Vizio E322Ar Picture Problem
    I have this tv that has a problem I have never seen before.It looks like 20 or so different images. All voltages check out. I have attached pics. and any help would be great. This tv doesn't have a separate tcon board. Thank You in advance for all your help.
    Re: Vizio E322Ar Picture Problem
    one of the boards does the video processing, you will need to post pictures of the back side without the cover
      Here are the pics. I hope they help. If you need anything else please let me know. Thank You
        Do you think it's the board and not the display? I found a board on ebay for $45.
          did the tv do this out of no where ? or did it slowly happen ? usually if the display is starting to go you will see black lines over a normal image and they will get worse and worse so i would think its a board if it kind of happened out of no where
          does it do it in all the different inputs ?
          i wouldnt buy a board just yet, i would start with carefully taking the ribbon connector for the display off and cleaning with with alcohol or contact cleaner and reseating them after that im not sure if id spend 45 on a board we arent 100% sure will fix it for 32in lcd when the used market is pretty competitive for that size
            I tried cleaning and reseating the cable already. Yes it does it on all inputs, as soon as the tv turns on. There is no point that the pic. is good.
            I can not tell you when it started I just got the tv.
            The board seems very hard to get for a 32 inch tv they are all for a 42.
              Many Vizio sets seem to suffer from faulty voltage regulators or eeprom
              I would start by testing the regulators - for more info see here
              https://www.badcaps.net/forum/showpo...32&postcount=3
              what do they look like - pics are not quite clear enough for trouble shooting but
              there looks to be 2 VRs just below the ribbon cable socket on the main board.
              Did you clean and reseat the other end of the ribbon where it goes into the panel - no board at that end?
                Here are some more pics. hope they help.
                Is the 1.25v when tv is on or at stand by?
                Thank You for your help.
                  I did clean both ends.
                  There is a board that is attached to the screen.
                    Pics are worse? I would go in and edit the post and remove them.
                    Can you get at the panel board for a pic of it?
                      How's this?
                        Great
                        Here is a better link on testing VRs The other I now see related mainly to
                        adjustable ones
                        https://www.badcaps.net/forum/showthread.php?t=22231
                        My understanding is the main is driven by the 5v standby so try first on that.
                          The small vr by the ribbon is a 1117a and it reads
                          Pin1 0v
                          Pin2 1.198v
                          Pin3 3.3v
                          is this good?
                            Does it have any other description on the part number.
                            if it is a 1.2 fixed it is good otherwise not so sure.
                              The markings are
                              LD1117A
                              G12AOL
                              But shouldn't I read 5v on pin 3?
                              All readings are with the tv on.
                                There are 3 others that are 1117ag they all read
                                Pin1 0v
                                Pin2 3.3v
                                Pin3 5.0v
                                  Originally posted by johnpeg View Post
                                  The markings are
                                  LD1117A
                                  G12AOL
                                  They all seem ok This one is a 1.2v fixed
                                  http://html.alldatasheet.net/html-pd...X-TF3-C-T.html
                                  It will be fed 3.3 from one of the others that reduced voltage from 5v to 3.3v
                                  They do that as too much heat would be generated reducing 5v to 1.2v
                                    So what do you think is wrong?
                                    What should I do next?
                                      Pity no-one else has commented - even to say the panel is bad.
                                      Are you able to get the picture of the screen board?
                                      Recently someone suggested connecting a set to another tv using the scart out to a scart in - I suppose you could try that or try recording to a dvd or vhs tape
                                      If any of that works then it points to a panel fault.
                                      Also can you get to the menu despite the image and do a factory reset.
                                      Other desperate measures are heating boards with a hair dryer to see if it changes anything and gently prodding the boards with a non conductive rod.
                                      These tests are good to find physical problems - cracked joints loose pins and so on.
                                      Next step would be replacing the eeprom - if it is replaceable.
                                        I will try to get a pic of the screen board but I will have to take it all apart. I had it apart already and tried moving it and there was still no changed.
                                        I don't know how to do a scart out to a scart in test. I have tried heating it up and nothing changed. I did do a factory reset. No change.
                                        How do you replace the eeprom.
                                        I would just like to say thank tou for all your help on this.
