LG 49UF6409 No Picture, Backlight & Sound working
  • hendue
    • 16
    so my TV recently decided to stop working.
    At first, it sometimes showed just one color on screen after switching it on, but as far I remeber the menu still worked.
    Now theres no way to get it to that anymore, just a blank screen :/
    I've already tested unplugging either the right or left cable from the TCon to the panel, but neither halves of the TV had a picture (see attached files). The white half is always on the unplugged side, the other side stays blank.
    With the right cable unplugged, the right side faded to grey after leaving it plugged in for a while.
    Theres atleast the correct voltage appearing at both sides of the TCon's fuse.
    Does anyone of you has an idea, which part of the TV might be the issue?
    Thanks in advance
    • 12187
    • U.S.
    Might be a tcon issue, make sure the ribbon cables from tcon to driver boards are not damaged, can clean the ends with iso alcohol, some use a pencil eraser, not too vigorously they can be fragile, make sure the cable from mainboard to tcon is secure and clean also.
    • hendue
      • 16
      Thanks a lot for your reply, I'll clean the cables up and give an update later on
      • hendue
        • 16
        I checked & cleaned all of the cables now, but still yield the same results.
        Additionally, I've measured the voltages for all points, but I'm not quite sure how to interpret them:
        Fuse 13.16
        VDD 15.78
        VCore 1.2
        VCC18 1.8
        Pwm tout4 3.3
        Adim on 0
        Vcc 3.3
        Vin 13.15
        Hvdd 7.68
        Vgl1 -7.02
        Vgl2 0
        E0 0
        Gclk 1.2
        Gst 0.015
        Mclk 0.074
        Vgh_odd -7
        Vgh_even -7
        Vst -7
        Vcom2 5.54
        Vcomrfb 5.54
        V1 15.37
        V5 11.78
        V9 8
        V10 7.39
        V14 3.72
        V18 0.4
        CLK1-8 all 7.77
        Is there anything else I can test?
        • EazyBone
          • Jun 2023
          • 1328
          • United states
          Likely the panel went to shit. Someone cleaning the screen recently? Google fixing TV with tape and try that. If it works it's likely the panel. but yes maybe small chance is tcon
          • hendue
            • 16
            There was no cleaning recently and no Otter water damage. I already checked the resistors on the LCD Board for shortages.
            Taping the Board didnt seem to have an effect either.
            So it's not the panel but TCon or Mainboard?
            • EazyBone
              • Jun 2023
              • 1328
              • United states
              That doesn't eliminate the panel. It's still likely the panel. We don't have pics of the rest of the board. Generally you can disconnect the main board from power board. Then disconnect the main board to TCON board. Then you jump 3.3stby on PSU with TCON on and Blon and pw on. Plug it in andb. This will turn on BL and potentially cycle a image on the screen RGB colors
              • Storyteller12
                • Jun 2020
                • 624
                I’m almost positive these “UF” series TVs had a problem with the main board. I think it’s the processor if I’m not mistaken and a reflow will not work.
                • lotas
                  • Jan 2016
                  • 4598
                  • Russia
                  Your VGH signal is low, it should be +27v.
                  • hendue
                    • 16
                    Of which board do you Need more pictures?
                    I'm not quite sure whether I get your other instructions right. So I'm supposed to disconnect the cable between Mainboard & PSU. If I do so, the backlight stays off for whatever reason. Additionally, the LVDS or the power cable between Mainboard & TCon needs to be unplugged?
                    And after unplugging the cables, the TV needs to be plugged in and is supposed to show the colored pictures?
                    • hendue
                      • 16
                      That's sad to hear. But thanks a lot for your information!
                      • EazyBone
                        • Jun 2023
                        • 1328
                        • United states
                        Ahh now that we have the picture the test I told you will not work. Sometimes sonys have direct power to TCON from PSU. This doesn't. Not sure where else to direct you here. Some other more experienced people may have suggests
                        • hendue
                          • 16
                          Alright. I just ordered a new TCon & Mainboard and keep you updated, if one of these will be able to bring it back to life.
                          • EazyBone
                            • Jun 2023
                            • 1328
                            • United states
                            Yea hopefully. Give us the update I'm curious
                            • hendue
                              • 16
                              The spare parts just arrived and after replacing the mainboard, the TV is working again!
                              Thank y'all for helping me out
                                • 12187
                                • U.S.
                                Good call.
                                • EazyBone
                                  • Jun 2023
                                  • 1328
                                  • United states
                                  Yea nice call. Good to know
                                  • TR103
                                    by TR103
                                    - it keeps rebooting
                                    01-22-2025, 04:12 PM
                                  • ChaosLegionnaire
                                    by ChaosLegionnaire
                                    09-13-2022, 09:02 AM
                                  • ashyt16
                                    Toshiba TV bad panel half screen dark - pull tabs or not?
                                    by ashyt16
                                    Hi fellas, I have a Toshiba 50u6863db (vestel crap) here belonging to a family member.
                                    The TV was given me to repair (possibly) as it had developed a blank screen, just back lights and sound.
                                    Upon further investigation it turned out one of her cats had sprayed on the screen as I could see it on the edge of the panel and tabs and it stank. Looks like it probably shorted the circuitry. I cleaned it up and still the same.
                                    I initially suspected Tcon board as none of the test points were showing correct voltages. Tried removing one LVDS cable at a time, same result....
                                    10-26-2020, 05:47 AM
                                  • MoreMagnets
                                    Sony KD49X8000H - Sound, backlight, no picture
                                    by MoreMagnets
                                    Hello all!
                                    This post will mostly just act as documentation for my undertaken troubleshooting steps for this TV. Advice will also be appreciated for things to try next
                                    Picked up the TV in thread title from a retail returns auction, symptoms were as described. I started my troubleshooting attempts by shorting the 19V PSU rail to the 3v rail with my multimeter... Doh. Big spark, dead PSU, TV not turning on anymore. Picked up a new mainboard and PSU locally from someone here in Sydney, wasn't sure if my butterfingers had killed both and was a big drive to pick them...
                                    10-23-2022, 09:31 PM
                                  • kca
                                    Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                                    by kca
                                    Hello all ~
                                    I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                                    This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                                    No picture. No sound.
                                    I tested all the voltages coming out of the power supply...
                                    10-12-2023, 05:23 PM
