*Please help* GRUNDIG GULCD37HDIT wont turn on
  • simple-me
    • Jan 2014
    • 27
    • England
    Re: *Please help* GRUNDIG GULCD37HDIT wont turn on
    I'll have to have a look tomorrow...I've got to get to work in half hour....thank you very much for your help so far...
    Learning something new everyday
    • multimeter
      • Jan 2011
      • 739
      • united kingdom
      hang on a mo before you do that.......,whats the marking on the other +stby ?cant quite read it
      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
      • simple-me
        • Jan 2014
        • 27
        • England
        +stby is 5.6v, the other 2 are reading 0.33v
        • simple-me
          • Jan 2014
          • 27
          • England
          thats ok dude,the pins to join are +5vstb and the one marked stby,but no mainboard connected,just want to confirm psu is actually working ,sorry its an ocd thing
          Am I right in thinking you want me to join +5vstb and the one marked stby pins together somehow...and then take a reading?
          • multimeter
            • Jan 2011
            • 739
            • united kingdom
            yes,linking the two should make the power supply rails to come up,then you can check the voltages on the other pins
            then we can bring the inverter live by using the same technique but different pins
            to confirm the psu is working how it should
            • simple-me
              • Jan 2014
              • 27
              • England
              #26
              I've connected the 2 pins together as you instructed but Im not getting any voltages on any of the pins...?? Not sure if I've done it right...
                What voltage do you measure on 5VSTB and STB while doing this? Note: normally I would use resistor to prevent damage to PSU board, of around 100 to 470 ohms.
                • simple-me
                  • Jan 2014
                  • 27
                  • England
                  #28
                  My BAD.....I forgot to connect the inverter board cables!!
                  I get the following voltages now..
                  from +5vstby and 2 pins below this I get 5.7v, stby is also reading 5.7v
                    Get any 24V on inverter cables?
                    • simple-me
                      • Jan 2014
                      • 27
                      • England
                      #30
                      No 24v on any of the inverter cables
                      • multimeter
                        • Jan 2011
                        • 739
                        • united kingdom
                        #31
                        good,with the +5vstby pin and stby connected,keep connected..
                        we can try and turn the inverter on.. bl_on pin to +5vstby
                        with inverter cables connected do you see the back-lights come on?
                        also with the +5vstby and stby connected,does the 12v rail come up?
                        but before you do this post up what the writing is next to the connector at the inverter end on each pin.
                        as in post #18,use a resistor,for the jumpering to limit current
                        • selldoor
                          Slow Learner
                          • 7870
                          #32
                          Neither can I what does it say? 5V ??? in
                            no 24V the inverter will not turn on - Power board is bad.
                            • simple-me
                              • Jan 2014
                              • 27
                              • England
                              #34
                              OK...I've used a resistor to limit the current....there is no 12v while the +5vstby and stby are connected
                              The back lights do not come on.
                              As for the writing I've attached a picture wasn't sure what you meant. They are labelled x532 and x521
                              Second picture is the actual inverter board.
                              • simple-me
                                • Jan 2014
                                • 27
                                • England
                                #35
                                I think it says +5Vmo in??? cant be sure...its so small
                                • multimeter
                                  • Jan 2011
                                  • 739
                                  • united kingdom
                                  #36
                                  would the 24v be present at the inverter end,after bl_on signal and stby connected?, ,maybee its generated after the bl_on signal is present
                                  can find a sch for it
                                  • simple-me
                                    • Jan 2014
                                    • 27
                                    • England
                                    #37
                                    Is this the schematic for it?
                                    • multimeter
                                      • Jan 2011
                                      • 739
                                      • united kingdom
                                      #38
                                      think thats for the mainboard
                                      • simple-me
                                        • Jan 2014
                                        • 27
                                        • England
                                        #39
                                        time for work guys...thank you very much so much so far...its been interesting
                                          24V is usually present before BL ON changes.
                                          • Gusse
                                            GE62VR 6RF Apache Pro - reboot until turn ON stuck at 1.6A
                                            by Gusse
                                            I am asking for your help because I am having a problem with no image on an MSI GE62VR 6RF Apache Pro.
                                            Here is a list of things I have checked:
                                            - Removed/reinserted the RAM
                                            - Removed the hard drive
                                            - Removed the SSD
                                            - Connected via HDMI -> no image
                                            - Tested caps lock -> working
                                            - USB key -> “activity” (LED flashes when inserted)
                                            - Reflashed the BIOS with CH341 using a version found on the MSI website (then checked the dump read with UEFI Tool) -> same result
                                            - Checked the power rails around the CPU on the...
                                            10-07-2025, 06:17 AM
                                          • PITERPENY
                                            MacBook A1989. Stuck in DFU and won't turn on!
                                            by PITERPENY
                                            MacBook A1989. does not work with dfu. Stuck in DFU and won't turn on!
                                            20 volts and 0.00 amperes
                                            Does anyone have any suggestions?
                                            It's possible that the problem is in the EFI (BIOS),
                                            who has the EFI ROM file please share
                                            01-11-2024, 07:43 PM
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                          • Stunt
                                            Hp Laptop Stuck on Hp protected by hp sure start screen
                                            by Stunt
                                            Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                            I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                            I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                            Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                            screen that's it and stuck there. I left it until the following day and i still...
                                            09-02-2025, 01:51 PM
                                          • Sergio Kub
                                            820-02536 It doesn't turn on, it's stuck at 5V.
                                            by Sergio Kub
                                            Has anyone ever removed the shielding from the 820-02536 board to access some components ?
                                            I need to check the 5V (PP5V_CHGR_SW) and other points.
                                            11-03-2025, 03:02 PM
