Help with no backlight on Toshiba 42AV504D
  • triplefour
    by triplefour
    09-13-2023, 10:43 PM
  • Boyxba
    TOSHIBA BACKLIGHT MAINBOARD C55-a-1h9
    by Boyxba
    I have a toshiba laptop satelite series c55-a-1h9 with a burnt item on pcb motherboard which is responsible for backlight display. the short came after installation of cable lvds and broken the leg with the v+ of backlight and made this short . the lvds cable replaced and i have working display now but not backlight. the problem is i dont know what was the component that burned in order to change it. voltage i have in this points of burned item at up side 19v and dropping and from down i have steady 19v . can anyone help me? i shall post some photos to see....
    05-13-2023, 11:47 AM
  • DanPoka
    by DanPoka
    02-15-2025, 05:05 AM
  • Comp_Pro
    No Backlight Macbook A1990 820-01041
    by Comp_Pro
    Hello all,
    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
    Tests performed:
    There is no backlight even with a good screen.
    Backlight IC is receiving the correct support voltages.
    Fuse F8400 ok
    Current sense resistor R8400 ok
    Backlight IC is receiving 3.3V on enable pin.
    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
    Backlight IC receiving 5V from PP5V_G3S
    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
    05-06-2024, 10:23 PM
  • willis6732
    Toshiba 55lf621c21 Dim Picture / Backlight afterbypassing a Burnt LED
    by willis6732
    This TV came in for a backlight Repair. I bypassed the Burnt LED as shown in Picture. I thought it was fixed and returned to customer. So I dont have the TV anymore, but customer says its not really watchable.
    Now the TV Is much dimmer than before. It does a quick bright flash when it first turns on.
    The Driver board looked pretty toasty in the LED Driver Area.
    So I am wondering.. how can i Tell if this is a LED or Driver Board Issue?...
    12-17-2024, 04:09 PM
