Sony XBR-52LX900 BL_ERR
  • Nicktronic
    • Mar 2023
    • 247
    Not so sure about that, it can be hard to tell from pictures but at least a couple of those solders on those transistors look a bit cracked, I would touch up any joints that look different than a good joint, it's pretty simple: https://www.google.com/search?client...h=541&dpr=1.09
    Yeah, I think the pics may be misleading you. Unless you can tell what ones you noticed specifically and I'll look at thos closer but I looked over the whole board and they look good.....nothing even questionable...
    • Nicktronic
      • Mar 2023
      • 247
      Originally posted by Davi.p
      Can i know how do you measure them? Usually is enough in diode mode every combination of pins, when mounted no one must show a drop near zero volt.
      Just followed a standard MOSFET test with them removed and meter in diode mode.
      How to Check N-Channel Mosfets 1) Set the DMM to the diode range.
      2) Keep the mosfet on a dry wooden table on its metal tab, with the printed side facing you and leads pointed towards you.
      3) With a screwdriver or meter probe, short the gate and drain pins of the mosfet. This will initially keep the internal capacitance of the device completely discharged.
      4) Now Touch the meter black probe to source and the red probe to drain of the device.
      5)You should see an "open" circuit indication on the meter.
      6) Now keeping the black probe touched to the source, lift the red probe from drain and touch it to the gate of the mosfet momentarily, and bring it back to the drain of the mosfet.
      7) This time the meter will show a short circuit (sorry, not short-circuit rather "continuity).
      The results from the point 5 and 7 confirms that the mosfet is OK.
      Repeat this procedure many times for proper confirmation.
      For repeating the above procedure each time, you will need to reset the MOSFET by shorting the gate and the drain leads using meter probe as explained earlier.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4467
        • Italy - Milan
        #63
        so you have a 0v between S and D all the time? if you turn black to D and red to S can you read the internal diode drop (0.5v)? And not least, do you read a short between D and G?
        • Nicktronic
          • Mar 2023
          • 247
          Not exactly, the steps I listed in post News- Leaking Capacitors Muck up Motherboards are all good except step 6 and 7. After going red to gate and back to drain, they both still read OL not continuity. That indicates bad MOSFETs, no?
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4467
            • Italy - Milan
            #65
            I see no steps in that post.. test G-D indicates you don't have a short in that junction and you don't have to replace IC that controls mosfet.. let's do things short, touch 3 legs of mosfets with something conductive to discharge them, then in diode mode try every combination of pins, (6 tests) ,no one must show near zero volt. STOP..
            • Nicktronic
              • Mar 2023
              • 247
              I wrote post News- Leaking Capacitors Muck up Motherboards had the steps. I don't know where that link came from.
              • Nicktronic
                • Mar 2023
                • 247
                What the f...... post 62
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4467
                  • Italy - Milan
                  #68
                  ok post 62.. ehm.. we are at post #42.. ehehe..
                  • Nicktronic
                    • Mar 2023
                    • 247
                    Says 62 on my screen lol......anyway go up a few posts and you'll see the step by step process I took.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4467
                      • Italy - Milan
                      #70
                      I already read all posts , if you want to follow my advices lets continue, otherwise i can quit..
                      • Nicktronic
                        • Mar 2023
                        • 247
                        I'm not saying I don't want your help, I thought we were just discussing what I've already done....anyway, here it is for reference again:
                        I will do the tests you said once I have time, thank you, i appreciate your help.​
                          • 12276
                          • U.S.
                          #72
                          Simple n-channel mosfet testing: https://www.youtube.com/watch?v=IF740E5bm84
                          • Nicktronic
                            • Mar 2023
                            • 247
                            Yeah, that's exact same procedure as my steps listed above. On both MOSFETs, after I turn on the MOSFET by putting positive lead to the gate and go back to the drain I get OLwhen I should get continuity. They are both faulty.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4467
                              • Italy - Milan
                              #74
                              when you touch red on S and blk on D do you get a 0,5? when doing your test are you touching well the pins? Opfen there is insulating oxide coating on used components and must put little pressure, the best is not to touch tinned ends..
