Alba 32880hdf Flashing standby
  • anotherdude
    • Feb 2013
    • 488
    • uk
    #61
    Re: Alba 32880hdf Flashing standby
    big thanks to tom66 provided a working main board, the tv now functions properly
    thanks again tom
      Nice to hear! And I sure did have fun assembling all the plastics with the boards removed and taking to that screen with a sledgehammer. Amazing how much stress that relieves!
      • anotherdude
        • Feb 2013
        • 488
        • uk
        #63
        haha, thankfully the bent antenna input wasn't too bad and bent it back, I would of enjoyed doing that to the 50 inch plasma I had but that glass be sharp
          I took the boards out before smashing it. It came from the street with that antenna bent slightly. Given some of the brusing on the plastic, I'm figuring it fell off a cabinet, which would explain the bent antenna connector.
          Just realised the TV was in fact an Alba 32880HDF so exactly the same model.
          • anotherdude
            • Feb 2013
            • 488
            • uk
            #65
            seems you and I both had a bit of luck
              PSU will go in a Toshiba 32BV702B which is a rebadge Vestel junker... so that should be good too. Got the inverter and t-con too, but they're not really worth listing, don't got for much.
              So yeah, all in all, not bad.
              • anotherdude
                • Feb 2013
                • 488
                • uk
                #67
                nice that it was saved from the tip and even better that it's parts have been used to rectify other sets
                thankfully I only spent £20 on this alba set so £33 all in isn't too bad
                • service
                  • Jun 2014
                  • Ukraine
                  #68
                  Hi Everyone!
                  I'm sorry that I write in a foreign subject, this is my first messages to .
                  I'm looking for theALBA LCD32880HDF file.
                  Main board 17MB62-1.V1. Paper label - 26752668.
                  I have enough firmware to 17MB62, but I need the correct file mb62_en.bin.
                  Or someone tell me the website address support of ALBA
                  • comptek
                    • Aug 2013
                    • 606
                    • uk
                    #69
                    can i just add i have had those 17MB62-1 main boards dead/flashing light, tried all sorts checking power supply etc
                    last resort plugged in a thumb drive in the usb port switched on the mains and it has kicked them into life for some strange reason
                    regards
                    Gary
                    • mushy408
                      • Nov 2010
                      • 9
                      #70
                      Sorry to dig up an old thread but could someone upload the FW for the Toshiba 32BV702B? If needs be I can program the NAND/SPI externally if someone has the dump from one?
                        You can get the mb62_en.bin etc files on the Toshiba website if you have a windows PC, just select the right options and it will copy the files out for you:
                        mboot.bin is common to all MB62 boards so you can use any make file for that.
                        http://www.dl.toshiba.com/DLY/index....ion=GB&lang=EN
                        • mushy408
                          • Nov 2010
                          • 9
                          #72
                          Yes I've already downloaded the firmware for this LCD, Toshiba only provide 2 files in the archive but like you said all the mboot.bin files are generic
                          (I even opened & compared several using HXD)
                          This Toshiba will happily install FW all day long but only shows a pixelated screen (see pic). I've tried several FW and I either get:
                          Long blinking LED - bad FW update
                          TV powers up but displays black screen (backlight is working)
                          or
                          TV powers up but displays pixelated screen
                          My guess would be there is a specific FW for this board/panel combo?
                          Board is 17MB62-2.5 (TOSH) from a 32BV702b
                          All I can think of is the bootloader may be corrupted, but then the TV wouldn't allow USB updates, right?
                          If the bootloader is ok then it must be down to the FW being corrupt/incorrect.
                          Tom do you have any SPI & NAND dumps for this model? I have programmers/clips
                            I believe mb62_en.bin is a raw NAND file, so you could try flashing that. usb_auto_update.txt contains info on exactly what addresses writing starts at (included with most firmware dumps)
                            • mushy408
                              • Nov 2010
                              • 9
                              #74
                              I'll give flashing the NAND a try. The usb_auto_update.txt shows that the NAND is flashed with only 16Mb (mb62_en.bin) where as the NAND is 64Mb correct?
                              From what I can see the actual FW occupies the first 16Mb and the rest is used for filesystem (I could be wrong). When updating by USB only parts of the NAND is flashed so this to me seems like the issue.
                              I'm not 100% clear on what all the commands in the usb_auto_update.txt mean, but from looking at them from different FW downloads I can see certain options are enabled/disabled. All the flash addresses are the same.
                              I'll make a dump of the NAND as-is then program mb62_en.bin directly to it. My best guess at this stage is there is part of the NAND that is corrupt and USB flashing isn't touching the address(es) that need reprogramming.
                              Once I get round to pulling the NAND I will update on what happens as I go.
                              Thanks for your input Tom!
                              • PNI E.
                                Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                by PNI E.
                                Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                03-17-2025, 04:23 AM
                              • Willem01
                                TV not powering on - with standby red –led flashing
                                by Willem01
                                Error – TV not powering on - with standby red –led flashing
                                Model- LEDTV – 39T3500
                                Power boarD - shg3206a-101h
                                I have read through the Basic LCD TV and Monitor troubleshooting guides.
                                https://www.badcaps.net/forum/showthr...956#post305956, I am no ELEC engineer but can use a multi meter and soldering iron
                                In the meantime I could not see any damage to any caps on the cold side of the power board, so I have replaced all of them.
                                Unplugged the power connector on the board, I plugged the power cable in waited...
                                02-27-2021, 08:23 AM
                              • STKR123
                                Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                by STKR123
                                As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                I wonder if re-flashing the BIOS might be of any use here.
                                As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                11-03-2024, 06:58 AM
                              • cheeky2
                                by cheeky2
                                05-25-2024, 03:27 AM
                              • howardc64
                                HiSense 65H6510G no boot
                                by howardc64
                                TV standby light flash once after plug-in AC power. Then silent. No backlight, no LCD image on flash light test, no SPDIF light.
                                All PSU voltages to main looks good (12v, 20v (label says 18v but is 20), standby voltage) Probing main board shows what appears to be a DCDC converter (MSH6103A can't find datasheet) providing 5v, 3.3v and 1v. 5v present to the standby light power switch board.
                                These HiSense TVs appears to have lots of firmware corruptions that takes out the main board either through smartTV use or firmware update. Used main board...
                                03-29-2023, 12:52 PM
