Help with no backlight on Toshiba 42AV504D
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    hi guys got a TV Toshiba 42AV504D swithced it on and got no picture, shined a light up against it and seen a picture so then realised the backlights where not on. i opened up the tv and the 2 caps that where on each inverter board (one at each side) where bulging like mad so i replaced them. put them back in the tv but still no baclights. one of the numbers on the boards are LC420WX7 and someone is selling a repair kit on ebay for this type of board. worth while or could it be something else. heres the link to ebay listing http://www.ebay.co.uk/itm/LCD-INVERT...item3f17ddcd88
    and the picture of the 2 boards after caps replaced.
    Re: Help with no backlight on Toshiba 42AV504D
    Checked the fuse on it? The FETs can fail on these.
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      took advise tom and got a better camera no will check the fuse on both the inverters and what is the FET tom66 ?
      • Mikeyboy2007
        • Mar 2013
        • 745
        • Scotland
        Tom66 switched on tv, set multimeter to 20v tested both fuses both ways and got 0v all the way ??
          It's a 24V inverter, you'd use the 200V range - anyway, I'd just check continuity for now, on the ohms range (2000 ohms.)
          • Mikeyboy2007
            • Mar 2013
            • 745
            • Scotland
            sorry Tom, you must think im a total pain in the ar*e but how do i do that ?
            • vinceroger69
              • Mar 2012
              • 6714
              post a picture of your multi meter then we can advise you on the settings.
              • Mikeyboy2007
                • Mar 2013
                • 745
                • Scotland
                its not the best multimeter
                  Switch it to the 2000 horseshoe ("ohm") range then measure across the fuse, you should see less than about 3 ohms.
                  • Mikeyboy2007
                    • Mar 2013
                    • 745
                    • Scotland
                    do i do that with tv on or switched off.... probably a daft question but just to make sure
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      off hahaha not a daft question at all.
                      • Mikeyboy2007
                        • Mar 2013
                        • 745
                        • Scotland
                        vincegregor69 tried doing that both ways on both boards and the numbers flash twice then go to 1 , i tried more than once and the numbers are never the same ??
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          what reading do you get when you hold both multi meter leads together?
                          • Mikeyboy2007
                            • Mar 2013
                            • 745
                            • Scotland
                            flashes up 2 different numbers then goes to 000. then when i take them apart it goes back to 1
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              maybe time to get a better multimeter imo anyway see what tom suggests too i suppose you can set your multi meter on 200v dc and put black probe on chassis and red on each side fuse and see if you get any reading? tv turned on when testing.
                              • Mikeyboy2007
                                • Mar 2013
                                • 745
                                • Scotland
                                ok will try that and update you
                                  Readings so far indicate fuse is blown
                                  • Mikeyboy2007
                                    • Mar 2013
                                    • 745
                                    • Scotland
                                    Tom66 know i shouldnt realy do it but jumped the fuse with a piece of speaker wire. still nothing.
                                      Did you check the voltages each end as Vince instructed above?
                                      • Mikeyboy2007
                                        • Mar 2013
                                        • 745
                                        • Scotland
                                        yes tom both ways on both fuses are reading 24v
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • Boyxba
                                          TOSHIBA BACKLIGHT MAINBOARD C55-a-1h9
                                          by Boyxba
                                          I have a toshiba laptop satelite series c55-a-1h9 with a burnt item on pcb motherboard which is responsible for backlight display. the short came after installation of cable lvds and broken the leg with the v+ of backlight and made this short . the lvds cable replaced and i have working display now but not backlight. the problem is i dont know what was the component that burned in order to change it. voltage i have in this points of burned item at up side 19v and dropping and from down i have steady 19v . can anyone help me? i shall post some photos to see....
                                          05-13-2023, 11:47 AM
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
                                        • willis6732
                                          Toshiba 55lf621c21 Dim Picture / Backlight afterbypassing a Burnt LED
                                          by willis6732
                                          This TV came in for a backlight Repair. I bypassed the Burnt LED as shown in Picture. I thought it was fixed and returned to customer. So I dont have the TV anymore, but customer says its not really watchable.
                                          Now the TV Is much dimmer than before. It does a quick bright flash when it first turns on.
                                          The Driver board looked pretty toasty in the LED Driver Area.
                                          So I am wondering.. how can i Tell if this is a LED or Driver Board Issue?...
                                          12-17-2024, 04:09 PM
