What these connections are called
  • bohaboha
    • Nov 2012
    • 1108
    • sweden
    Hi everyone, does anyone know the names of those contacts
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    They are cables, called ribbon or flat cables, 60 pins.
    I've torn one of these by mistake and just replaced with one with the same pin count and spacing from a plasma tv, it fit perfectly and the tv worked.
    • bohaboha
      • Nov 2012
      • 1108
      • sweden
      do all of them have 60 pins? I'm trying to put an ad on ebay but I can't find the right name so people get it others call them " buffer connection cables" or ffc cables
      Which is true, I don't know
      • diif
        • Feb 2014
        • 6978
        • England
        Any cable that is flat and flexible is an FFC.
        • kasfamily
          • Aug 2014
          • 776
          • Russia
          • electronics, music, movies, books
          For example
          qpwbm006zzpn
          https://aliexpress.ru/wholesale?Sear...LDJBKhFw%3D%3D
          • diif
            • Feb 2014
            • 6978
            • England
            The part number looks to be 69.55t24.t04 as doing a search online for that brings up results.
            • bohaboha
              • Nov 2012
              • 1108
              • sweden
              thank you all for your help .diif​ exatly what you say I haven't found this reference. has been put on ebay already sold .another question ar they compatible if the connectors would fit another screen ? as Biruslapio has said in the first answer " I've torn one of these by mistake and just replaced with one with the same pin count and spacing from a plasma tv, it fit perfectly and the tv worked" good to know
              • diif
                • Feb 2014
                • 6978
                • England
                That part number seems to be linked to different sizes of Samsung and also a Vizio TV.
                • scubacamper
                  Sharp Aquos LC-70C6400U Half Screen Dark
                  by scubacamper
                  I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                  Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                  when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                  05-03-2025, 12:19 PM
                • thstuff
                  Sony OLED XR-77A80J - Initially dead, now 4 Flashes
                  by thstuff
                  A) TV initially dead
                  B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
                  C) Was able to perform a Reset from Settings menu and completed out of box configuration.
                  D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
                  E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
                  12-26-2024, 09:10 PM
                • valvashon
                  Repair Success! Middle Atlantic UPS2200R-IP
                  by valvashon
                  Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                  Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                  02-06-2024, 12:54 PM
                • otaku_nut
                  Vizio E701i-A3 fixed but now has red vertical line
                  by otaku_nut
                  Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                  08-19-2025, 06:11 PM
                • Jackching
                  What is the end called on this wire?
                  by Jackching
                  Anyone know what the end is called on this gps wire?
                  https://www.amazon.ca/dp/B01N3QHLDE
                  I see you can buy gps antennas that have wires exposed and no cable ends. I need this end for my hondex plotter.
                  08-05-2024, 11:53 AM
