i send you the fotos as possible with best quality i could
fu tv fl32050 stuck on logo
Your soldering is fine, try this dump again to check.Attached FilesComment
Between 4 and 8 pin there is 3.3v?Comment
so it seems all voltages are normal and the firmware has the problem must fit with my motherboard Εl. MS3663S-FE48 V1
if i cant find the proper firmware sir can i use a universal motherboard from aliexpress for my display so as not to throw the TV in the trashComment
Do you at least write the dump onto the chip correctly, write down the order of your actions and be able to read the contents and post it here, I will check what you have recorded.
If more than one dump did not help, then the problem may be in the processor itself.Last edited by lotas; 04-21-2024, 02:34 PM.Comment
ok i understood
i will do it on tuesday afternoon and i will tell you about
i used ch341a programmer and i did in my new chip 25Q64FV erase after blank
after i opened the file bin you send me and did write and at the end confirm
all the aboves had the result on the software new programmer that i used successComment
I understand that your board EL.MS3663S-FE48V1 is CV3663C-Q32?Last edited by lotas; 04-21-2024, 03:14 PM.Comment
I found another one, try it.
Aceline 32HEN1 EL.MS3663S-FE48V1 CX320DLEDM 25Q64Comment
hi sir lotas
last dump when i used it i leaved 30 second and after press the button of tv is working with stuck the aceline only one time when i press with remote control its working normal show me there is nor signal all the other times when is from standby and press remote control is stuck on logo
do you have to suggest me something ?Comment
Replace with a new flash, this one may have already been damaged by a lot of dismantling and soldering and wash this place of flux, there may already be degradation of the processor itself, the voltage on the motherboard may not be stable (large ripples), replace the electrolytic capacitors...Comment
I used a new chip and for confirmation I programmed another new one the same does I cleaned the area with ethanol the only thing left is the electrolytics just when I pass the program on the chip I catch it with the pins that the programmer has I do not stick it and when the writing finishes I confirm and it tells me successful to solder it and pass it betterComment
by x_orange90_xI just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
by G33RTPhilips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
It does power up when pressing the power button.
I already try the power button while plugin the plug with no result.
Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
Could this be an PSU or eMMC issue ? -
by justice171Hi everyone,
I'm working on a JVC TV for a client that's stuck on the "Wisdom Share" logo screen.
It's a model LT-50N795 with a board number TP.HV510.PC822. I attempted a firmware update via USB, and while the upgrade was completed successfully, the TV is still stuck on the Wisdom Share screen on reboot.
Has anyone encountered this issue before, or does anyone have any suggestions on possible solutions?
Thanks in advance!
by mr.DataHello,
This Macbook Pro 2018 boots up and then gets stuck on the logo.
All the normal methods of resetting this Macbook have been tried but do not work.
I cannot get into recovery mode and there is no bar displaying, it's just the white logo on a black background.
Any help would be greatly appriciated.... -
Hi guys i have my personal MacBook Pro 2015 820-00165 board that was working fine for more than a year and one day stopped working on my original Magsafe charger. It was turning on with my bench power supply. Opened it up and while diagnosing that somehow i ended up with a shorted smc.The line which was shorted was SMC_PM_G2_EN. I removed the SMC and short was gone. So all I had was another working donor board 820-3435 which i used to program it's SMC to 820-00165 using the SMCTOOL By MuertoGB.Took that SMC and use it on my 820-00165 board .And my board started working again. PPBUS_G3H 8.56V....1 Photo
- Loading...
