IPAD A1673 power constantly resetting
  • AlexVG
    • Apr 2022
    • 138
    • SPAIN
    Hello. I came across with the power supply constantly resetting on IPAD A1673.
    (I connect it to USB power)
    PMU U8100 is rising all voltages except PP3V3_S2 . Consequently, the SYS_ALIVE is also absent.
    I have two identical boards with the same symptoms, and I think this is a common problem.
    I also have a working board. I've taken all the measurements to compare and haven't seen any abnormalities. There are no signs of a short circuit or water damage.
    VREF, IREF are also present.
    I also couldn't find any PP3V3_S2 enable signals.
    Please help me and suggest what the problem might be.
    Thank you
  • reformatt
    • Feb 2020
    • 1535
    I haven't worked on iPads for a long time, but IIRC, iPads will boot loop without the battery gas gauge data or missing voltage from the battery.
    Don't know about the more recent models. I don't work on anything these days held together with glue 🤣
    • AlexVG
      • Apr 2022
      • 138
      • SPAIN
      Thank you for the reply.
      But that's not it.
      My test mainboard boots without a battery.
      At the least, it should read the NAND. But it doesn't get to that point because there's no voltage on the NAND (3.3V)
      • GeirAndersen
        iPad .pcb file collection
        by GeirAndersen
        I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
        Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
        IPAD COLLECTION 1
        +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
        +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
        +---iPad mini3 820-00008(A1599) 820-00002(A1600)
        +---iPad mini4 820-00180(A1538) 820-00177(A1550)
        +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
        +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
        12-09-2024, 09:28 AM
      • garretofriviaaaaa
        iPad Pro 9.7" A1673
        by garretofriviaaaaa
        Hello, working on an iPad and there is no touch after replacing the battery even with 2 new screens. Need schematics so I can test the diode values on the FPC pins. Thanks...
        08-30-2024, 04:27 PM
      • jason0503
        iPad Pro 9.7" A1673 schematic need thanks
        by jason0503
        I've found the bitmap .PCB file on this forum (although many things are wrong with it, such as inductors labeled as resistors or capacitors), but I can't find the schematic. Can anyone share it? Thanks.
        09-19-2025, 02:48 AM
      • trepachka
        iPad Air A1475 Boot loops after replacing battery
        by trepachka
        This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
        The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
        I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
        11-08-2024, 03:17 PM
      • ipatch
        ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
        by ipatch
        i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
        08-24-2024, 02:36 PM
