Yes, you want the TV to do that power light up briefly.
You using 20VDC scale? 0.00V?
No short, so it must be in ckt that feeds that part.
Now I need you to test the macro mode of your camera. Best pic you can get of area around J38 (bottom, green side)? Need to see small parts and traces.
Didn't see those. I've highlighted some points to ohm out. Please test between the RED and each BLUE points in 2000 ohms. If I have the circuit right, they'll all show near zero.
Also, the part# of IC301 would help too
DDA002B is available, but appears to be a proprietary Delta part (most likely specifically marked rather than dedicated design, but it makes it hard to find a datasheet for it.)
You guys are really great at this, and I appreciate all of your help. I think if I were better at this, we would be farther than we are :/
I will retest in a bit, but I have a question. Someone on my local Craigslist just posted my exact same model and chassis for $35. It stays turned on, but no picture.
I'm thinking of offering him $20 for it and trying the power board in mine. I've been eying boards, and my chassis is out-of-stock everywhere, and if it ain't, it's $100 plus. There's one on eBay for $60, but what a hassle if it doesn't work. At least this way, I can see it working and only be out $20 if it doesn't fix mine.
No picture, there is a chance that big inverter transformer is bad, (if no backlight) but you can swap them over, it's just a lot of work.
