Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4329
    • Italy - Milan
    #81
    You are right with doubt on power board, if 1²v (sorry, my phone screen keyboard is getting mad) or ²4v are low then tcon does not start well and tells the MB it hàs à problem, but your action of buying à power board is so rookiē, power boards càn be easily tested on bench, and tcon? have you followed my purchàse advices? For the tcon doubts i understand but i only pàrtiàlly agree.. i will explain in future..
    • odie34
      • May 2016
      • 41
      Davi.p Both the T-Con and power board are returnable. I could see trying to fix the original power board if it turns out that that’s the problem, although in that case I’d probably sell the one I bought rather than returning it. (It doesn’t seem right to return a part that aided in the repair… and I got a good deal on it.) The bottom line is that I was running out of patience and needed to be able to definitively rule some things out.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4329
        • Italy - Milan
        #83
        Try a first step with simple hair dryer at max temp, this is not a reflow obviously but we don't need it i think..
        • odie34
          • May 2016
          • 41
          I received the replacement power board and T-Con today. I installed them one-at-a-time, but the problem still remains… The TV turned on and acted fine, but then shut down a few seconds later. At this point the only things left are the main board and the panel. The panel seems more likely given the other tests we’ve done, although the screen looks perfect for the few seconds while the TV is on. I suppose it could be a problem with the LVDS cable, but how often does that happen? Any suggestions?
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4329
            • Italy - Milan
            #85
            5 flashes seems panel at this point but try at power off with hairdryer on the MB processor, then turn it on, if the defect varies bad processor soldering, try also to Ram/Rom..
            • odie34
              • May 2016
              • 41
              I know that you can remove one of the two cables between the T-Con and the panel on standard (non-OLED) TVs to help identify where a short is in the panel. Can you do the same thing with OLEDs or might that damage something? (It would be a pretty definitive test if the TV stayed on when connected to one side but not the other.)
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4329
                • Italy - Milan
                #87
                you can do it
                • odie34
                  • May 2016
                  • 41
                  Sorry that it's taken so long, but I wanted give a quick update to everyone who has helped me through this process... Unfortunately it turns out that the problem was a bad panel. Over the course of my tests and board swaps I was finally able to get definitive proof, which can be seen about 12 seconds into the video at https://youtu.be/HD1rEY37GRY
                  You can see a thin black line about 10% down from the top of the screen. Very disappointing, but it was fun working on it and I really wanted to thank you all for your help. Hopefully I'll have better luck next time.
                  • Diah
                    • Feb 2013
                    • 6374
                    still yours OLED usable, don't trash it, try to isolated the error sos signal rail... or add load like lamp to the EVDD line to handle and take any over load current so the the SOS will not trick on..
                    • odie34
                      • May 2016
                      • 41
                      Darn! I didn't realize that that was a possibility. I thought that there was nothing to do if there was a short in the screen so I recycled it. Next time...
                      • EazyBone
                        • Jun 2023
                        • 1329
                        • United states
                        #91
                        The boards were worth like $200-300 on eBay also
                        • odie34
                          • May 2016
                          • 41
                          I still have the boards. I'll list them when I have time...
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4329
                            • Italy - Milan
                            #93
                            it could have tried something to save it, if you are in time tell me..
                            • odie34
                              • May 2016
                              • 41
                              Sorry.. it's already gone, but I'll know for next time. Thanks for all of your help.
                              • Dan20701
                                Dahua XVR Hard Reset, Locked 8 Channel CCTV NVR
                                by Dan20701
                                Hello all just wondering if anyone knows how to do a hard reset on this model, XVR58C-21D-8CH-V1.1 ?
                                There are videos on youtube for every other model but this one, I do not have the switch on the board or reset jumpers.
                                https://www.youtube.com/watch?v=Ao7EwIMDx_c
                                I do have 2 little pads right next to the firmware chip, I have shorted these and powered the system on and waited a wile
                                with no luck. I will add picture of these 2 pads.
                                I do have the bin file from the firmware if its any good to anyone maybe able to edit out the pass I am not sure.
                                02-28-2025, 09:13 AM
                              • ash91
                                Hp pavilion 15 not detect hard drive
                                by ash91
                                Hello gentelmen .... this is my first post and sorry for my bad english,
                                so my proplem is my laptop keep losing hard drive even if i but the
                                hard disk in the cady (the box that can replace the dvd rom with hard disk)
                                when i turn the laptop on the massage that said no boot media found pop on
                                the hard disk is fine and to be sure i try another hard
                                i also update my bios to the last update
                                the 5 volt is present on the hard connector on the motherboard
                                the dvd rom work fine when i but a windows dvd in it
                                also when i boot from flash...
                                06-07-2023, 01:45 PM
                              • madura2010
                                DAY11AM6E0 hard disk drive and optical disk drive not detected
                                by madura2010
                                Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                                i checked the connectivity of ribbon=good communication with hard and motherboard
                                changed hard disk and checked=3f0 error persist
                                sata power=+5v available
                                Then checked data capacitors=all good
                                Then checked data lines path connectivity to pch=all good
                                reflashed...
                                03-12-2023, 09:09 AM
                              • MikeRWK
                                Westinghouse WD40FW2610 hard reset?
                                by MikeRWK
                                Are there any points on this board I can short to hard reset this TV? It won't save any tcon settings in the service menu....
                                06-21-2021, 11:08 PM
                              • CraigR
                                Hp x360 15-u499nr power light flashes continuously.
                                by CraigR
                                I have an Hp x360 15-u499nr laptop with a continuous white blinking power light. The laptop does turn on. The light flashes with just the battery and if I disconnect the battery and just use the power cord it still flashes and with both connected it still does. I have updated the bios and tried a hard reset with battery unplugged and power cord unplugged and holding down the power button for 60 seconds. I can't think of what else to try.
                                09-16-2024, 06:12 PM
