Vizio E701i-A3 Vizio logo flashing then turns off
  • Super360
    • Jul 2016
    • 243
    I guess I will try a new PSU next. Will keep you updated. Thanks.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Is that really 300 LEDs or nearly 300 LEDs in-series?!
      Or at or around 180 LEDs in series, for at or around 600V?
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • Super360
        • Jul 2016
        • 243
        Ok so a little update and thanks to all you guys for all your help but I did indeed fix this one. I replaced the psu and it fired right up. I did bother replacing those 3 main filter caps on the working one even though they look fine, Figured it couldn't hurt. Also found the picture of the original capacitor explosion on the broken psu so you can enjoy that. Thanks for all the help guys on this tv.
        Thanks.
        • nomoresonys
          • 12116
          • U.S.
          Glad to hear it, a guess on the problem with the original powerboard is maybe a bad backlight driver IC.
          • EazyBone
            • Jun 2023
            • 1314
            • United states
            Bing bang boom. Well done.
            Gotta make sure you do that flashlight.
            And I've never seen a cap do that yet, well a main one anyway. Pretty cool
            • ossroy
              Vizio M60-C3 powers on, perfect logo, turns off
              by ossroy
              Vizio M60-C3 powers on, perfect logo, turns off. If you don't touch anything it will repeat this process by itself until it is unplugged. Not the "button board" since I disconnected the cables to the main board and the problem persisted. So I'm fairly positive something is going on with the main board, but want to know if there is a fix for this other than replacing the expensive mainboard, which may eventually have the same problem. Also, heat sink was hot as hell when this all started. Unplugged for a few days and same thing happens.
              My kids are getting antsy waiting...
              08-03-2022, 08:11 PM
            • x_orange90_x
              Vizio V555-G1 stuck on wallpaper; now stuck on V logo
              by x_orange90_x
              I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
              12-28-2023, 06:26 AM
            • mrtek
              Vizio M65-C1
              by mrtek
              Hi.
              picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
              When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
              This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
              07-14-2025, 07:28 PM
            • JaquesPratt
              Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
              by JaquesPratt
              I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
              This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
              07-16-2024, 01:04 AM
            • STKR123
              Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
              by STKR123
              As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
              I wonder if re-flashing the BIOS might be of any use here.
              As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
              There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
              11-03-2024, 06:58 AM
