Grundig 40VLE7131BF led strips doesn't light up
  • h4rdw4re
    • Jun 2012
    • Bosnia and Herezgovina
    Hi guys,
    I have one very old TV.
    Main problem I have with this tv is that led strips won't light.
    I measured voltage levels, and inverter input is 24V.
    other voltages are also ok.
    What I found is that removing and connecting again connector CN1 led strips lights for shorts time (but only once). When led strips lights up then light is uniformly spread on whole panel.
    First I thought that led strips are dead, but I'm quite sure that problem is not strips related.
    I don't know what voltage level is at output of inverter board (samsung SSL400_3E2A) and how to measure voltage of LED1, LED2, LED3 and LED4.
    Measuring inverter output for lines LED1...4 to the ground while CN3 is connected (steady state) gives voltage levels as below:
    1. LED1->GND = 10.98V
    2. LED2->GND = 2.83V
    3. LED3->GND = 10.98V
    4. LED4->GND = 2.83V
    5. VCC->GND = 5.4V
    Voltage level at inverter board input is very stable and at 24.6V (no matter is display flicker or in steady state - stay sable).
    On inverter board there is CN2 connector where I can see signals as follows:
    1. GND
    2. PWM
    3. 3D_ENA
    4. V_SYNC
    I suppose that PWM is for display panel brightness, V_Sync is some signal for synchronization. Of course I can not measure nothing there because I don't have equipment here.
    Is it possible that two stripes (LED2 and LED4) create this behavior of inverter board, or this is inverter feature (regarding voltage output)?
    One note is that during removing and inserting CN1 connector inverter voltage output changes so VCC jumps to 24V, then even 60V. I suppose that this is because transient state. After second or a little more every voltages come to mentioned values.
    I will be thankful for any help.
    Inverter board is quite cheap but I want to be sure, if possible of course, to not buy something which is not broken...
    Please find attached pictures of boards.
    https://photos.app.goo.gl/DSQJ9k4wFaYdek2y6
    Thanks in advance.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Grundig 40VLE7131BF led strips doesn't light up
    Check your pins on the board for cracked joints.
    • nomoresonys
      • 12307
      • U.S.
      prolly bad backlights, compared to a lot of tvs it speaks very well that they lasted this long.
      • h4rdw4re
        • Jun 2012
        Just an update regarding led strips.
        After replacing led strips TV started working correctly.
        Thanks for helping me.
        • petehall347
          • Jan 2015
          • 4445
          well done .i hope you find something worth watching on it .
            Lithonia Lighting versus Light of America Compact Fluorescent product quality
            I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
            I also have back when Light of America had these light bulbs available for yard lights
            The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
            While the Lithonia lighting fixture has all most certain bulb failure
            So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
            I have only had this light fixture for not more than a year if it...
            07-02-2023, 03:45 PM
            LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
            This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-07-2024, 03:40 AM
            LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
            This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-06-2024, 09:10 PM
            09-06-2024, 08:40 PM
          • serious_electron
            Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
            by serious_electron
            Hello Everyone!
            I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
            06-28-2025, 02:57 PM
