lg 37lc2d power board #6709900016D
  • Tvbob
    tvbob
    • 204
    Could any one post the values of c163,c125 c502 c161 This set was slow to come on, I could hear the power supply squeal lightly. It would come on in about 40 seconds. Butt I got the 4.7uf and the 47uf mixed up I think...I am getting old. Photo from shopjixxy
  • tw2005
    • Oct 2011
    • 6458
    Re: lg 37lc2d power board #6709900016D
    I found this http://tvrepairhelp.webs.com/lgjvc.htm
    If you look at the 32LC2D post, mentions C125 as 4.7uF 50V. Both PSUs look the same layout 6709900016C
    • tw2005
      • Oct 2011
      • 6458
      Then I found this https://www.badcaps.net/forum/showthread.php?p=123668
      Post #3
      Amazing the power of google sometimes.
      47uF 35V Samxon KM 5mm (C163)
      4.7uF 50V Samxon KM 5mm (C125)
      Are these 2 below , the same values you have mixed up?
      10uF 50V Samxon KM 5mm (C502)
      33uF 50V Samxon KM 5mm (C161)
      list from the other post for 32LC2D
      68uF 450V Rubycon AXW 18mm (C500)
      100uF 50V Samxon KM 8mm (C501)
      150uF 450V Rubycon MXC 35mm (C150)
      470uF 10V Samxon KM 6.3mm (C211, C238)
      680uF 10V Samxon GF 8mm (C210)
      1000uF 25V "H" 10mm (C208, C226, C228, C234, C237)
      1000uF 50V "H" 12.5mm (C221, C222)
      3300uF 16V "H" 12.5mm (C201, C202)
      • Tvbob
        tvbob
        • 204
        Thanks tw2005.I goggled it also but I used a Netscape browser. and just skimmed the posts here. It looks like i have (2) 4.7 uf caps in there now. I am retired now wish we had the internet back in the day, We had to work from micro film. I will post the results. Thanks agian.
        • Tvbob
          tvbob
          • 204
          Got right caps in, Comes right on in 3 blinks not 12 or so.It was c210 a 680uf@10v on the 3.4 volt rail Thanks for the links tw2005, with out your input I probably would still be working on it...
          • Dmuggy
            • Feb 2014
            • 15
            • Uk
            Hi there,
            I have the LG 32LC2D tv with various issues including the startup issues and crackling sound as mentioned on this thread. I am a total newby to this but as the tv is going in the bin anyway i thought it would be fun to try to fix it myself, and ive always fancied a bit of soldering. Could you tell me exactly what caps i would need to replace all of the caps on the power supply so i can make a phone call to order the partsand sound like i know what im talking about? Also, dont 4 of the caps need to be a higher temperature rating than the 105°C ones, 125°C i think?
              @Dmuggy, post the pictures of your board then I can mark which caps to replace. The caps I use are PANASONIC FM/FR/FC series.
              • selldoor
                Slow Learner
                • 7870
                @budm - Dmuggy has duplicate posted on another thread - doesnt want to take the set to bits as they are watching tv on it
                https://www.badcaps.net/forum/showth...611#post421611
                • Dmuggy
                  • Feb 2014
                  • 15
                  • Uk
                  Yes, sorry to dual post but i was having problems signing up and didnt think this had posted. Apparently you cant post until you have introduced yourself. Anyway, please come over to the other thread and help me out if you can, i need all the help i can get.
                  • chth96
                    Can I replace KME cap with Samxon GF cap?
                    by chth96
                    Hello.
                    I have 29inch LG CRT TV,And Yesterday,Whenever I connect AC power cord to power outlet without switch on, I heard a sound like white noise, And When I switched on this CRT TV, It sometime displayed correctly But usually It won't last more than 20 minute and The screen begin to dark and It finally did not display at all for hours..
                    Today,I dismantled its plastic case and discharged the biggest capacitor(400wv 470uf) which still holds 250 voltage,and I finally detached PCB from cathode-ray tube.
                    I measured ESR value of most of caps in PCB with MESR-100 and I found that KME(25v...
                    04-17-2024, 07:11 AM
                  • slybunda
                    Elite Capacitors? (450v 47uf power board Toshiba Vestel TV)
                    by slybunda
                    anyone heard of these caps before? at first glance i mistook them to be Elna caps but closer look and it was elite. not sure if they are known failure prone brand.
                    also they are 47uf and 450v. why are they so large in height? i can get replacement 450v 47uf caps that are a quarter the height. what am i missing here?
                    if i were to replace them what should i be looking for?
                    they are on the power board of a toshiba (vestel) tv power board.
                    pic attached...
                    11-13-2023, 06:33 AM
                  • yuzupatogik
                    Help with replacing Capacitors on Altec Lansing ATP 3
                    by yuzupatogik
                    I have this old (2004?) Altec Lansing ATP3 and i would like to replace the capacitors. I have identified 34 out of the 36 of them as Samxon GR of various capacities and voltages.
                    I can't find datasheets for the Samxon in any of the following variants:
                    10000uF 25 v - this one i really want to replace because i suspect it is what causes a dull hum regardless of the volume knob position or if the source is plugged in. I am eyeballing the Rubycon 25PK10000MEFCGC18X35.5 for this purpose. So if i pay a 10x the price part for shipping i might as well go ahead and...
                    02-14-2025, 04:11 PM
                  • Alfieh
                    NAD C320BEE repair possibly bad capacitors
                    by Alfieh
                    hey Im very new to repairing electronics with capacitors as well as using a multimeter so I need so help/guidance fixing this issue
                    recently I was handed a family members old NAD C320BEE that they had in their loft for storage for a few years but when powered on it went into power safety mode due to a problem on the protection circuit somewhere before it went into storage I was told it worked fine I found lots of people online talking about how the capasitors are known to be pretty bad in this model and can cause this issue the only problem being I don't have much experience sorting...
                    11-19-2024, 04:55 PM
                  • GEARELECTRONICS
                    Samxon capacitor esr
                    by GEARELECTRONICS
                    I need your advice.
                    -SAMXON 2200uf 50V tested 0.00 esr on Dick Smith Blue Esr meter and 2027 ohm on FLUKE 179 multimeter.
                    -Is this esr reading realistic?
                    Thank you
                    05-29-2023, 07:26 AM
