Sharp Aquos LC-40UG7252E LCD TV burn in?
  • Diah
    • Feb 2013
    • 6343
    yours firmware upgrade one... it header to skip over write chip.. you need factory firmware.
    • jonah1024
      • Jul 2024
      • 44
      • Romania
      #62
      Originally posted by Davi.p
      The logic says the good is at 1,5v, then with the heat resistance rises and voltage drops to a bad value, try unsolder, remove and resolder that coil..
      Unsoldered that coil, measured its resistance (<0.4 ohm) then soldered it back. Problem is still there…
      • Davi.p
        • Sep 2009
        • 4265
        • Italy - Milan
        #63
        Have you removed all old solder? I would suspect one or more of those 4 caps.. replacing them all with at least 10uF 10v each, better 50v..
        • Davi.p
          • Sep 2009
          • 4265
          • Italy - Milan
          #64
          We can only suppose that 1,5v is the correct one, since 1,5 is the normal voltage for ddr ram, but no ram is present, main chip usually needs about 1-1,2v, so that 1,5v can be normally 3,3v that is a voltage for COF chips, or 1,8v also for COF, this to tell that COF can be shorted, not completely but unremediable broken..
          • jonah1024
            • Jul 2024
            • 44
            • Romania
            #65
            Ok so I unsoldered all the caps and the diode next to the inductor, tested all of them and there is no short. Diode is also ok. I then tried to trace the connection and the caps are directly connected to the VCC 1.05V test pad which measured is about there (~1.02 V).
            I've attached a photo with the trace.
            Also, The resistance between the caps pad (or in that case the VCC1.05V pad) and ground is about 105 ohms. Is this normal?
            Also, VOFF-11V is actually -13V is this normal?
            • Davi.p
              • Sep 2009
              • 4265
              • Italy - Milan
              #66
              you previously said it was at 1,5v when cold, is now the same? was the main ic Samsung heating too much? The vcc_1.05v is connected also to another chip more than the main chip, it would be useful to feed only the 1.05v externally, no other power, and feel the heat on various ic, caps, etc..
              • lotas
                • Jan 2016
                • 4458
                • Russia
                #67
                Why do you unsolder these components (capacitors, inductor, diode), everything is fine there! 1.05v is the power supply to the processor core and it always has low resistance (it’s not for nothing that such a powerful inductor is used.
                • jonah1024
                  • Jul 2024
                  • 44
                  • Romania
                  #68
                  It's still 1.5V if measured with the ground as chassis, 1.42V if measured with ground on the nearest ground on tcon.
                  The VCC1.05V pad measures 1.3V at power on and slowly decreases close to 1.05V
                  Yes, the main Samsung IC heats up as well.
                  • jonah1024
                    • Jul 2024
                    • 44
                    • Romania
                    #69
                    I soldered them back, TV is back to square 1.
                    • Davi.p
                      • Sep 2009
                      • 4265
                      • Italy - Milan
                      #70
                      I see you are providing some random measurement values, i suspect your meter battery is not ok..
                      • jonah1024
                        • Jul 2024
                        • 44
                        • Romania
                        #71
                        Hmm what do you mean by random?
                        I will replace battery as well but all measurements are consistent, are they not?
                        • Davi.p
                          • Sep 2009
                          • 4265
                          • Italy - Milan
                          #72
                          i mean you wrote too much values of the 1.05v rail to be comprehensible
                          • jonah1024
                            • Jul 2024
                            • 44
                            • Romania
                            #73
                            I'll try to be less confusing:
                            • bottom part of Inductor measures 1.8V decreasing to 1.48V stable
                            • the other part of the inductor (that is also connected to the 4 capacitors) measures 1.43V going down to 1.16V
                            • this in turn has direct connection with the VCC_1.05V (which measures around 1.3V decreasing to 1.02V)
                            The voltages differed a bit (by about 0.1V more) If I measured using ground from chassis instead of ground pad on T-con board. That's all
                            • jonah1024
                              • Jul 2024
                              • 44
                              • Romania
                              #74
                              New panel symptoms:
                              It started flickering now.
                              Main Samsung IC heats up really well as before but freezing it with air can makes the flickering disappear.
                              I tried doing a better job with the parts I resoldered but those new symptoms are still there.
                              PS: I noticed that COFS heat up really well too.
                              Here is video with the new symptom: https://www.youtube.com/watch?v=TvoXVFQhhg0
                              • Davi.p
                                • Sep 2009
                                • 4265
                                • Italy - Milan
                                #75
                                From before the inductor to the main ic load there is a suspicious high v drop, i think that glue around the chip hides a sad secrect and it is not protective
                                • jonah1024
                                  • Jul 2024
                                  • 44
                                  • Romania
                                  #76
                                  That’s sad. I feared you would say that.
                                  This means giving up I guess. 😢
                                  Thank you everyone for the contribution!
                                  I learned a lot even though repair was not successful.
                                    • 12081
                                    • U.S.
                                    #77
                                    Well if its down to giving up, maybe try a diy reflow, check this thread, some good info about how to and what temperatures to use, and yes I know it might not be the problem but these things can be very tricky and nobody has come up with the perfect answer yet: https://www.badcaps.net/forum/troubl...-no-backlights
                                      • 12081
                                      • U.S.
                                      #78
                                      I would try a diy reflow on the big chip on the driverboard where it says deno tp3, if no joy, then maybe remove the heatsink of the bga on mainboard and refolw that. Might not be the problem but as someone said before, "I have seen stranger things"
                                      • Diah
                                        • Feb 2013
                                        • 6343
                                        go to this side and ask for firmware early version with panel firmware.
                                        • Davi.p
                                          • Sep 2009
                                          • 4265
                                          • Italy - Milan
                                          #80
                                          is there someone able to reball the main chip? you can give him the tv set for free or some few $
                                          • scubacamper
                                            Sharp Aquos LC-70C6400U Half Screen Dark
                                            by scubacamper
                                            I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                            Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                            when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                            05-03-2025, 12:19 PM
                                          • sefoster
                                            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                            by sefoster
                                            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                            11-20-2022, 09:29 AM
                                          • klassic
                                            Sharp Aquos LC-60LE635E three blinks
                                            by klassic
                                            Hi community,
                                            I will describe my problem with a TV in those short following terms to be the most precise :
                                            What i have :
                                            power board DPS-162KP-1
                                            main logic board QPWBXF733WJN2
                                            symptoms :
                                            white led light logo at startup,
                                            after 2 minutes, blinking 3 times a row, repeating
                                            no backlight (and apparently no picture, checked panel with flashlight)
                                            no startup sound
                                            powerboard investigations :
                                            1-2 PNL : 0v
                                            3-4 GND
                                            5-6-7-8 UR : 13.15v
                                            9-10-11-12...
                                            10-24-2023, 01:39 PM
                                          • foxyUK
                                            Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                                            by foxyUK
                                            Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                                            The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                                            There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                                            10-22-2024, 10:27 AM
                                          • thesharpfella
                                            Is this white-washed screen caused by a faulty T-Con board or panel? Sharp Aquos c70le735x
                                            by thesharpfella
                                            Hello esteemed gentlemen. I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
                                            07-23-2024, 10:37 AM
