yours firmware upgrade one... it header to skip over write chip.. you need factory firmware.
Sharp Aquos LC-40UG7252E LCD TV burn in?
We can only suppose that 1,5v is the correct one, since 1,5 is the normal voltage for ddr ram, but no ram is present, main chip usually needs about 1-1,2v, so that 1,5v can be normally 3,3v that is a voltage for COF chips, or 1,8v also for COF, this to tell that COF can be shorted, not completely but unremediable broken..Comment
Ok so I unsoldered all the caps and the diode next to the inductor, tested all of them and there is no short. Diode is also ok. I then tried to trace the connection and the caps are directly connected to the VCC 1.05V test pad which measured is about there (~1.02 V).
I've attached a photo with the trace.
Also, The resistance between the caps pad (or in that case the VCC1.05V pad) and ground is about 105 ohms. Is this normal?
Also, VOFF-11V is actually -13V is this normal?Comment
you previously said it was at 1,5v when cold, is now the same? was the main ic Samsung heating too much? The vcc_1.05v is connected also to another chip more than the main chip, it would be useful to feed only the 1.05v externally, no other power, and feel the heat on various ic, caps, etc..Comment
Why do you unsolder these components (capacitors, inductor, diode), everything is fine there! 1.05v is the power supply to the processor core and it always has low resistance (it’s not for nothing that such a powerful inductor is used.Ok so I unsoldered all the caps and the diode next to the inductor, tested all of them and there is no short. Diode is also ok. I then tried to trace the connection and the caps are directly connected to the VCC 1.05V test pad which measured is about there (~1.02 V).
I soldered them back, TV is back to square 1.Comment
I'll try to be less confusing:- bottom part of Inductor measures 1.8V decreasing to 1.48V stable
- the other part of the inductor (that is also connected to the 4 capacitors) measures 1.43V going down to 1.16V
- this in turn has direct connection with the VCC_1.05V (which measures around 1.3V decreasing to 1.02V)
New panel symptoms:
It started flickering now.
Main Samsung IC heats up really well as before but freezing it with air can makes the flickering disappear.
I tried doing a better job with the parts I resoldered but those new symptoms are still there.
PS: I noticed that COFS heat up really well too.
Here is video with the new symptom: https://www.youtube.com/watch?v=TvoXVFQhhg0
Well if its down to giving up, maybe try a diy reflow, check this thread, some good info about how to and what temperatures to use, and yes I know it might not be the problem but these things can be very tricky and nobody has come up with the perfect answer yet: https://www.badcaps.net/forum/troubl...-no-backlightsComment
I would try a diy reflow on the big chip on the driverboard where it says deno tp3, if no joy, then maybe remove the heatsink of the bga on mainboard and refolw that. Might not be the problem but as someone said before, "I have seen stranger things"Comment
by scubacamperI found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display... -
by sefosterI have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
by klassicHi community,
I will describe my problem with a TV in those short following terms to be the most precise :
What i have :
Sharp Aquos LC-60LE635E
power board DPS-162KP-1
main logic board QPWBXF733WJN2
symptoms :
white led light logo at startup,
after 2 minutes, blinking 3 times a row, repeating
no backlight (and apparently no picture, checked panel with flashlight)
no startup sound
powerboard investigations :
1-2 PNL : 0v
3-4 GND
5-6-7-8 UR : 13.15v
9-10-11-12... -
by foxyUKCan anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12.... -
Hello esteemed gentlemen. I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
... - Loading...
