Sony XBR-52LX900 BL_ERR
  • Diah
    • Feb 2013
    • 6440
    cocktails strips
    take clear photo on each strips front and end... will tell you how they are cocktails
    • Nicktronic
      • Mar 2023
      • 247
      Look over all the solder joints, some of them don't look too great, add a little solder to those that look suspect, careful not to bridge anything, search images bad solder joints if needed, it's something that should be done early in troubleshooting becuz sometimes it IS just a bad solder or two.
      What area did you notice the bad joints in?
        • 12276
        • U.S.
        #43
        You have it in front of you so you can see it best, images of bad joints there: https://www.google.com/search?client...h=541&dpr=1.09
        • Nicktronic
          • Mar 2023
          • 247
          Originally posted by Diah
          cocktails strips
          Is this what you want to see??
          • Diah
            • Feb 2013
            • 6440
            yours photo , show the other end of the strips..
            it show you have only 2 lines - * ... so where are the return line which it will go to the sockets??
            try draw yours BL strips on paper and how the socket connected... then you will be sure that the circuit are closed not remain open
            • Diah
              • Feb 2013
              • 6440
              no need any more photo i found you upload before here & here so you have 2 channel each have 2 strips together... just be sure the 2 strips at the end of them connected like that
              + of channel socket go to + first strips. , - of first strips go to + second strips , - of second strips go to - of the channel socket
              • Nicktronic
                • Mar 2023
                • 247
                Yeah, that's how they are wired
                • Diah
                  • Feb 2013
                  • 6440
                  then they are fine if you tested each on zener and LED....
                  you wrote at post #17 you have 6 red blinking... iits really 6 or it was typo???
                  • Nicktronic
                    • Mar 2023
                    • 247
                    No, really 6.
                    • Diah
                      • Feb 2013
                      • 6440
                      No, really 6.
                      check after yours IC data sheet then compare
                      • Nicktronic
                        • Mar 2023
                        • 247
                        Compare signals you mean?
                        • Nicktronic
                          • Mar 2023
                          • 247
                          Here is the datasheet for IC6501, it's the PFC controller, but the PFC circuit works. Does it also limit current for the backlights??
                          • Nicktronic
                            • Mar 2023
                            • 247
                            Looked over all the solder joints, they all look good to me.
                            • Diah
                              • Feb 2013
                              • 6440
                              slide out the wire of BL_ON from the socket.on PSU .. its pin on the socket connect it to T-CON _12V_ON which you have 3.3V when tv start.... see if the BL will come on
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4467
                                • Italy - Milan
                                #55
                                How do you measure the led output voltage? Must be measured ex. from Out1+ to Out1-.. From what i can read the schematics there is an high power boost for the + outputs that it is supposed to be maybe near the 350v caps voltage, then another less power booster for the negative outputs, maybe a power charge pump, it has also 350v caps on it with the + on GND, so since each channel is near 700v, strips are in series of 2, then each strip is supposed to have near 350v.... i think you must inspect both positive stage and negative stage power components for short.. let me watch later which ones.. maybe its only turning the positive stage..
                                PS: that are... D6853/6, Q6850, Q6854, R6933, R6939, R6864, D6850, D6852, C6858
                                • Diah
                                  • Feb 2013
                                  • 6440
                                  what the hell you are talking..... you shared here post #7 and post #10... then nothings.... what i drive the owner over you jump with your silly kids.... however you are every day here and join other threats....
                                  when you will stop this acting ????
                                  do you know why i ask him to do what i asked... if you clever enough explain. the porpoise of it.???
                                  when we will put end of this Admin... ???
                                  • Nicktronic
                                    • Mar 2023
                                    • 247
                                    Looks like I have two bad MOSFETS (Q6850 and Q6854). One was working but now is suspect. They are Sanyo K4096 (datasheet attached). I've ordered replacements. Will update when received and installed.
                                    Sorry Diah, I missed your post Share your ideas and successes!! I will see what happens after I replace the FETs.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4467
                                      • Italy - Milan
                                      #58
                                      Can i know how do you measure them? Usually is enough in diode mode every combination of pins, when mounted no one must show a drop near zero volt.
                                        • 12276
                                        • U.S.
                                        #59
                                        Not so sure about that, it can be hard to tell from pictures but at least a couple of those solders on those transistors look a bit cracked, I would touch up any joints that look different than a good joint, it's pretty simple: https://www.google.com/search?client...h=541&dpr=1.09
                                          • 12276
                                          • U.S.
                                          #60
                                          • Kingfreddie
                                            LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
                                            by Kingfreddie
                                            Ok.. this is the story:
                                            Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
                                            This is kinda how it looked, just that mine were at the bottom of the screen:
                                            09-11-2021, 01:57 AM
                                          • edugimeno
                                            Help findinf LED strips for TDSystems K32DLT1H
                                            by edugimeno
                                            Hi There!
                                            I bought a broken 32" TV today. It has sound but no image. I checked with a flashlight and it was missing backlight
                                            Disassembled down to the led strips and found this TV has been serviced before. Not sure if it was fixed, worked again for some time, and broke again, or maybe last repair wasn't successful
                                            Looks like on previous repair, the center LED strip was replaced with a different model, 7 leds in it instead of 8, but when checking LEDS one by one, leds on the center strip were brighter with same test voltage (multimeter in DIODE mode) so maybe the...
                                            11-05-2022, 03:36 PM
                                          • eccerr0r
                                            What to do with bad LED strips?
                                            by eccerr0r
                                            I suspect a lot of you have done a lot of repairs and end up with a lot of bad LED strips...what do you do with them?
                                            Wonder if I should get a pile of LED chips and try to replace the bad units for the heck of it, but I don't really need the strips at the moment because I bought the strips...
                                            Oh... and I think I got my TV working again, though not 100% I don't think, on a white screen I can see a bit of the ghost of the LED strips, must have done something wrong or the LED strips aren't quite the same as the original...
                                            10-22-2022, 12:27 AM
                                          • h4rdw4re
                                            Grundig 40VLE7131BF led strips doesn't light up
                                            by h4rdw4re
                                            Hi guys,
                                            I have one very old TV.
                                            Main problem I have with this tv is that led strips won't light.
                                            I measured voltage levels, and inverter input is 24V.
                                            other voltages are also ok.
                                            What I found is that removing and connecting again connector CN1 led strips lights for shorts time (but only once). When led strips lights up then light is uniformly spread on whole panel.
                                            First I thought that led strips are dead, but I'm quite sure that problem is not strips related.
                                            I don't know what voltage level is at output of inverter board (samsung SSL400_3E2A) and how...
                                            10-09-2022, 11:10 AM
                                          • mc900fthanna
                                            Visio M70-C3 LED replacement strips
                                            by mc900fthanna
                                            So... I have the patchy back light issue with my Visio M70, meaning some light up, others do not. I finally got around to testing the LED driver board and found that was not the issue (swapped another one in and the same issue persisted) and I am considering if i dare dive deeper into this TV and go after the LED strips.
                                            Right away i see that they don't seem to stock them anywhere out there (E700DLB0016-002) is a part number that i see a you tube / seller guy list out. He has a nice video of how to get into my exact TV out there: https://www.youtube.com/watch?v=0AcUPiN83Tg
                                            11-28-2022, 03:03 PM
