Samsung LE37A336 TCON fuse keeps blowing
  • Jooo
    • Oct 2011
    • 222
    • Finland
    I got this Samsung LCD TV in for repair. It turns on, plays the startup melody and backlights turn on but the screen stays black.
    I opened it up and found a open 3A fuse on TCON board so I replaced it, but this didn't fix the problem.
    The newly replaced fuse had blown again. Thinking that the new fuse was already broken I replaced the TCON fuse again and this time tested it before putting the board back to tv. This still didn't fix the problem, so I tested the fuse and it had blown again.
    So something is causing the TCON fuse to blow, what could it be?
    Tcon model no. is T370XW02 or 37T03-C01
    Re: Samsung LE37A336 TCON fuse keeps blowing
    Does the T-con even work briefly or is it blowing fuses immediately?
    • Jooo
      • Oct 2011
      • 222
      • Finland
      The fuses blow immediately. Nothing comes to screen at all.
        OK, try replacing the fuse but this time, disconnect the ribbons going to the top of the LCD panel, does the fuse still blow?
        • jbfr_54
          • Dec 2012
          • 52
          • France
          If the fuse still blows when the panel ribbons are disconnected, try to locate any shorted SMD caps on the T-Con board. There are usually 6 or more caps wired just after the fuse, decoupling the panel power coming from the main board.
          It happened to me several times that one of these caps is bad, shorting the 5 or 12 volts panel voltage. Replacing the bad ones with equivalent sized smd caps taken on another board is OK as they are not value sensitive and low voltage operating.
            To build on jbfr's answer, I've had a shorted ceramic capacitor on the panel ribbon board, hidden under the LCD frame.
            Typically they'll short the AVDD voltage, which is about 15V. This voltage can be hidden behind a diode drop, so ordinary ohms/continuity testing will not pick it up.
            • MajesticMike
              • May 2012
              • 31
              • US
              and what should you do if the fuse doesn't blow when you unplug the ribbon cables?
              thats where i'm at with the same issue.
                The LCD panel might be bad or it could just be a capacitor shorted out, it can be hard to find.
                • Bobo360
                  • Sep 2018
                  • 36
                  • Italy
                  Hi everyone, I also have the same problem described in the first post. Is the T-com card the one located high above the PSU?
                  Thank you
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    Thank you
                    The small card in the middle at the top, possibly under a metal cover.
                    There will be a wide flat cable going from the mainboard to it.
                    • Bobo360
                      • Sep 2018
                      • 36
                      • Italy
                      OK thanks. I understand.
                      let's check the fuse and U202.
                      I'll let you know.
                        Please provide good clear pictures of the whole backside of the TV showing all the boards using 'Go Advanced'.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4546
                          • Italy - Milan
                          check the.diode near the fuse...
                          • triplefour
                            Samsung UN55ES7003 has blown fuse on TCON and short to ground.
                            by triplefour
                            Samsung UN55ES7003
                            made house call.
                            red power led comes on, blinks twice, no display, no backlight, relay clicks, repeat.
                            psu has self test feature.
                            disconnected from mainboard.
                            determined PSU ok BL ok.
                            suspect mainboard.
                            disconnecting tcon has no change on operation.
                            markings on mainboard:
                            BN97-06531P 0151
                            BN94-06123R
                            found and ordered replacement on ebay https://www.ebay.com/itm/394077328633
                            for 54$
                            second house call:
                            with replacement mainboard, tv turns on, has sound,...
                            07-13-2022, 03:53 PM
                          • Chrissygizmo
                            Samsung ue55hu8500t tcon board fuse blowing
                            by Chrissygizmo
                            Hi , I've got a Samsung UE55HU8500T that has sound but no picture, I've had it open and done a quick check of voltages etc, I found that the F2 fuse on the tcon board had blown (T-CON BOARD VD_STV5565EU22BC6LV0.3 -) so I replaced it with a similar value fuse but still nothing, ten I noticed the replacement fuse had blown too . I would appreciate any help with this. Thank you in advance...
                            04-28-2021, 11:15 PM
                          • Tips
                            Samsung PD27AOQ (BN44-00506B) constantly blowing internal fuse.
                            by Tips
                            Looking for some assistance please.
                            Trying to repair a PD27AOQ samsung power board.
                            Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
                            Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
                            Testing it the fuse blows immediately power is turned on.
                            diodes dm852 and dm853 test as shorted when in the board but fine when removed.
                            any assistance, guidance would be appreciated.
                            04-11-2024, 11:24 AM
                            09-07-2024, 05:50 AM
                          • RogerH58
                            Samsung 46" TV LE46B530 blowing fuse
                            by RogerH58
                            I am a newbie and not very experienced so bear with me if i struggle sometimes with technical language - but I'll do my best. I searched "Samsung" and the model number on the forum but didn't find anything I could understand!
                            I'm not an electronics guy - just picked up stuff over the years through my flight-simming hobby.
                            I have the above mentioned 46" tv as the monitor for my flight-sim setup. Recently it went "crack" and stopped working. No standdby light and no response. I assumed a fuse had blown and after investigation...
                            06-10-2023, 10:27 AM
