sony 55X850D black screen no front white or red led light.
    • 12330
    • U.S.
    Just a warning, be VERY careful if you do work on the mainboard, I ruined mine somehow, may have overheated the ram.
      • 12330
      • U.S.
      Would be good to narrow this bl-err down, appears it is usually backlights but can be something else maybe? Wonder if Nick knows.
      • Diah
        • Feb 2013
        • 6562
        Originally posted by Ihandyrepair
        I just noticed that if I unplug the cable from LD board to mainboard and power it on
        the backlight will turn on.
        so most likely the LD board is ok and issue could be the main board right?
        we have in this forum threats with sony same things... BL_ERR generated by LD driver as its the parts monitor the currents pull up of BL LEDs,, disconnecting the LD just disable the monitore circuit.. mainboards send power on & BL_ON so where are the problem .. LOL
        you test them on wrong way... you need to test each LED with DMM in diode mode in K A and reverse way to test the build in ziner are in takt and it pull 0.65 to 0.78
          • 12330
          • U.S.
          Yes, do this, definitely need to test those leds.
          • Ihandyrepair
            • Sep 2017
            • 44
            Well the thing that made me scratch my head is that I did take the screen apart, both edge led looks good condition,
            And I used one of those led strip tester showed voltage draw
            each led had like 6 sections
            each section were drawing 56.9-57v
            if one of the led was bad it would had lower or higher voltage draw, right?
            also I thought maybe the trace or cable to led,
            so I tested the led sections from the LD boards that has each sections test pads
            same result
            each section was drawing 57v
            I was hoping it was the led strips or maybe the LD board
            as they are cheaper than used mainboard
            i don’t get eBay or used online tv parts asking for $250 or higher
            why I would spend $300 parts for this tv
            where good used Sony tv are $300-500
            • Diah
              • Feb 2013
              • 6562
              do you have problem to understand what i am in ?? LED tester never never never discover LED with zener diode defect.. so the test should be with DMM in diode mode.. the reset up to you. at time you test all LED one by one with DMM and all show good then i can join again your threats... this is useless way for me at least.. as there other users include you go in guess on parts had nothing to do with BL_ERR... read again my last post. good luck
              • Ihandyrepair
                • Sep 2017
                • 44
                thanks for your help but
                you have to understand I am new in fixing tv and still learning.
                I am guessing most of us are still learning.
                you may be the best tech here but they way you tell me what to check I do not get it
                but after reading your post more carefully and did more research
                I am guessing you are trying to say this
                https://youtu.be/rq-RwfDrU8c?si=PTnO4v7EDOq5GHZu
                Like this guy showed cheap led tester can cause miss diagnosing led failure.
                I guess I already bought the led strips
                maybe I should just remove the screen again and test with the new led strip
                or another way is order led ribbon cables, and test them to confirm if the tv will boot without the LD_err before taking the screen apart again
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4538
                  • Italy - Milan
                  #28
                  You are almost newbie in tv repairs if you didn't noticed that no status led errors are present, this clearly tells there is a bad software... truely, this is the sit. :
                  -bad software or bad emmc balls, bad software can mean also bad balls, so reballing is suitable
                  -bad Ram balls
                  -bad cpu balls
                  the sureness is to reball everything and reprogram emmc.. is this ok economically? i don't know...
                    • 12330
                    • U.S.
                    #29
                    I believe Diah wants you to test those led backlights in this manner using the DIODE setting on the multimeter and testing each led so if you have for example 32 individual led backlights you would test all 32 not just from each end of strip: https://www.google.com/search?q=How+...86B18H4c8,st:3
                    • Ihandyrepair
                      • Sep 2017
                      • 44
                      yes I am not worry people calling me newbie as I am new at this
                      but I do this as hobby only, so I don't think I will learn how to reball large chip like ram or cpu
                      if doing this full time, I think I should.
                      but something like small cap or resistors maybe ok
                      I look it this way.
                      if I get a tv for free or under $100
                      and if lucky is just something minor or fixable like led strips then why not spend the time as hobby
                      but I have to spend anything more than $250 to 300 for a used tv
                      I don't think it is worth to do it.
                      I guess there are 2 steps I should do for this tv
                      are the led ok? so Diah wants me to check each LED using diode mode
                      if they are ok, then most likely like davi mentioned bad software or chips = mainboard
                        • 12330
                        • U.S.
                        #31
                        That seems like a good approach, mainboards can be very hard to diagnose and fix even for the best pros.
