LG 49UF6409 No Picture, Backlight & Sound working
  • hendue
    • 28
    so my TV recently decided to stop working.
    At first, it sometimes showed just one color on screen after switching it on, but as far I remeber the menu still worked.
    Now theres no way to get it to that anymore, just a blank screen :/
    I've already tested unplugging either the right or left cable from the TCon to the panel, but neither halves of the TV had a picture (see attached files). The white half is always on the unplugged side, the other side stays blank.
    With the right cable unplugged, the right side faded to grey after leaving it plugged in for a while.
    Theres atleast the correct voltage appearing at both sides of the TCon's fuse.
    Does anyone of you has an idea, which part of the TV might be the issue?
    Thanks in advance
    • 12331
    • U.S.
    Might be a tcon issue, make sure the ribbon cables from tcon to driver boards are not damaged, can clean the ends with iso alcohol, some use a pencil eraser, not too vigorously they can be fragile, make sure the cable from mainboard to tcon is secure and clean also.
    • hendue
      • 28
      Thanks a lot for your reply, I'll clean the cables up and give an update later on
      • hendue
        • 28
        I checked & cleaned all of the cables now, but still yield the same results.
        Additionally, I've measured the voltages for all points, but I'm not quite sure how to interpret them:
        Fuse 13.16
        VDD 15.78
        VCore 1.2
        VCC18 1.8
        Pwm tout4 3.3
        Adim on 0
        Vcc 3.3
        Vin 13.15
        Hvdd 7.68
        Vgl1 -7.02
        Vgl2 0
        E0 0
        Gclk 1.2
        Gst 0.015
        Mclk 0.074
        Vgh_odd -7
        Vgh_even -7
        Vst -7
        Vcom2 5.54
        Vcomrfb 5.54
        V1 15.37
        V5 11.78
        V9 8
        V10 7.39
        V14 3.72
        V18 0.4
        CLK1-8 all 7.77
        Is there anything else I can test?
        • EazyBone
          • Jun 2023
          • 1362
          • United states
          Likely the panel went to shit. Someone cleaning the screen recently? Google fixing TV with tape and try that. If it works it's likely the panel. but yes maybe small chance is tcon
          • hendue
            • 28
            There was no cleaning recently and no Otter water damage. I already checked the resistors on the LCD Board for shortages.
            Taping the Board didnt seem to have an effect either.
            So it's not the panel but TCon or Mainboard?
            • EazyBone
              • Jun 2023
              • 1362
              • United states
              That doesn't eliminate the panel. It's still likely the panel. We don't have pics of the rest of the board. Generally you can disconnect the main board from power board. Then disconnect the main board to TCON board. Then you jump 3.3stby on PSU with TCON on and Blon and pw on. Plug it in andb. This will turn on BL and potentially cycle a image on the screen RGB colors
              • Storyteller12
                • Jun 2020
                • 625
                I’m almost positive these “UF” series TVs had a problem with the main board. I think it’s the processor if I’m not mistaken and a reflow will not work.
                • lotas
                  • Jan 2016
                  • 4892
                  • Russia
                  Your VGH signal is low, it should be +27v.
                  • hendue
                    • 28
                    Of which board do you Need more pictures?
                    I'm not quite sure whether I get your other instructions right. So I'm supposed to disconnect the cable between Mainboard & PSU. If I do so, the backlight stays off for whatever reason. Additionally, the LVDS or the power cable between Mainboard & TCon needs to be unplugged?
                    And after unplugging the cables, the TV needs to be plugged in and is supposed to show the colored pictures?
                    • hendue
                      • 28
                      That's sad to hear. But thanks a lot for your information!
                      • EazyBone
                        • Jun 2023
                        • 1362
                        • United states
                        Ahh now that we have the picture the test I told you will not work. Sometimes sonys have direct power to TCON from PSU. This doesn't. Not sure where else to direct you here. Some other more experienced people may have suggests
                        • hendue
                          • 28
                          Alright. I just ordered a new TCon & Mainboard and keep you updated, if one of these will be able to bring it back to life.
                          • EazyBone
                            • Jun 2023
                            • 1362
                            • United states
                            Yea hopefully. Give us the update I'm curious
                            • hendue
                              • 28
                              The spare parts just arrived and after replacing the mainboard, the TV is working again!
                              Thank y'all for helping me out
                                • 12331
                                • U.S.
                                Good call.
                                • EazyBone
                                  • Jun 2023
                                  • 1362
                                  • United states
                                  Yea nice call. Good to know
                                  • kca
                                    by kca
                                    Hello all ~
                                    08-31-2025, 06:38 AM
                                  • TR103
                                    by TR103
                                    - it keeps rebooting
                                    01-22-2025, 04:12 PM
                                  • netgearnetgear
                                    TCL 43S423 TCON OR PANEL FAULTY???
                                    by netgearnetgear
                                    Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                                    08-20-2025, 06:04 PM
                                  • ChaosLegionnaire
                                    by ChaosLegionnaire
                                    09-13-2022, 09:02 AM
                                  • JohnML1975
                                    Samsung UA50TU8000W no picture and no sound
                                    by JohnML1975
                                    Hello All
                                    have seen posts on this model in here but my problem sounded different so thought i would create a thread
                                    TV will not turn on
                                    There is no standby light
                                    When I press ON button for remote the red standby light does flash but no picture and no sound
                                    From the back of the TV I can see the red light on the back of the mother board
                                    Holding torch to the screen I cannot see a picture
                                    I removed the back cover
                                    Observing the boards I cannot see any damage
                                    I disconnected the main board from the power supply
                                    the back...
                                    08-30-2025, 09:40 PM
