LCD32880HDF problems
  • e3gsr
    • Aug 2012
    • 36
    • N Wales
    Hi guys me again.
    I have been given an Alba LCD32880HDF it turns on backlights come on, then blue screen with channel number etc, but the volume bar comes on and the volume is going down without touching any buttons, Then the screen just goes blank, but it has sound so i'm told. No source has been connected to confirm this. Do you think it may be the main board that is faulty? as the screen stays on for varying times the longest being when it is first turned on.
    I have noticed that the large chip on the board does get quite warm even in such a short time.
    Any help would be much appreciated, Thanks in advance.
    Neil
    Re: LCD32880HDF problems
    Is this a model with push buttons or a touch panel for buttons?
    • e3gsr
      • Aug 2012
      • 36
      • N Wales
      touch panel on the lower right hand side.
      • gilly1984
        • Jun 2012
        • 751
        Originally posted by e3gsr
        Hi guys me again.
        Neil
        Has the button board had anything spilled on it? I believe the buttons are at the top?
        I have a 22" alba/vestel in the bedroom, also have a 19" and sold a 15", they all had buttons on top.
        edit; Never mind, you answered as i was typing. 1 Finger typer here.
        Do NOT touch heatsinks when testing for voltages as they may be LIVE!
        • e3gsr
          • Aug 2012
          • 36
          • N Wales
          noting spilled on it as far as i can see, my buttons are on the right hand side this one is a 32" if that makes any difference. to be honest that was my first thought lol.
          • gilly1984
            • Jun 2012
            • 751
            Is the remote anywhere in the room?
            Sounds silly but might be causing the problems.
            Its prob not so lets just get that out of the way first.
            I always check the simple things first before anything as its them that have you over the most.
            • e3gsr
              • Aug 2012
              • 36
              • N Wales
              yep checked that as well removed the batteries. still the same. Sonds like you work the same as me easy to hard lol.
              • gilly1984
                • Jun 2012
                • 751
                Yep lol,,
                Well, i do the easy to medium.
                Then i ask the great guys here for the hard stuff.
                Always messed with electrical stuff, but still know so little.
                • sienoki
                  sienoki
                  • Jan 2012
                  • 314
                  Originally posted by gilly1984
                  Yep lol,,
                  Ive just done 1 of these n recapped the psu with panasonic caps..my problem was it didnt like starting up from cold..like new again n ready 4 a new home
                    Would take a stab at the touch board myself, try removing it and cleaning the capacitive touch contacts.
                    Sienoki's advice is also valid as he showed me this model with a bulging cap.
                    • e3gsr
                      • Aug 2012
                      • 36
                      • N Wales
                      Cant see any bulging caps at all,Tried disconnecting the touch board as its doing it and it carries on, So dont think its that but thanks for all the suggestions, keep them coming lol.
                      • e3gsr
                        • Aug 2012
                        • 36
                        • N Wales
                        just a quick question for you, I have been looking at mainboards for these and can anyone tell me what is the difference between v1-v4 will they all work in this tv as they all look physically the same.
                        • e3gsr
                          • Aug 2012
                          • 36
                          • N Wales
                          i think mine may be a version 1 as the number under the sticker is 17mb24-3 060309. can anyone confirm this?
                          • e3gsr
                            • Aug 2012
                            • 36
                            • N Wales
                            right guys quick update for you after having a fiddle when i came home i found that if you turn it on with the number buttons you get this screen. It will sit there at that screen for ages no problem so im guessing it is not power supply problems or am i wrong? it will also bring up another one if you try to change channels that has an ok button on it at this screen you can adjust the volume but the menus only flash up for a second then go off again.
                            Any thoughts?
                              OK try both of these methods:
                              Method #1
                              TV in standby.
                              Turn TV on.
                              Press MENU on remote.
                              Press 4, 7, 2, 5 in succession.
                              This should bring up factory menu - select RESET option.
                              Method #2
                              TV in standby.
                              Turn TV on.
                              • e3gsr
                                • Aug 2012
                                • 36
                                • N Wales
                                slight problem menus don't stay up long enough to do anything. Just flash up then disappear.
                                  Disconnect the touch panel and try again.
                                  • e3gsr
                                    • Aug 2012
                                    • 36
                                    • N Wales
                                    wont even turn on with it disconnected just flashes the power light constantly.
                                      Darn must be a chassis detect problem. Would be hard to eliminate that without unplugging it but TV detects this and doesn't like it.
                                      For Vestel just match the main board chassis part "17MB24-3" etc, the -3 is important and check the HDMI ports match.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        http://www.tv.quuq.org/forum/index.p...e;topic=5167.0
                                        might help?
                                        • karthur
                                          Vizio D65x-G4 Volume changes on its own
                                          by karthur
                                          On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
                                          It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
                                          06-05-2025, 08:13 AM
                                        • crackedprint
                                          Sony HCD-HX80R Amplifier Volume Control Problem
                                          by crackedprint
                                          I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                                          I have tried a Cold Reset as per the service manual.
                                          I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                                          I have looked all the way through the service manual and tried many online...
                                          01-21-2025, 12:18 PM
                                        • BigOof
                                          Marantz SR5007 popping on volume change and mute in Direct Mode
                                          by BigOof
                                          I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
                                          12-12-2024, 06:15 AM
                                        • jean luc ferre
                                          laptop hp g72 b52sf screen problems
                                          by jean luc ferre
                                          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                          i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                          06-07-2025, 03:27 PM
                                        • Storyteller12
                                          Samsung Soundbar Q900T Cuts Off if Volume above 30
                                          by Storyteller12
                                          I have this soundbar and when I turn it on it works until I turn the volume above 30.
                                          Then the display show “PROT” protection and shuts off.
                                          I can turn it right back on and it works until volume hits 30 again.
                                          There is a little static on the surround speakers so I unplugged them but still have same problem. I tried unplugging all speakers also and when volume goes above 30 it shuts off.
                                          I can turn the volume above 30 if nothing is playing but as soon as I play something it shuts off.
                                          It will play fine for hours with volume...
                                          03-21-2023, 12:31 PM
