Logik l32digb20
+ More Options
Posts
  • sordids999
    • May 2013
    • 2152
    #81
    Re: Logik l32digb20
    This is the problem flocko one minute the backlight will flash constantly or only one flash then goes into standby seems to have a mind of its own
    i can use the side button to turn on the tv on but once the backlights stop flashing you cant use it,instead you have to turn the tv off and on
    http://cpc.farnell.com/texas-instrum...63?Ntt=tlv1117 (33p - 3.3V type)
    http://cpc.farnell.com/texas-instrum...117/dp/SC08267 (44p - adj)
    so go ahead and order these ? im collecting the resistors later tom
      Re: Logik l32digb20
      If you get resistors from Maplin, may as well wait before ordering the LDOs.
      • flocko
        • Nov 2012
        • 1121
        #83
        Re: Logik l32digb20
        Yes will be easy to power up the inverter you can do it at the plug to the Av you dont have to do Pson as you can still power on the side buttons, just BLon and Dim on the 4 wire plug of the Av to jump with the resistors to 5V standby, and see if it work the inverter, if it does then it the av board
          Re: Logik l32digb20
          I would jumper the PSON too because I suspect main board could be causing the problem. Not sure though.
          • sordids999
            • May 2013
            • 2152
            #85
            Re: Logik l32digb20
            OK tom I've got a the resistors ready when you are
              Re: Logik l32digb20
              OK, so first lets get PSON working.
              - Disconnect the connector between main board and power board, on the main board end.
              - Connect the resistor between the 5V STB and PSON pins. (Poking the pins in the connect holes works best.)
              At this point, once you plug TV in, you should get 24V and other voltages. You should not get any backlight.
              Are the voltages steady?
              • sordids999
                • May 2013
                • 2152
                #87
                Re: Logik l32digb20
                Tom do you mean the 4 pin red and black cable pins ?
                • sordids999
                  • May 2013
                  • 2152
                  #88
                  Re: Logik l32digb20
                  Sorry found it voltages are steady tom
                    Re: Logik l32digb20
                    OK, now unplug set.
                    For the connector going to the inverter, you want to leave that plugged in. But, you want to run one resistor between 5V main to BL ON and one from 5V main to DIM. (Order doesn't matter; BL ON and DIM are the green and brown wires.)
                    Now, when you plug set in backlight should come on and stay on. No picture will appear. Screen will either be black or white. Does it flicker?
                    YES - Power board or inverter board or bulb panel arc - need to do further tests
                    NO - Main board
                    • sordids999
                      • May 2013
                      • 2152
                      #90
                      Re: Logik l32digb20
                      OK tom first resistor connected but not sure where the second one goes to I've added pictures
                      • flocko
                        • Nov 2012
                        • 1121
                        #91
                        Re: Logik l32digb20
                        un plug 4 wire connector with the green and brown on form Av board same again one resistor in green and one in brown to 5V backlight should come on when set plugged in Flocko
                        • sordids999
                          • May 2013
                          • 2152
                          #92
                          Re: Logik l32digb20
                          Well if this is wired up right I now have a flashing backlight
                          • sordids999
                            • May 2013
                            • 2152
                            #93
                            Re: Logik l32digb20
                            Ok done what flocko said now I have backlight on
                              Re: Logik l32digb20
                              Not flickering?
                              24V measure OK still?
                              Note: it'd be a good idea to unplug connector for blon/dim from the main board.
                              • sordids999
                                • May 2013
                                • 2152
                                #95
                                Re: Logik l32digb20
                                no flickering and 24 volt is steady
                                • flocko
                                  • Nov 2012
                                  • 1121
                                  #96
                                  Re: Logik l32digb20
                                  i did say unplug the 4 wire connector from the Av. Ok now to prove only BL on and Dim from main board defective, if you go back to the start pull the resistor out off PS on and plug that back in main board but leave the BL on and dim connected to the resistors and 5v but unplugged from Av, you should now be able to turn on the set on from the side buttons or remote and get backlight
                                  • sordids999
                                    • May 2013
                                    • 2152
                                    #97
                                    Re: Logik l32digb20
                                    yes flocko and tom plugged it back in now the backlight comes on tv,also menu now showing on the screen and i can use the buttons on the side
                                    • flocko
                                      • Nov 2012
                                      • 1121
                                      #98
                                      Re: Logik l32digb20
                                      Good ,then i think change the regulators and you will be fine sorry it took 5 pages to get here but that some time happens, any way order your regulators and let us know how it goes i will keep my fingers cross that all will be fine Flocko
                                      • sordids999
                                        • May 2013
                                        • 2152
                                        #99
                                        Re: Logik l32digb20
                                        ok so order these ?
                                        and thanks alot flocko and tom
                                        • flocko
                                          • Nov 2012
                                          • 1121
                                          #100
                                          Re: Logik l32digb20
                                          good i think now change the regulators and it will be fine, sorry it took so long to get here but that sometimes happens,go back over the post and read how we said to change them and be careful with the heat,let us know how it goes Flocko
                                          • Cemal Odabasioglu
                                            MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                            by Cemal Odabasioglu
                                            I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                            Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                            Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                            Observations...
                                            01-14-2025, 03:54 PM
                                          • triplefour
                                            ONN 100012588 Has fluctuating Voltage on PSU 12v
                                            by triplefour
                                            Hello all got another TV here im puzzled by. why cant they all be easy fixes that just need a little love and some tape???
                                            anyway i go to this guys house to look at an ONN 100012588
                                            this is my first time looking at one of these brand of TV's.
                                            TBH i have low expectations because i see ONN as the cheap walmart brand that suddenly popped up selling the cheapest version of all kinds of tech things. and someone sent me a ONN flash drive with some data on it with some recordings they wanted me to check out and it immediately broke and corrupted the data and i was unable to...
                                            09-14-2022, 07:41 PM
                                          • unimatrix93
                                            Inexive (Vestel) TV constantly blinking after plugging in
                                            by unimatrix93
                                            Hello everyone, I have a constantly blinking Inexive LED TV.
                                            Display is: VES390UNVA-2D-N01
                                            Mainboard: 17MB97​
                                            PSU: 17IPS71
                                            The TV power led start blinking constantly right after plugging it in, I tried to update via USB but did not help....
                                            03-26-2025, 08:36 AM
                                          • beetle1303
                                            Wine Chiller - SMPS issue - fluctuating voltages
                                            by beetle1303
                                            My wine chiller, TECNO SW-126LCD, is semi-functional - it powers up, can set temperature, and chilled to the set temperature, and cuts off compressor, etc. It however runs very hot.
                                            Upon taken out the PSU and did some basic check - 5V output to LCD panel buttons and display is stable, but there is no 12V output to LED lights, and fans.
                                            Further checks found the secondary side voltage is fluctuating around 8-15V range, but the 7805 regulator seems ok and producing the stable 5V output.
                                            Checking further on the primary side: Incoming line input to bridge...
                                            09-04-2023, 10:33 AM
                                          • koby058
                                            yoga9 3v3 5v fluctuating
                                            by koby058
                                            Hi
                                            board model: NM-D992
                                            type c remains on 5v. when i connect it the 3.3VALW and 5VALW fluctuating. can someone please help understand why?
                                            main power rail voltage 13v
                                            till now i have tried:
                                            measured all coils resistance looks ok
                                            replaced RT6585CGQW to a brand new one
                                            replaced all mosfets for 3.3v regulator and the dual mosfet for 5v regulator
                                            happen both on DC power and on battery
                                            issue remains
                                            video
                                            schematic attached...
                                            08-03-2025, 09:06 AM
