Philips PSU (715G7350-P01-000-002S) behaving funny
  • hervou
    Hervé
    • Apr 2024
    • 11
    • France
    Hi everybody,
    I briefly unburry the thread to give you a small update, in case someone keeps stats about defect components on this PSU. Well the TV is back to life after having replaced D9105 😍
    I'm really happy, as well as my mother in law since she can watch the tour de france now.
    Thank you a lot for your help !!!
    Hervé
    • Sasiccia
      • Feb 2025
      • Hungary
      Hi everyone!
      I seem to have stubled in a similar issue:
      My Philips model 43pus6401/12 tv doesn't turn on
      Not even the power led goes on
      I've looked for info online and gathered information on which are the most common fault points
      I've then procedeed to gather readings with my multimeter
      I would you be as kind as to help me out understanding which components seem faulty? :
      Component reading with multimeter:
      Fuse position F9902
      Ebay board
      ―⯈⊢ = 00.1
      200 Ω = 00.3
      Original board (Also faulty)
      ―⯈⊢ = 00.1
      200 Ω = 00.6
      Mosfet position Q8601
      Ebay board
      ―⯈⊢ = S+D=469, S+G=713 D+G=1
      200 Ω = S+D=1 S+G=1 D+G=1
      Resistor position R8601
      Ebay board
      ―⯈⊢ = 00.0
      200 Ω = 00.8
      ―⯈⊢ = 00.0
      200 Ω = 00.8
      Capacitor position C8626
      Ebay board
      ―⯈⊢ = 468
      200 Ω = 1
      ―⯈⊢ = Component not present
      200 Ω = Component not present
      Diode D8609
      Ebay board
      ―⯈⊢ = 068
      200 Ω = 68.8
      ―⯈⊢ = 069
      200 Ω = 69.0
      Integrated circuit position U8601
      I did not find a pinout online, so I only report the supposed continuity readings:
      Ebay board
      Pin 1+4
      ―⯈⊢ = 684
      200 Ω = 00.6
      Pin 1+2
      ―⯈⊢ = 680
      200 Ω = 00.6
      Pin 2+3
      ―⯈⊢ = 000
      200 Ω =00.6
      Pin 2+4
      ―⯈⊢ = 000
      200 Ω =00.6
      Pin 3+1
      ―⯈⊢ = 000
      200 Ω =00.6
      Pin 3+4
      ―⯈⊢ = 000
      200 Ω =00.5
      Pin 5+6
      ―⯈⊢ = 467
      200 Ω =1
      Pin 6+8
      ―⯈⊢ = 723
      200 Ω =1
      Pin 7+5
      ―⯈⊢ = 733
      200 Ω =1
      Pin 7+8
      ―⯈⊢ = 826
      200 Ω =1
      Pin 1+2
      ―⯈⊢ = 684
      200 Ω = 00.5
      Pin 1+4
      ―⯈⊢ = 659
      200 Ω = 00.5
      Pin 2+3
      ―⯈⊢ = 000
      200 Ω = 00.5
      Pin 2+4
      ―⯈⊢ = 000
      200 Ω = 00.5
      Pin 4+5
      ―⯈⊢ = 549
      200 Ω = 1
      Pin 5+6
      ―⯈⊢ = 745
      200 Ω = 1
      Pin 1+5
      ―⯈⊢ = 538
      200 Ω = 1
      Pin 2+5
      ―⯈⊢ = 553
      200 Ω = 1
      Pin 3+5
      ―⯈⊢ = 543
      200 Ω = 1
      Pin 4+5
      ―⯈⊢ = 542
      200 Ω = 1
      Diode D9105
      Ebay board
      ―⯈⊢ = 1
      200 Ω = 1
      ―⯈⊢ = 1
      200 Ω = 1
      SMD resistor R8616
      Ebay board
      ―⯈⊢ = 549
      200 Ω = 1
      ―⯈⊢ = 556
      200 Ω = 1
      SMD resistor R8617
      Ebay board
      ―⯈⊢ = 022
      200 Ω = 22.3
      ―⯈⊢ = 022
      200 Ω = 22.3
      SMD resistor R8618
      Ebay board
      ―⯈⊢ = 047
      200 Ω = 47.1
      ―⯈⊢ = 047
      200 Ω = 47.1
      SMD resistor R8619
      Ebay board
      ―⯈⊢ = 1
      200 Ω = 1
      ―⯈⊢ = 1
      200 Ω = 1
      It would be great if somebody could help me figuring this out
      Thanks a lot in advance,
      Kind Regards,
      S.
      • nomoresonys
        • 12312
        • U.S.
        Test the mosfets in diode mode: https://www.youtube.com/watch?v=IF740E5bm84
        • Sasiccia
          • Feb 2025
          • Hungary
          Hi nomoresonys​,
          I did test all most common fault points including mosfets in diode mode, I've shared my results above, the diode mode is marked as: ―⯈⊢
          If you could please help me understanding the readings, as I am not very experienced, that would be amazing,
          Thanks a lot!
          Kind Regards,
          S.
          • nomoresonys
            • 12312
            • U.S.
            Just follow the video linked in post #23, it's step by step.
            • Montse
              • Feb 2025
              • 15
              • Spain
              #26
              Hi all! I had the same issue than Hervé and changed D9105. Since then, the TV turns on, so it's alive again! Nevertheless the screen is in burning mode, so flashing full screen blue, red, green, white, etc in a cycle. I have watched many videos on how to fix this issue but none of them worked for me. Starting the TV after pressing On/Off button for 30 seconds. Press the button for 30 second after it is on already. Tried with all buttons in the remote control but nothing is displayed in the screen besides a full color at the time. I bought a repair kit for this mainboard so I have a few more components to change but as I am far from behing an expert, I prefer to do it step by step and only touch it again when it's necessary and at this point I am not sure if the board still has something damage or I should somehow reset the TV or something like this! Any suggestion/help is much appreciated.
