Alba 32880hdf Flashing standby
  • anotherdude
    • Feb 2013
    • 488
    Picked this up last night originally told stuck in standby (assumed just solid standby) but it flashes blue and red indicating a problem in the self check i think
    Anyway measured the voltages from the psu to the mainboard and the only one that currently stands out is the 12v reads 11.7 not really much of a drop but only one i'm really noticing
    BL inverter reads 25v which should be correct I think, tried the obvious disconnecting boards one by one etc
    any suggestions?
    Disconnected the main board and powered it up the 12v pin now reads 12.6v with the main board disconnected, points to a main board fault?
    edit2: looking through the 17pw25-4 schematic there is a 24v aud pin on PL805 but i read nothing at this pin when not connected to the main board, also the same when main board is connected
  • anotherdude
    • Feb 2013
    • 488
    Re: Alba 32880hdf Flashing standby
    any help, looked through a lot of previous posts with similar startup issues
      What's main board on this?
      • anotherdude
        • Feb 2013
        • 488
        17mb62-1
        only find it in stock in one place at near £40
          SCH:
          Locate TP202 PROTECT circuit and check voltage.
          • anotherdude
            • Feb 2013
            • 488
            Originally posted by tom66
            SCH:
            it reads 3.36v
              I think that's good. You might have corrupted firmware. It is possible to update the firmware but it's difficult, you need the BIN file and a USB memory stick.
              • vinceroger69
                • Mar 2012
                • 6714
                https://www.badcaps.net/forum/showthread.php?t=22989
                not sure if you read this post 21 onwards i guess
                • anotherdude
                  • Feb 2013
                  • 488
                  ye I did read that, but I can't see anything removable on this to put a new eeprom in, not sure how i'd go about only connecting up the yellow and black cables on there own to the touch panel on the lower bottom.
                  and thats a different board too, not sure if it matters but i know the touch panel is in a different position, also have tried without the tcon and still get the same, no glimpse of a backlight either
                  • anotherdude
                    • Feb 2013
                    • 488
                    this tom?
                    http://elektrotanya.com/vestel_17mb6.../download.html
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      well it was worth a read im sure you will sort it out.
                      • anotherdude
                        • Feb 2013
                        • 488
                        so for the hell of it I thought i'd plug in a usb drive to see if it got any activity the first time i plugged it in the pen drive lit up briefly for maybe 2 or 3 seconds and since then it no longer lights up showing power etc
                        I know this is probably nothing but the main board was outputting the 5v at least for the usb at one point
                        edit: again maybe nothing but thought i'd try anyway, powered the tv off by mains and connected a xbox360 (via hdmi) and powered it on, the xbox360 wont boot fully without a valid video signal the other end or something to say yes or however hdcp works, anyway I let the xbox360 sit there and it done nothing as it's supposed to, powered the tv on and got the flashing led on the tv but the xbox360 proceeded to boot as normal
                        So some part of the main board is still active, again maybe nothing but it's a start...
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          did you the update.
                          • anotherdude
                            • Feb 2013
                            • 488
                            did you the update.
                            no , no idea on how to even do it
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              im sure tom will be along to advise be good to know actually for future refrence.
                              did you read this https://www.badcaps.net/forum/showthread.php?t=29238
                              • anotherdude
                                • Feb 2013
                                • 488
                                ye i seen that too, judging from the post it seems he had access to the screen to update it etc whereas I don't
                                from reading you need to get to the service menu to do it, i'm guessing tom is talking about doing the update blind so to speak
                                  It is possible, but I'm not sure how. I heard it's related to inserting USB, and pressing some buttons on touch panel.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    quote from the link
                                    The flashing LED can indicate a short-circuit, so with the aid of the manual you need to check the voltage rails on the main board first. You will also get the same symptoms if the firmware is corrupted. I can send you the firmware I have for this model, which you shove on a USB stick, power down the TV (pull the plug), put the stick in the TV, hold "OK" on the remote, plug TV back in still holding OK down until LED responds, then let it do it's stuff and if successful the set will power up to the install screen after a minute or so.
                                    so do you need to see the screen? not sure
                                    • anotherdude
                                      • Feb 2013
                                      • 488
                                      quote from the link
                                      well that went tits up, done that with the update file on the stick, the led stopped flashing and remained blue the pen drive had acitivity, let it sit there for 5 minutes after no activity powered off and now have no led, the xbox360 no longer sees the hdmi either
                                      usb still gets activity and the led lights up briefly if i press buttons on the remote at power on
                                      seems it now does need a new main board
                                      • multimeter
                                        • Jan 2011
                                        • 739
                                        • united kingdom
                                        what EEPROM is on the main board?,maybee one that can be reset,using a pin to pin short,that might bring it back
                                        fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
                                        please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
                                        • PNI E.
                                          Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                          by PNI E.
                                          Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                          03-17-2025, 04:23 AM
                                        • Willem01
                                          TV not powering on - with standby red –led flashing
                                          by Willem01
                                          Error – TV not powering on - with standby red –led flashing
                                          Model- LEDTV – 39T3500
                                          Power boarD - shg3206a-101h
                                          I have read through the Basic LCD TV and Monitor troubleshooting guides.
                                          https://www.badcaps.net/forum/showthr...956#post305956, I am no ELEC engineer but can use a multi meter and soldering iron
                                          In the meantime I could not see any damage to any caps on the cold side of the power board, so I have replaced all of them.
                                          Unplugged the power connector on the board, I plugged the power cable in waited...
                                          02-27-2021, 08:23 AM
                                        • STKR123
                                          Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                          by STKR123
                                          As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                          I wonder if re-flashing the BIOS might be of any use here.
                                          As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                          There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                          11-03-2024, 06:58 AM
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • howardc64
                                          HiSense 65H6510G no boot
                                          by howardc64
                                          TV standby light flash once after plug-in AC power. Then silent. No backlight, no LCD image on flash light test, no SPDIF light.
                                          All PSU voltages to main looks good (12v, 20v (label says 18v but is 20), standby voltage) Probing main board shows what appears to be a DCDC converter (MSH6103A can't find datasheet) providing 5v, 3.3v and 1v. 5v present to the standby light power switch board.
                                          These HiSense TVs appears to have lots of firmware corruptions that takes out the main board either through smartTV use or firmware update. Used main board...
                                          03-29-2023, 12:52 PM