                                • 12276
                                • U.S.
                                #75
                                Can you show a picture of Q6850 on the board?
                                  • 12276
                                  • U.S.
                                  #76
                                  A little more on solder joints: https://www.youtube.com/watch?v=UPf6p7A-ctU
                                  • Nicktronic
                                    • Mar 2023
                                    • 247
                                    No, it's removed.
                                    • Nicktronic
                                      • Mar 2023
                                      • 247
                                      0.3VDC on one MOSFET and 0.5VDC on the other MOSFET.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4467
                                        • Italy - Milan
                                        #79
                                        My soft suspect those are both good, waiting answer to all questions, but all the rest of my list are been tested good?
                                        • Diah
                                          • Feb 2013
                                          • 6440
                                          i did wrote before and again will wrote this last time... edge LED BL if they are cocktails will never working... this why i asked to do the BL-on Jumper early
                                          • Kingfreddie
                                            LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
                                            by Kingfreddie
                                            Ok.. this is the story:
                                            Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
                                            This is kinda how it looked, just that mine were at the bottom of the screen:
                                            09-11-2021, 01:57 AM
                                          • edugimeno
                                            Help findinf LED strips for TDSystems K32DLT1H
                                            by edugimeno
                                            Hi There!
                                            I bought a broken 32" TV today. It has sound but no image. I checked with a flashlight and it was missing backlight
                                            Disassembled down to the led strips and found this TV has been serviced before. Not sure if it was fixed, worked again for some time, and broke again, or maybe last repair wasn't successful
                                            Looks like on previous repair, the center LED strip was replaced with a different model, 7 leds in it instead of 8, but when checking LEDS one by one, leds on the center strip were brighter with same test voltage (multimeter in DIODE mode) so maybe the...
                                            11-05-2022, 03:36 PM
                                          • eccerr0r
                                            What to do with bad LED strips?
                                            by eccerr0r
                                            I suspect a lot of you have done a lot of repairs and end up with a lot of bad LED strips...what do you do with them?
                                            Wonder if I should get a pile of LED chips and try to replace the bad units for the heck of it, but I don't really need the strips at the moment because I bought the strips...
                                            Oh... and I think I got my TV working again, though not 100% I don't think, on a white screen I can see a bit of the ghost of the LED strips, must have done something wrong or the LED strips aren't quite the same as the original...
                                            10-22-2022, 12:27 AM
                                          • h4rdw4re
                                            Grundig 40VLE7131BF led strips doesn't light up
                                            by h4rdw4re
                                            Hi guys,
                                            I have one very old TV.
                                            Main problem I have with this tv is that led strips won't light.
                                            I measured voltage levels, and inverter input is 24V.
                                            other voltages are also ok.
                                            What I found is that removing and connecting again connector CN1 led strips lights for shorts time (but only once). When led strips lights up then light is uniformly spread on whole panel.
                                            First I thought that led strips are dead, but I'm quite sure that problem is not strips related.
                                            I don't know what voltage level is at output of inverter board (samsung SSL400_3E2A) and how...
                                            10-09-2022, 11:10 AM
                                          • mc900fthanna
                                            Visio M70-C3 LED replacement strips
                                            by mc900fthanna
                                            So... I have the patchy back light issue with my Visio M70, meaning some light up, others do not. I finally got around to testing the LED driver board and found that was not the issue (swapped another one in and the same issue persisted) and I am considering if i dare dive deeper into this TV and go after the LED strips.
                                            Right away i see that they don't seem to stock them anywhere out there (E700DLB0016-002) is a part number that i see a you tube / seller guy list out. He has a nice video of how to get into my exact TV out there: https://www.youtube.com/watch?v=0AcUPiN83Tg
                                            11-28-2022, 03:03 PM
