NAD C320BEE repair possibly bad capacitors
  • Alfieh
    • Nov 2024
    hey Im very new to repairing electronics with capacitors as well as using a multimeter so I need so help/guidance fixing this issue
    recently I was handed a family members old NAD C320BEE that they had in their loft for storage for a few years but when powered on it went into power safety mode due to a problem on the protection circuit somewhere before it went into storage I was told it worked fine I found lots of people online talking about how the capasitors are known to be pretty bad in this model and can cause this issue the only problem being I don't have much experience sorting this so I thought it might be a good opportunity to learn I found the online schematics for the board although I don't really know how to read them and tried checking some power levels around the board the power from the power supply mini board seemed correct but the +18 and -18 rail seemed to be incorrect from what I could figure out so I tried to check the capacitance of a lot of the capasitors on the board and I'm not too sure if I've found the issue or not the following capacitors stood out more than the rest but lots were slightly out of spec so I'm not sure how to take it if they need replacing or not:
    C431 0.75mf instead of 10uf
    C430 13.36mf instead of 10uf
    C12 111.4uf instead of 47uf
    C326 and c325 0.46mf instead of 47uf
    C421 580mf instead of 4.7uf
    C49 104900uf instead of 47uf
    C47 860uf instead of 47uf
    C413 and c414 350uf instead of 220uf
    C48 1280mf instead of 47uf
    C410 170uf instead of 47uf
    C342 250uf instead of 47uf
    C425 1.8mf instead of 2.2mf
    C436 is 0.25mf instead of 100uf
    C324 is 10.74mf instead of 47uf
    C323 is 450uf instead of 47uf
    C44 is 610uf instead of 220uf
    C43 is 1.43mf instead of 220uf
    C26 is OL on max settings should be 220uf
    C25 is 18.4mf instead of 220uf
    C15 is 13.6mf instead of 220uf
    C16 is 14.26mf instead of 220uf
    as I said I'm not experienced at all with this type of stuff so would be really appreciated for any guidance that you could give I'm not sure how big of an error of margin I should give c410 doesn't seem too far off but its still 3x over what it should be so should it be replaced or is it an issue further back down the line that is making this capacitor seem broken I'm not sure and don't really know where I should go
    TL;DR
    I need help fixing a NAD C320BEE but don't have much experience with electronics and don't know what to do
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8351
    So what are you getting on the positive and negative 18v rails? Some of your measurements are skewed because you measured them in circuit. So you probably measured multiple capacitors without understanding what the circuit does.
    Here is a rule if something you think is off: When in doubt, take it out! Or lift a leg and measure it again out of circuit. Keep in mind a hot capacitor will always read better than at room temperature. If a capacitor is off 10% of the original rating, it is a non concern for me. Even at 20% off the circuit shouldn't be affected, but I'd change it out after I know why this thing isn't working.
    Having a reading of 3x the value you should have on a cap, you measured something else and again it depends on the circuit. Don't focus on where is too much capacitance, rather on where there isn't enough and the ESR value on capacitors is like what a health gauge is on batteries depending on internal resistance and chemistry.
    Usually if an amp is in protect mode it has problems inside the PA stage. First things first: Find all the power rails and see that they are correct.
    Sometimes it is easier to follow the block diagram first, before you dive right into the schematics.
    • Alfieh
      • Nov 2024
      thanks for coming to help ill try tomorrow on taking off some of the capasitors that are too low and and measure their voltage and capacitance to see if they still seem weird
      I apologise but I'm having trouble knowing if the +18 and -18 rails are correct as I'm not even sure if I'm measuring them off the right point when I measure off the v+ and ground as well as v- and ground the voltage is quite low but if I power the amp off and on again it seems to jump up then slowly decrease the voltage so I'm not sure what is happening but from another form I found people were saying to measure l11 and l21 for the +/-18 rail but both show up as 0v atm so I'm not sure if that's correct or if its because its in power safety mode
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8351
        Measure the + 18V and - 18V at C49 and C410 capacitors. Look at your schematic.
        • ric000
          • Dec 2024
          • italia
          non è facile riparare un amplificatore per un profano ci servono diversi strumenti come misurare i componenti misurare le tensioni di alimentazione tantissime cose per me forse sbagli a misurare i condesatori dei video che ti possono aiutare https://www.youtube.com/results?sear...=the+river+lab
          io sono italiano ......
          • slybunda
            Elite Capacitors? (450v 47uf power board Toshiba Vestel TV)
            by slybunda
            anyone heard of these caps before? at first glance i mistook them to be Elna caps but closer look and it was elite. not sure if they are known failure prone brand.
            also they are 47uf and 450v. why are they so large in height? i can get replacement 450v 47uf caps that are a quarter the height. what am i missing here?
            if i were to replace them what should i be looking for?
            they are on the power board of a toshiba (vestel) tv power board.
            pic attached...
            11-13-2023, 06:33 AM
          • Eh546
            Help choosing capacitors for Asus VW266H
            by Eh546
            So i ordered a kit off of amazon, this one, thinking i ordered the right model. It had all the right caps i needed for the power board and most of the video board, i have only 5 caps left on the video board that i need to change, but the ones i have left doesn't have the right voltage/uf.
            I would need help choosing the right ones on digikey.ca
            The caps i'm missing are
            25v 47uf
            25v 47uf
            25v 47uf
            16v 220uf
            16v 220uf
            The one i have left from the kit are
            16v 47uf
            16v 47uf
            16v 47uf
            10v 220uf...
            07-15-2020, 06:51 PM
          • zklgfs
            Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
            by zklgfs
            I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
            08-11-2025, 02:14 PM
          • EnderFFX
            P15 Gen 1, Error 2203 but B0 / C0 are okay. possibly GPU swap?
            by EnderFFX
            Hello!
            I bought a P15 Gen 1 as defective and without much hints to its history.
            Was sold as "cannot start, weird stuff on screen".
            So i bought a replacement GPU (2070 Super) and BOOM it worked immediatly, i got lucky.
            Only that error 2203 every single time with beep loud enough to wake the kids is annoying.
            I sincerly tried to read up and got a U One to work (3.5.40, that update tool will always say 3-5-40 is latest on cloud althiugh i ran it 3 times, it updated once from 3.5.30 to .40. Is that a problem? P15 Gen 1 is old anyways...)...
            07-26-2025, 04:23 AM
          • ajdrenter
            Picking caps for Antec SU-380
            by ajdrenter
            In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
            https://www.badcaps.net/forum/showthread.php?t=14159
            It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
            05-13-2023, 10:40 AM
