Help with no backlight on Toshiba 42AV504D
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    hi guys got a TV Toshiba 42AV504D swithced it on and got no picture, shined a light up against it and seen a picture so then realised the backlights where not on. i opened up the tv and the 2 caps that where on each inverter board (one at each side) where bulging like mad so i replaced them. put them back in the tv but still no baclights. one of the numbers on the boards are LC420WX7 and someone is selling a repair kit on ebay for this type of board. worth while or could it be something else. heres the link to ebay listing http://www.ebay.co.uk/itm/LCD-INVERT...item3f17ddcd88
    and the picture of the 2 boards after caps replaced.
    Re: Help with no backlight on Toshiba 42AV504D
    Checked the fuse on it? The FETs can fail on these.
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      took advise tom and got a better camera no will check the fuse on both the inverters and what is the FET tom66 ?
      • Mikeyboy2007
        • Mar 2013
        • 745
        • Scotland
        Tom66 switched on tv, set multimeter to 20v tested both fuses both ways and got 0v all the way ??
          It's a 24V inverter, you'd use the 200V range - anyway, I'd just check continuity for now, on the ohms range (2000 ohms.)
          • Mikeyboy2007
            • Mar 2013
            • 745
            • Scotland
            sorry Tom, you must think im a total pain in the ar*e but how do i do that ?
            • vinceroger69
              • Mar 2012
              • 6714
              post a picture of your multi meter then we can advise you on the settings.
              • Mikeyboy2007
                • Mar 2013
                • 745
                • Scotland
                its not the best multimeter
                  Switch it to the 2000 horseshoe ("ohm") range then measure across the fuse, you should see less than about 3 ohms.
                  • Mikeyboy2007
                    • Mar 2013
                    • 745
                    • Scotland
                    do i do that with tv on or switched off.... probably a daft question but just to make sure
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      off hahaha not a daft question at all.
                      • Mikeyboy2007
                        • Mar 2013
                        • 745
                        • Scotland
                        vincegregor69 tried doing that both ways on both boards and the numbers flash twice then go to 1 , i tried more than once and the numbers are never the same ??
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          what reading do you get when you hold both multi meter leads together?
                          • Mikeyboy2007
                            • Mar 2013
                            • 745
                            • Scotland
                            flashes up 2 different numbers then goes to 000. then when i take them apart it goes back to 1
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              maybe time to get a better multimeter imo anyway see what tom suggests too i suppose you can set your multi meter on 200v dc and put black probe on chassis and red on each side fuse and see if you get any reading? tv turned on when testing.
                              • Mikeyboy2007
                                • Mar 2013
                                • 745
                                • Scotland
                                ok will try that and update you
                                  Readings so far indicate fuse is blown
                                  • Mikeyboy2007
                                    • Mar 2013
                                    • 745
                                    • Scotland
                                    Tom66 know i shouldnt realy do it but jumped the fuse with a piece of speaker wire. still nothing.
                                      Did you check the voltages each end as Vince instructed above?
                                      • Mikeyboy2007
                                        • Mar 2013
                                        • 745
                                        • Scotland
                                        yes tom both ways on both fuses are reading 24v
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • Boyxba
                                          TOSHIBA BACKLIGHT MAINBOARD C55-a-1h9
                                          by Boyxba
                                          I have a toshiba laptop satelite series c55-a-1h9 with a burnt item on pcb motherboard which is responsible for backlight display. the short came after installation of cable lvds and broken the leg with the v+ of backlight and made this short . the lvds cable replaced and i have working display now but not backlight. the problem is i dont know what was the component that burned in order to change it. voltage i have in this points of burned item at up side 19v and dropping and from down i have steady 19v . can anyone help me? i shall post some photos to see....
                                          05-13-2023, 11:47 AM
                                        • Kurtix
                                          TV Toshiba 46TL938 - backlight only/green power light
                                          by Kurtix
                                          I am looking for a Toshiba TV expert for a repair on a Toshiba 46TL938 TV
                                          Here are the full tests:
                                          - Connecting the TV to the power
                                          - The TV turns on automatically without logo only the backlight works
                                          - LED on the front of the screen power green
                                          - TV controls (Power/VOL/Menu/Source) not responsive
                                          - Commands with the remote do not react (remote works on another TV)
                                          - Cover removal
                                          After about 1 minute when connecting the TV to the mains, there is an LED on the motherboard (PE1091) which flashes...
                                          11-23-2022, 06:58 AM
                                        • canadaboy25
                                          LG Flatron 24EN33TA No Backlight When Cold
                                          by canadaboy25
                                          I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                                          I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                                          03-07-2023, 12:23 AM
                                        • triplefour
                                          TCL 75S421 has sound but no backlight not even a flash
                                          by triplefour
                                          TCL 75S421
                                          PSU BOARD: 40-L402H8-PWD1CG
                                          it shows not even a flash of backlight when powering up.
                                          but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
                                          testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
                                          unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
                                          i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
                                          with mb connected, PSON...
                                          11-17-2023, 09:54 PM
