The above readings were taken in Diode mode on a Craftsman DMM, and when I reverse the leads I get a reading of 1 on the left-hand side of the screen. There are no OL readings. Is this the best way to gather the readings?
                    Attached is a pic of the diodes currently in question near the transformer that is making the problematic squealing/hissing sound.
                    • kca
                      • Feb 2016
                      • 529
                      Also, I am wondering if you know if other boards in the set, if defective, can cause this type of squealing in the PSU transformer?
                      I ask because when I disconnect all of the cables leading out from the PSU, the tv no longer shuts down and there is no squealing. I only get a "silent" black screen. When I reconnected all of the cables and ribbons one by one, the squealing returns. I haven't done exhaustive testing of this as of yet, but one result is that everything could be plugged in EXCEPT the tuner board and it was still black screen silent. Then, when I made that last connection of tuner board to PSU via the small white ribbon, that's when the transformer would start its familiar squealing/humming again.
                      The same result, however, occurred when I left the tuner board connected up to the PSU and isolated the board above it (where the HDMI ports are). All black screen silent until I made that connection between this "HDMI port" board (sorry, can't think of its proper name at the moment), and the tuner board via two white ribbons. I think there are other combinations that would likely produce the same result.
                      So, my question is .... could it be that one or more than one of these other boards in the set is producing the squeal in the transformer, or is it the case that the squeal must be stopped at the PSU level itself and then the other boards are likely to function in their normal manner? It seems like both notions have merit.
                      • Shane711
                        • 493
                        I have noticed that D652 also causes the transformer to squeal. Also check D614. I have one that will not turn on, I am starting to suspect a bad resistor because I have no shorts on the board. I have been fixing about 3 of these power boards every week because I offer a repair service for it. But I have not experienced every possible problem yet. Soon I will be an expert on this board but it is stressful.
                        • kca
                          • Feb 2016
                          • 529
                          Thank you, Shane711 ~
                          I have put this particular set on the back burner because I could not get it to fire up back in the spring.
                          I will take a look at those two particular diodes you just pointed out. I agree that this set and its respective boards seems to be a little touchy and its hard to diagnose the exact source of the problem.
                          Because you've fixed a few of these in the past already, I am curious as to your opinion of the picture quality that results after the fix. How would you rate it?
                          ~ kca
                          • Shane711
                            • 493
                            LOL, The TV I am using to fix all these boards has a broken screen so there is no way I can tell what the picture quality is. I figured since the screen was smashed I might as well use it for a test TV. I fixed 14 of these board in the past month. I have one now that will not turn on. I found D614 to be shorted but still won't turn on. I think I have narrowed it down to IC1401. I will change this IC tomorrow and see what happens. I also have another board that keeps blowing the fuse and 2 diodes but I have not been able to figure out why, I am suspecting 1 of the high voltage capacitors because I can't test them. D652 will definitely cause the transformer to buzz so be sure to check that.
                            • Shane711
                              • 493
                              Sometimes when you have the board squealing and then after you replace the diode, if it blows again it usually means you have a bad audio/input board. If you do not fix the audio board the power board will blow every time. Working on 4 of these boards today and I have another one that will not work after replacing all the parts, but this board was damaged, has cracks and broken pieces.
                              • littlejohn
                                Emerson clock radio transformer
                                by littlejohn
                                Hello I have a Emerson research clock radio model CKS3516C and the transformer went out on it ,the label on the clock radio says 120VAC 6 watt backup battery DC 3v CR2430. the numbers on the transformer ST3591C-13SEN which I can't find anywhere for it. Can anyone please tell me the AC output voltage. Thanks
                                08-30-2023, 07:13 PM
                              • ohren
                                Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                by ohren
                                Hello!
                                I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                Measured voltages with no load:
                                After rectifier diodes
                                12V: 6.17 V
                                5V: 5.67 V
                                Secondary transformer pins AC measurement (really don't know if this says anything)
                                12V: 2-2.5 V
                                5V: 1.04 V
                                I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                03-18-2023, 10:33 AM
                              • mikey5791
                                Is it possible for transformer substitution?
                                by mikey5791
                                Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                My questions are
                                1. How do i test to see if the transformer is in good working condition?
                                2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                Hope you guys understand what i was asking. My intention is...
                                11-03-2022, 02:11 AM
                              • dennis_elx33
                                3PHASE STEP-DOWN Transformer in Check
                                by dennis_elx33
                                Hello All,
                                i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                                Problem statement: Power tripped Off
                                Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                                Action Done:
                                1) Replaced the faulty parts with good spare.
                                2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                                12-02-2024, 06:52 AM
                                ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                                This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-06-2024, 04:40 PM
