I think STR-chip is defective. You can try replacing it.
With power off, you can test from pin 5 to 3 on ohms mode, in circuit, then pull device and check again out of circuit.
fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
this is your power ic,pin one will have a dot on the surface
count anti-clockwise,you will have to check pins 3 and 5 ,with your meter on 200 ohm resistance,report the reading back,when you have done the voltage testing
well we all learn by making mistakes at times i would add some fresh solder to each pin of the ic your removing then use your solder wick these are also very usefull in my opinon if radio shack sells them http://www.amazon.com/Parts-Express-.../dp/B0002KRAAG
Well, I've definitely learned a lot and I'm really enjoying it, aside from the frustration.
I actually ordered that sucker last night with the expectation that I'd never be able to get this IC up. I've been practicing on an old Genesis board I had lying around, and I had such a hard time getting the caps out. The solder would hardly soak up into the wick. I managed to get 3 of them out, and I'm quite sure I've ruined them all.
But the solder around this IC came up much easier. Different quality of solder, maybe. I dun know.
Hopefully I haven't ruined the board or anything - I did make an effort not to leave the iron tip on it for no more than 5-10 seconds.
And I got the same readings with it off the board, so I guess it's a dead spider.
One thing of note, just noticed this, is that is 8-DIP type. Ideally you use 7-DIP which has that missing lead. You can still use 8-DIP but you would have to cut off the excess lead, which has no function.
Thanks for pointing that out. I noticed it as well yesterday and had a chat with a rep before ordering it - he checked it and confirmed that pin 6 is not used. I'm assuming that means it just isn't there. If not, I'll have to cut it.
Just out of curiosity, what could have happened to it to cause it to stop functioning?
I won't go into too much detail but basically it's a random probability that a device will fail.
So a device might have an MTBF (mean time between failures) of 50,000 hours, that's pretty typical for consumer electronics. Does this mean it will last 50,000 hours? Not necessarily. It means that if you had 50,000 widgets in the field, on average, one would fail every hour.
Other things, it can also be damaged by a power surge or moisture getting into the device before the soldering process, leading to early failure.
