Philips 19PFL5522D/05, psu clicking
  • Sylvester
    • Nov 2006
    • 67
    Delta PSU PHPWR0000159, DAC-12M057 AF,
    2995307100 rev 00, with bloated GL & KF capxon's, will replace them all but wondering what is the best replacement for them? I was going to use pana FR's, the 2200uF 10v can't be more than 20mm.
    1x 22uF 50v GL
    1x 2200uf 10v GL
    all the rest KF
    5x 470uF 16v
    1x 470uF 25v
    4 x 1000uF 10v
    [/URL][/IMG]
    [/URL][/IMG]
    [/URL][/IMG]
    [/URL][/IMG]
    [/URL][/IMG]
  • selldoor
    Slow Learner
    • 7870
    Re: Philips 19PFL5522D/05, psu clicking
    Yes panasonic FR FM or FC will do FR =best
    You may find not all sizes in one series.
    Check you have the physical space.
    Online orders from cpc.com are post free at the moment - no min order.
    If you have to post further pictures please use manage attachments rather than posting in line.
    and off site. ( They will disappear in time possibly losing the sense in the thread)
    • Sylvester
      • Nov 2006
      • 67
      Would the pana EB series be ok for the 22uF 50v?
      I'll look at changing the pictures.
      • selldoor
        Slow Learner
        • 7870
        No idea never heard of EB series if that is the start up cap id use an FR - but then again I would use FR FM or FC if they fit for everything then looks at low esr Rubycon then nichicon ( but cpc dont often have nichicon.)
        Are you asking because you have some ?
        -perhaps wait for others to comment.
        • Sylvester
          • Nov 2006
          • 67
          No, just one source I use only had an EB listed for that one.
            EB is the general purpose 105c rating cap, that will be find for the 22uF 50VDC for startup cap.
            • Sylvester
              • Nov 2006
              • 67
              All done, slight problem with a pad lifting, the -ve side of c111 22uF 50v and after a lot of head scratching and looking at it closely the track was also attached to zd111 which I bridged with the cap leg, can anyone confirm this with a schematic?
              • Sylvester
                • Nov 2006
                • 67
                Re: Philips 19PFL5522D/05, psu clicking.
                Board refitted and tv working, thanks for the input.
                Unable to edit title to fixed
                • B0r1s
                  Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                  by B0r1s
                  PSU - BN44-00878A
                  Symptoms:
                  The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                  A weak clicking sound was coming from the transformer.
                  Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                  Progress:
                  After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                  01-17-2023, 04:58 PM
                • G33RT
                  Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                  by G33RT
                  Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                  It does power up when pressing the power button.
                  I already try the power button while plugin the plug with no result.
                  Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                  Could this be an PSU or eMMC issue ?
                  07-19-2025, 03:43 AM
                • double_DD
                  Philips curling iron - is this a common AC cable?
                  by double_DD
                  Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                  As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                  Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                  08-18-2025, 10:04 AM
                • janos6662000
                  Philips 47PFS7509/12 LCD TV problem
                  by janos6662000
                  Hi
                  I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                  When i applied cable signal to check image, i had normal picture, but TV was restarting.
                  I downloaded original firmware and applied the update, but the problem remained.
                  From a colleague i received a "factory package software" which is a lot bigger.
                  I made another firmware update, but still did not solve the problem.
                  Somewhere on the way the error got worse, because at the moment the...
                  08-12-2025, 12:54 PM
                • slimmy182
                  [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                  by slimmy182
                  Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                  I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                  Looking on google I found this:...
                  01-14-2023, 11:55 AM
