fu tv fl32050 stuck on logo
  • wolf1976
    • Oct 2023
    • 113
    • Ελλάδα
    sir do you have read this chip with ch341a or will i need an other programmer ?
    thanks on advance
    • lotas
      • Jan 2016
      • 4900
      • Russia
      thanks on advance
      Yes, it’s not I who should count it, but you, you have a TV, I gave an example of which chip you need to select in the programmer program. The rest is up to you!
      • wolf1976
        • Oct 2023
        • 113
        • Ελλάδα
        ok i understood just i wanted to be sure this programmer ch341a was suitable for this particular component before i desold it from pcb
        • wolf1976
          • Oct 2023
          • 113
          • Ελλάδα
          hi again As for the reading I did from flash memory there is a confusion in it the first time I read file 1 and all the next 5 times I read file 2 the strange thing is that when I did verify ic it always gave me an error but also with another spi that I tried the same did not make it sticky but I had put it on a special base for SPI that unlocks and locks
          Finally I uploaded a file from an akai mainboard but it wouldn't let me erase and blank so I passed it over now I stuck it and it's permanently standby it doesn't even get a command
          • lotas
            • Jan 2016
            • 4900
            • Russia
            What you got was not a dump, but complete garbage, as you read? Did you solder the flash through a clothespin or through an adapter on the programmer? Were the legs on the flash washed of flux with alcohol (maybe there was a bad contact)?
            • wolf1976
              • Oct 2023
              • 113
              • Ελλάδα
              #26
              I understood and I did both the stupidity and I passed another program from Akai TV with a similar chassis on top overwrite and now the TV is only on standby does not take any command so it is useless since I completely destroyed its first even defective file right?
              • lotas
                • Jan 2016
                • 4900
                • Russia
                #27
                These two dumps are completely destroyed and cannot be restored, here is a working dump for your hardware (main + panel), try it!
                • wolf1976
                  • Oct 2023
                  • 113
                  • Ελλάδα
                  #28
                  thanks a lot sir you are very helpful
                  just i want to ask you when i tried to do blank or erase on old flash ic it doesnt allo me and has a message writing register addresss protect
                  only when i did write it completes the proccess with success like overwrite i hope to understand
                  so on your opinion must i buy a new flash or is there other way ?
                  • lotas
                    • Jan 2016
                    • 4900
                    • Russia
                    #29
                    Before erasing, try unchecking all the checkboxes in the status register and executing “write”. If you can't make it your programmer, then install a new 25Q64 (from Winbond)​
                    • wolf1976
                      • Oct 2023
                      • 113
                      • Ελλάδα
                      #30
                      thanks a lot one more time sir
                      just if i dont have winbond like to advice me i will order from aliexpress when i test it i will inform you
                      • wolf1976
                        • Oct 2023
                        • 113
                        • Ελλάδα
                        #31
                        sir i wanted to ask because i want to order winbond 25q64 as you tell me
                        what exactly
                        25Q64FVSIG ? 25Q64FWSIG ? or 25Q64BVSIG? is more suitable for my case ?
                        • lotas
                          • Jan 2016
                          • 4900
                          • Russia
                          #32
                          25Q64FVSIG, 25Q64BVSIG
                          • wolf1976
                            • Oct 2023
                            • 113
                            • Ελλάδα
                            #33
                            thanks
                            • wolf1976
                              • Oct 2023
                              • 113
                              • Ελλάδα
                              #34
                              sir i used your file but unfortunately for me its not working
                              its going on standbybut it doesnt turn on either from button or from remote control
                              • wolf1976
                                • Oct 2023
                                • 113
                                • Ελλάδα
                                #35
                                i used winbond 25q64hv i did and confirm after writre all are success
                                probably the file is not compatible with mine tv do you have other file ?
                                • lotas
                                  • Jan 2016
                                  • 4900
                                  • Russia
                                  #36
                                  Is there anything else missing on your TV? During dismantling and installing the chip, nothing was damaged, were there any nearby components?
                                  • lotas
                                    • Jan 2016
                                    • 4900
                                    • Russia
                                    #37
                                    winbond 25q64hv - Does such a chip exist?
                                    • wolf1976
                                      • Oct 2023
                                      • 113
                                      • Ελλάδα
                                      #38
                                      sorry 25Q64FV
                                      • lotas
                                        • Jan 2016
                                        • 4900
                                        • Russia
                                        #39
                                        You can post a high-quality photo with this chip, I want to see how things are in this place.
                                        • wolf1976
                                          • Oct 2023
                                          • 113
                                          • Ελλάδα
                                          #40
                                          i understood sir lotas
                                          By tomorrow noon I will have sent it
