TV not powering on - with standby red –led flashing
  • Willem01
    • Feb 2021
    • 45
    • South africa
    Error – TV not powering on - with standby red –led flashing
    Model- LEDTV – 39T3500
    Power boarD - shg3206a-101h
    I have read through the Basic LCD TV and Monitor troubleshooting guides.
    https://www.badcaps.net/forum/showthr...956#post305956, I am no ELEC engineer but can use a multi meter and soldering iron
    In the meantime I could not see any damage to any caps on the cold side of the power board, so I have replaced all of them.
    Unplugged the power connector on the board, I plugged the power cable in waited 30sec, plugged the connector back. The standby led remained on constant which showed me that it would power on..voila and it worked and we used it for longer than 2 hours. When I switched it off for longer than 40sec still in standby mode, it's flashing again and It would not power on, I had to disconnect the power connector again and got it to power up.
    Then we left it overnight in standby mode, even if I disconnect the power connector and plug it back in again it still stays on a flashing standby led – it does not want to power on anymore.
    I have measured the volts on pin- out's, with the gnd – poweron, bridged, I only get the 3.3v on both the rows, nothing for the 24v
    The power connector is divided in two rows
    DIM H-On….?
    GND P-On…bridged
    3.3v 3.3v….give me 3.3v
    GND 24V…..nothing
    24v 24v....nothing
    What gave up as it did work before and now nothing again, what else can I look at, don't see any visual signs off blown caps as they are all still brand new just replaced them, cant give a high resolution pic now only a crappy low resolution from the web.
    If anyone can give some advice, assistance would be appreciated
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: TV not powering on - with standby red –led flashing
    If you can post some photo's of your boards using the attachmnet would help.
    • Willem01
      • Feb 2021
      • 45
      • South africa
      I am not currently home, thought I could get some interaction while I get time to submit them later, much appreciated will upload later
      • Willem01
        • Feb 2021
        • 45
        • South africa
        pics uploaded also the diagram
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Disconnect the mainboard and use a 1K resistor and jumper between pin10 (P-ON) and Pin 7 or 8 (3.3V) and see if your 24V comes up
          Use another 1K resistor and jumper Pin 7 or 8 (3.3V) to pin 12 (BL-ON) to see if the backlights come on. All on CON3.
          The backlights also need the 24V supply to be working.
          • Willem01
            • Feb 2021
            • 45
            • South africa
            What is the purpose for using the resistor, if you only bridge the pins out without the resistor what will happen
            ns...I have no electronic background skills hence my question
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              If you were to make a mistake and connect between or to a wrong pin then you could damage the power supply. Example if you connected the 3.3V to ground then you may well have badly damageg the power supply. If you were using a 1K reistor then no damage would happen because the 1K resistor limits the current from the 3.3V supply to 3.3mA
              (3.3V/1K = 3.3mA)
              • Willem01
                • Feb 2021
                • 45
                • South africa
                I have done this and it returned 0 results nothing happens
                • Chrille
                  Chrille
                  • Feb 2021
                  • 21
                  • Sweden
                  Check this thread out.
                  https://www.badcaps.net/forum/showth...48#post1022048
                  Another model though but it seems to be a similar problem.
                  I finally found a bad chip (MP2363DN).
                  Seems to be a common problem on Samsung TVs.
                  /Chrille
                  • R_J
                    • Jun 2012
                    • 9607
                    With the power supply disconnected from the main board. You have 3.3v standby so you should have +24v at L1 (jumper wire) If you do then connect P-on pin to 3.3v standby and see if you get +24v on Con3 pin 1,2 or 4
                    • Willem01
                      • Feb 2021
                      • 45
                      • South africa
                      I have bridged out the 3.3v and the P-On pins, then measured the volt readings on pin1, 2,4 and there is nothing.
                      Like you have explained with the power cord removed I still only have the 3.4v in standby.
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        What voltage do you have on the D(rain), G(ate), S(ource) pins of Q2 in standby and then when out of standby when you jumper P-ON to 3.3V using the 1K resistor
                        • Willem01
                          • Feb 2021
                          • 45
                          • South africa
                          Hell for the heck of me I cant find Q2 on the board I only see Q4 is it that thing under the big heatsinks there are 2, which one of them....think I found something on the board but there is nothing mounted
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            The components may be on the other side of the board. Post a photo.
                            What voltage do you have at L1 to chassis.
                            • Willem01
                              • Feb 2021
                              • 45
                              • South africa
                              Aha...see when you know your trade you know your stuff found it
                              this is a pic taken earlier as i am not at home to check the v ,,,
                              will do so and report back.
                              • Willem01
                                • Feb 2021
                                • 45
                                • South africa
                                I will add the rest of the powerboard in a few pics split up to see better, kindly indicate where to find L1 and how to measure it with the multimeter ( where must I put the red and black leads )
                                You make me sound stupid - but I know nada of these electronic stuff
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  L1 is shown in the photo in post #13
                                  Red meter lead on L1, black on chassis. Meter set to 20V DC
                                  • Willem01
                                    • Feb 2021
                                    • 45
                                    • South africa
                                    8v
                                    • Willem01
                                      • Feb 2021
                                      • 45
                                      • South africa
                                      In and out of standby the voltage fluctuates from 7.5v to 8.3v
                                      • Willem01
                                        • Feb 2021
                                        • 45
                                        • South africa
                                        V at the jumper wire fluctuates at 7.5 v - 8v,, when on standby or not , still zero volts on the 24v pins
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • STKR123
                                          Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                          by STKR123
                                          As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                          I wonder if re-flashing the BIOS might be of any use here.
                                          As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                          There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                          11-03-2024, 06:58 AM
                                        • Green Probe
                                          Recapping a Denon AVR X6400h SMPS
                                          by Green Probe
                                          (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
                                          Disclaimer: I'm an amateur hobbyist and will get things wrong.
                                          Always use caution when working around mains power and high voltage capacitors!
                                          Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
                                          SYMPTOMS:
                                          -No display...
                                          07-18-2025, 03:36 PM
                                        • e-repair
                                          Broken connector on an electric boat power steering
                                          by e-repair
                                          Hey, i have to repair an electronic board on an electric power stearing. the package was damaged during delivery and the connector was broken. but i can't find a part. the connector is the same BUT reversed as fiat power steering. I searched on digikey, mouser and aliexpress and i can't find any part similar. it's an uflex electric power steering, but i don't have more reference on the power steering block. if needed, i can buy any complete part just to recover the conector on the board and put it on this board...
                                          09-24-2025, 07:30 AM
                                          03-31-2024, 02:12 PM
