Help me verify my NAND dump (attached) from LG SK10Y soundbar stuck in PLEASE WAIT - is it missing critical data?
  • Daniel Larsson
    • Feb 2025
    • 16
    • Sweden
    I’m trying to bring a LG SK10Y soundbar back to life. Currently it is stuck in the “PLEASE WAIT” loop.
    My conclusion so far is that something fails to boot fully, but it does start via eARC and can play perfectly good sound until watchdog shuts it down.
    After dumping NAND with a T48 programmer, extracting with binwalk and exploring with Ghidra I think:
    • Kernel B is present, but no Kernel A. Is that normal?
    • SquashFS A/B are present
    • Bootloader is present
    • UBI region is completely empty (only volume 0 / layout volume exists)
    • No system.cfg, no dsp config, no wifi config, no calibration, no logs
    Can someone have a look at my dump, or provide a working dump (or the UBI volumes) from a SK10Y/SK9Y unit?
    Any help is much appreciated!
  • Daniel Larsson
    Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
    by Daniel Larsson
    My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
    I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
    During these seconds the function button is not working...
    08-13-2025, 10:29 AM
  • tranquility
    Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
    by tranquility
    i want to repair an Onkyo TX-NR809 receiver.
    symptoms:
    on power on, display appears and i hear one click. enue functions is given.
    - no hdmi output
    - audio output not tested, but i think it is not there
    - usb sticks are not recognized
    if i read out the chips with display+standby button + tone+
    both dts show only ????
    chip is D830K013BZKB4
    things i have done:
    - reflow of the dts chip without taking off and reballing
    - changed the aluminium caps without the big one with 25v because i dont...
    08-25-2025, 01:04 AM
  • pauldow
    LG SN9YG Soundbar - Stuck with Please Wait
    by pauldow
    Another dump find, so someone must have given up on it already.
    The list price was $700, so I figure it's worth giving it a try.
    When I plug it in, the display briefly says Hello, then the volume level, the scrolls Please Wait. There are 4 LEDs under the display words that go in a three second loop of 2 inner on, all 4 on, all 4 off.
    From the remote, the volume level changes on the display, but that seems to be the only activity.
    The owners manual says to hold the microphone mute button for 5 seconds to reset, but nothing there.
    06-12-2023, 10:17 AM
  • cheebster
    MacBook Pro 2019 A2141 820-01700 NAND Issue Stuck in DFU
    by cheebster
    Ok, here's an issue ive got on a A2141 820-01700 MBP 16' 2019. No signs of life, 5.06v 0.0a on usb-c meter, on each 4 usb-c ports.
    Nand voltages are missing.
    I've found no shorts at all so far, no signs of heat via thermal camera either.
    PPBUS_G3H 12.31
    PP3V3_G3H_RTC 3.387v
    PP3V3_G3H 12.31v
    PP2v5_NAND_SSD0 0v 58 ohms
    PP2v5_NAND_SSD1 0v 57.8 ohms
    PP1v8_SLPS2R 1.8v
    PP1v1_SLPS2R 1.1v
    P3V3_G3H_SOCPMU 3.37v
    PP0V9_SLPDDR 0.9v...
    10-11-2023, 11:31 AM
  • Stunt
    Hp Laptop Stuck on Hp protected by hp sure start screen
    by Stunt
    Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
    I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
    I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
    Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
    screen that's it and stuck there. I left it until the following day and i still...
    09-02-2025, 01:51 PM