              • nomoresonys
                • 12312
                • U.S.
                #27
                Try holding the power button on the tv til the tv shuts off, wait one minute, unplug tv from power for 5 minutes then try it.
                • Montse
                  • Feb 2025
                  • 15
                  • Spain
                  #28
                  Following a previous suggestion to Hervou, I was about to replace the mosfet besides the diode D9105 but I realized that the mosfet I have in the kit I purchased is not that one but Q8601. Should I buy that one or taking into account that the screen and ambilight are getting tension I should check something else?
                  Thanks a lot in advance!
                  Regards,
                  Montse
                  • Montse
                    • Feb 2025
                    • 15
                    • Spain
                    #29
                    Thanks for your advise! I have tried but the power button does not shut off the TV while holding it. I have tried pushing it a few times and finally it turns off. I waited the minute, unpluged for 5 minutes and it remains the same. I also have disconnected all buses and cleaned them... same result... any other idea?
                    thanks a lot!
                    • nomoresonys
                      • 12312
                      • U.S.
                      #30
                      Maybe try unplug it while it's on, wait a minute, hold power button for 30 seconds, plug back in and try it.
                      • nomoresonys
                        • 12312
                        • U.S.
                        #31
                        They usually aren't too hard to get out of aging mode, wonder if you have to enter service mode on this one to exit aging mode. Must be very careful if you do go into service mode, doing something wrong in there can brick the tv.
                        • nomoresonys
                          • 12312
                          • U.S.
                          #32
                          Try this if you have not, unplug tv for 5 minutes, hold power button on tv for 30 seconds, it lets everything discharge. Now plug power cord in while holding power button in, when tv comes on let go, wait a minute unplug tv from power, wait a minute then try it.
                          • Montse
                            • Feb 2025
                            • 15
                            • Spain
                            #33
                            hmmm... so far nothing is working... how can I get into service mode in this Philips? Any idea? When I press any key in the remote control I can see the led blinking like there is reception but does nothing. Is there any specific sequence to get to the service mode?
                            Thanks a lot for all your help!
                            • Montse
                              • Feb 2025
                              • 15
                              • Spain
                              #34
                              thanks a lot!
                              I just have found the sequence 062596 and OK but it also does nothing....
                              • nomoresonys
                                • 12312
                                • U.S.
                                #35
                                Wondering if this model updates without any remote clicks needed, if so you may be able to update the firmware thru a usb drive. Any Philips pros looking on?
                                • nomoresonys
                                  • 12312
                                  • U.S.
                                  #36
                                  Guess I'm missing something, it seems like it should be simple to get out of this mode but the usual methods don't seem to work, I'm stumped.
                                  • William1967
                                    • Nov 2017
                                    • 217
                                    • Netherlands
                                    #37
                                    The tv has an so called OPEN CELL panel/t-con, it goes in WBRG mode when there is 12V on the t-con but no data from the mainboard. Check the LVDS cable if there is no damage and check if there is data comming from the mainboard.
                                    • angelos
                                      • Dec 2012
                                      • 573
                                      • South Africa
                                      #38
                                      That's right what William1967 says. Sometimes you need to clean the LVDS cable on both ends as well as the connectors. I use benzene.
                                      • nomoresonys
                                        • 12312
                                        • U.S.
                                        #39
                                        That's good info. so it may be a mainboard issue. How to determine, should check anything on mainboard to try and narrow down to issue??
                                        • Montse
                                          • Feb 2025
                                          • 15
                                          • Spain
                                          #40
                                          OK, my Tcon is a LG v15 43UHD TM120 ver 0.4, P/N: 6870C-0552A. I attach a picture. I have disconnected all buses and cleaned them with an eraser (previously with the spray CRC 2-26 electro). Situation remains the same. What should I check in this board to ensure it gets data? I find it difficult to use the tester with all those pins so close to each other!
                                          • u666sa
                                            HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                                            by u666sa
                                            Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                                            Platform: ipa32 la-m024p rev 1b
                                            Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                                            I found a short on the other side:
                                            10-04-2025, 05:03 PM
                                          • supermattch
                                            HP 15dy-2021nr wont power on mystery volts
                                            by supermattch
                                            Hi everyone.
                                            I am diagnosing my personal laptop, because it wont power on and no leds light up.
                                            At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
                                            Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
                                            09-23-2025, 12:13 PM
                                          • alro7779
                                            Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                            by alro7779
                                            Hello, guys!
                                            The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                            09-14-2025, 12:25 AM
                                          • G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                            by G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                            It does power up when pressing the power button.
                                            I already try the power button while plugin the plug with no result.
                                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                            Could this be an PSU or eMMC issue ?
                                            07-19-2025, 03:43 AM
                                          • MisterAIL
                                            PS5 digital / No Power / No Beep / Good power supply
                                            by MisterAIL
                                            Brought a non functionnal PS5. Apparently only a bad PSU...
                                            No beep, nothing.
                                            After some tests i found this :
                                            - PSU is fine (12 volts stable)
                                            - 12 volts line is shorted
                                            - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                            - By the way, nothing change. No signal, no power, no beep.
                                            Mesuring all rails with my workbench psu (12 volts input)
                                            - 0.00 amp drawing
                                            - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                            03-12-2024, 03:24 PM