                          • 12330
                          • U.S.
                          #32
                          I look it this way.
                          I wouldn't make fun of you, I'm new to this myself. I have very seldom met a sony that was an easy fix.
                          • Diah
                            • Feb 2013
                            • 6562
                            i asked to testing LED one by one as nomoresonys said.. not to replace LOL you can learn its no difficult matters... if yours DMM with 9V Battery , on K A ithe led will light very dim.. and when you do reverse the probe it will show you the reading on zener diode... so you will know if this shorted or open or in takt at good reading.
                            yours MB sending Power ON and BL ON so what kind of SW issue or BGA to do when it send signal so funny.....there are BL err high so the first things need to be sure this LED BL are good not to go destroying the MB.... front LED indicator can be turn off from user menu... who don't know about sony android then should have one and learn how it work.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4538
                              • Italy - Milan
                              #34
                              my advice don't risk much with broken sets, the luck rarely presents it, in the very wide faults types field, this was my error many and many time, therefore you end filling house with hard to fix beasts.. better buy them with no urgent needs.. and if you have much time to dedicate..
                              and last.. today tv are more problematic than previous, don't expect fast repairs, them are hard bones..
                                • 12330
                                • U.S.
                                #35
                                I'll just say that if you are paying 100 bucks for a non-working tv, you better make sure you can at least get that back in parts OR you might be in for a very expensive hobby.
                                • Ihandyrepair
                                  • Sep 2017
                                  • 44
                                  haha yeah
                                  I would only pay $100 if I can see the screen working for Sony
                                  other would be $50 or free
                                  I can believe some people asking cracked screen for 250-300,
                                  before I got few free LG or samsung were tv works fine just the back light was burnt
                                  but I don't want to do samsung edge BL anymore as I found most of them after burning the LED you take it apart
                                  you see the diffuser cracked or plastic sheets all metled so after replacing the BL
                                  the tv screen still look like crap all lights everywhere
                                  as for LG, spread out back light not too bad after replacing the BL, everything looks good
                                  only down side is you don't get as much as Sony tv
                                  I got lucky few times were I got Sony tv
                                  one 55 inch was replacing the main board. and I was lucky were local guy was selling the mainboard due of cracked screen so costed me only $45 for the tv to fix
                                  now I am using it as computer monitor
                                  another one was free Sony 65, owner unplugged it before updating was finished, stuck in booting. but I was lucky just did a hard reset and tv was working. I didn't even had to use my screw driver on this one.
                                  and last one was the X950g, with flashing red light, and I was able to ground the BL_err and tv start so I was able to confirm the back light had 1 dark spot, burnt 2 led most likely
                                  which I will replacing it later on.
                                  now stuck with this one,
                                  but now I look at this way
                                  if the led are still ok, then most likely I will have to wait until I get a cheap or free mainboard like from a cracked screen. in order to fix it.
                                  the worst part as nick said, the 55x850d support has been discontinued. so I can't find a newest firmware to download.
                                  and looking at some complains about this model, I should not spend too much for it. as there is no more updates.
                                  I am sure how many of us have few broken tv in the garage waiting for cheap part or another way to diagnose the problem
                                  and the wife is mad about it
                                  right?
                                  haha
                                  • Gigabyte_PL
                                    PS4 PRO - black screen, white light
                                    by Gigabyte_PL
                                    I have problem with my Playstation 4 PRO. After a long break, I turned on the console and tried to play game. Game started, but after a minute it froze the console and crashed to the main menu. I tried running another game and the same problem.
                                    Error returned: CE-34878-0 (I changed HDD)
                                    I updated the software in the console. I unplugged the console, put it aside for a week and now I want to turn it on but there is no image. The console lights up white, there is communication via HDMI with the monitor - but only a black screen (but it detects the...
                                    01-04-2024, 05:46 AM
                                  • Audeze
                                    Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                    by Audeze
                                    I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                    Does...
                                    10-06-2024, 08:54 PM
                                  • howardc64
                                    by howardc64
                                    Problem
                                    08-04-2024, 10:36 PM
                                  • VcemPzd
                                    Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                    by VcemPzd
                                    Hello everyone !
                                    My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                    04-28-2025, 10:14 AM
                                  • Raulnn
                                    TD Systems K50DLG12US half black and half white screen
                                    by Raulnn
                                    good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
                                    By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
                                    01-20-2024, 04:49 PM
