Technika X22/14B-GB-TCD-UK LCD screen went dark
  • Fred53
    • Mar 2014
    • 33
    • United Kingdom
    Hi All, First Thread so be gentle
    Technika X22/14B-GB-TCD-UK LCD screen went dark. Upper half for a short time then the full screen went dark, still got sound and picture visible using a torch. Checked on start, backlights come on for 1 / 2 seconds then backlights switch off, DVD cycles, sound from speakers, Technika Logo visible, Menu functions etc visible with torch. LED on Front cycles from standby through amber then stays on green Everything seems to operating as normal except for backlights. I changed the Inverter as a cheapest option, but TV still has the same fault, any suggestions Please.
    Fred
    I don't like to leave a job I started unfinished
  • sordids999
    • May 2013
    • 2152
    Re: Technika X22/14B-GB-TCD-UK LCD screen went dark
    Pictures of boards ?
    • multimeter
      • Jan 2011
      • 739
      • united kingdom
      im assuming this tv is a 22"?,if it is ,and you have replaced the inverter,its very likely that the ccfls,(assuming not led tv)are failing/failed,and that would come under panel failiure.and not really worth it,another problem it could be,is that the psu may not be outtputting the correct voltages due to bad caps,underpowering the inverter
      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
      • Fred53
        • Mar 2014
        • 33
        • United Kingdom
        Hi Multimeter,
        Thanks for the info. yes it is a 22" and not worth spending much on, PSU went about 6 months ago but there are no visible sign's of faults on the new one. or any cap's boards etc, but that doesn't mean the fault's aren't in there hiding
        I have been reading a thread with the same fault, different set, so I will follow it and see what develops there, may give me a hint.
        I was wondering if there is a way to bypass inverter protection, to test out the panel backlights that way?
        I read this thread but not sure if it is the way to go,
        Technika 22" - X21/14C-GB-TCD-UK - 2 secs to black
        Thanks Fred
        • sordids999
          • May 2013
          • 2152
          Fred
          had the same problem bought this tv thinking it was the invertor to only find out the replacement did not work so swopped screens due to having another one of these with a power issue and all working
          i might have a spare screen laying around you can have,but ill check to be sure first
          • Fred53
            • Mar 2014
            • 33
            • United Kingdom
            Hi sordids999,
            Thanks for that, I will look on ebay and see if I can find one as well.
            I might find a working one cheap, I don't like to leave a job I started unfinished
            Thanks Fred.
            • multimeter
              • Jan 2011
              • 739
              • united kingdom
              the inverter ccfl plugs will be the small white connectors ,if you have any spare ccfl tubes lying around,you can use them to plug into the inverter,if they light up,and dosent shut down the tv,then its safe to say the tubes are gone(or even just one will cause this fault).
                I have seen two of these now, both bad CCFL tubes.
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  Tom's seen two.....
                  I guess I must have seen 200--ALL with bad CCFL tubes.....
                  I dont even bother with 'em now
                  TESCO'S Finest Shit!
                  TELEFIX
                  • multimeter
                    • Jan 2011
                    • 739
                    • united kingdom
                    Originally posted by Alastair E
                    Tom's seen two.....
                    oddly,ive fixed around 20-25 of these,and only about 5 had CCFL issues!
                    i guess different factory's have different perks .........
                    • Fred53
                      • Mar 2014
                      • 33
                      • United Kingdom
                      I haven't got a spare CCFL, is there any sort of ballast that I could use instead to test each socket on the invertor?
                        Make two of them for testing.
                        https://www.badcaps.net/forum/showth...er+testing+cfl
                        • Fred53
                          • Mar 2014
                          • 33
                          • United Kingdom
                          Originally posted by budm
                          Thanks for that Gem, budm, I will be testing soon
                          AARGH Just checked my spares and only got 8w 9w and 11w will I be able to use 11Watt? by any chance!
                            8, 9, 11 W in the form factor as shown in my pictures are fine, its the higher Wattages are the one that may not work.
                            • Fred53
                              • Mar 2014
                              • 33
                              • United Kingdom
                              Brilliant Thanks again budm
                              • sordids999
                                • May 2013
                                • 2152
                                What's the panel number I got a few laying around ?
                                • Fred53
                                  • Mar 2014
                                  • 33
                                  • United Kingdom
                                  I haven't stripped it down that far yet, sordids999, I had a look but the number must be under a board. the inverter was easy to get to 2 screws, I changed it like i said earlier, but same fault CCFL's on for a flash, when I get it stripped I will PM you the number ok, Thanks for the help.
                                  I want to try this 11W test bulb idea from Budm first, cool idea
                                  • Ryan.man
                                    by Ryan.man
                                    02-04-2025, 12:23 PM
                                  • smic717394
                                    by smic717394
                                    07-25-2024, 10:16 AM
                                  • Chrissygizmo
                                    by Chrissygizmo
                                    02-10-2025, 12:33 AM
                                  • spice_disc
                                    Vizio TV M50-C1 reboot cycle and static on screen
                                    by spice_disc
                                    I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                    The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                    09-08-2024, 02:37 PM
                                  • ipatch
                                    ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                                    by ipatch
                                    i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                                    08-24-2024, 02:36 PM
